Is the I2C interface on the Arduino UNO R3 only good for very short cable lengths (e.g., 8" or so)?
I am using an UNO R3 (purchased from Adafruit) to drive a 16x2 LCD via I2C (SDA/SCL pins on UNO R3). Cabling is from shield to DB-9 connector pair to 16x2 display, with a total distance of about 8 inches. With that configuration, it works great. Display lights up, data gets displayed.
If I add a 6' DB-9 extension cable, nothing works. Display lights up for a few seconds, then goes dark. Reset UNO, reload software, same result. Checked the cable. It is straight one to one. No opens or shorts.
Using an O-Scope, I can see the SDA/SCL signals on the UNO R3 (cabling disconnected). If I simply connect the extension cable to the UNO R3 end (i.e., other end of the cable open), the interface dies. Same result using two different UNO R3's.
In just looking at the unloaded SDA/SCL lines, the pulses have a sharp negative going edge, but a very slow positive going edge. Perhaps it might need a pull up resister? I looked at the unloaded SDA/SCL lines on a MEGA2560, and the signal pulses looked very good.
I conducted a simple test using a bare board with my simple I2C software loaded. With nothing connected to the board but a scope probe, I can see the interface working. If I touch the SDA with my finger, the interface dies, although touching SCL doesn't seem to have any affect. Do the same test using a MEGA2560. Interface is unaffected.
In my last project, I used the same configuration, but the I2C interface was driven by a MEGA2560. It has worked flawlessly over a 6' DB-9 cable, so the problem seems to be specific to the UNO R3.
I2C cable limitation using Arduino UNO R3?
- Franklin97355
Re: I2C cable limitation using Arduino UNO R3?
This might be better answered in the Arduino forums. http://forum.arduino.cc/
- adafruit_support_rick
Some additional 4.7K pullup resistors can't hurt.
I2C is a spec by NXP (formerly Philips). Here is an App Note on using I2C:
http://www.gooligum.com.au/tutorials.html
The full spec is:
http://www.nxp.com/documents/other/UM10204_v5.pdf
NXP does have I2C extender IC's.
The issue with longer bus lines is the capacitance and the Resistor pull-ups. These form a low pass filter that rounds the rising edge of the waveforms. Small value pull-ups lower the frequency of the filter and can help if the lines are not too long. See the App note ans spec docs for details.
Another way to use longer lines is to lower the clock frequency.
The full spec is:
- bowserrh
I added 4.7K pull up resisters on the SCL and SDA lines. Now the I2C interface works fine over the 6' extension cable.
