I've encountered the following error:
"VC0706 Camera snapshot test
No camera found."
This error occurred after uploading the default Snapshot sketch. I've done my research and have found that the NewSoftSerial library has complications with the Arduino Mega 2560 according to the following board discussion: http://forums.adafruit.com/viewtopic.php?f=19&t=23448 . Has the library been updated since then? If not, does anybody know how to get around this problem? Any help would be appreciated. Thank you.
SoftwareSerial and Arduino Mega 2560 compatibility for Snaps
- arduinonewb13
Re: SoftwareSerial and Arduino Mega 2560 compatibility for S
What pins are you using on the Mega? Not all Mega pins support pin-change interrupts and SoftwareSerial requires pin-change interrupt capability on the receive pin.
http://arduino.cc/en/Reference/SoftwareSerial
Not all pins on the Mega and Mega 2560 support change interrupts, so only the following can be used for RX: 10, 11, 12, 13, 14, 15, 50, 51, 52, 53, A8 (62), A9 (63), A10 (64), A11 (65), A12 (66), A13 (67), A14 (68), A15 (69).
- arduinonewb13
I currently have it connected to RX 0 and TX 1, which are on the arduino ethernet shield.
Then you shouldn't be using software serial. As noted in my previous post, those pins are not supported for Software Serial on the Mega. However, those are hardware serial pins, so you can use the regular Serial library.I currently have it connected to RX 0 and TX 1, which are on the arduino ethernet shield.
- arduinonewb13
In your opinion, which library is easier to use for a beginner? Attached is a picture of my wiring....
Furthermore, here is my code:Code: Select all
// This is a basic snapshot sketch using the VC0706 library.
// On start, the Arduino will find the camera and SD card and
// then snap a photo, saving it to the SD card.
// Public domain.
// If using an Arduino Mega (1280, 2560 or ADK) in conjunction
// with an SD card shield designed for conventional Arduinos
// (Uno, etc.), it's necessary to edit the library file:
// libraries/SD/utility/Sd2Card.h
// Look for this line:
// #define MEGA_SOFT_SPI 0
// change to:
// #define MEGA_SOFT_SPI 1
// This is NOT required if using an SD card breakout interfaced
// directly to the SPI bus of the Mega (pins 50-53), or if using
// a non-Mega, Uno-style board.
#include <Adafruit_VC0706.h>
#include <SD.h>
// comment out this line if using Arduino V23 or earlier
#include <SoftwareSerial.h>
// uncomment this line if using Arduino V23 or earlier
// #include <NewSoftSerial.h>
// SD card chip select line varies among boards/shields:
// Adafruit SD shields and modules: pin 10
// Arduino Ethernet shield: pin 4
// Sparkfun SD shield: pin 8
// Arduino Mega w/hardware SPI: pin 53
// Teensy 2.0: pin 0
// Teensy++ 2.0: pin 20
#define chipSelect 4
// Pins for camera connection are configurable.
// With the Arduino Uno, etc., most pins can be used, except for
// those already in use for the SD card (10 through 13 plus
// chipSelect, if other than pin 10).
// With the Arduino Mega, the choices are a bit more involved:
// 1) You can still use SoftwareSerial and connect the camera to
// a variety of pins...BUT the selection is limited. The TX
// pin from the camera (RX on the Arduino, and the first
// argument to SoftwareSerial()) MUST be one of: 62, 63, 64,
// 65, 66, 67, 68, or 69. If MEGA_SOFT_SPI is set (and using
// a conventional Arduino SD shield), pins 50, 51, 52 and 53
// are also available. The RX pin from the camera (TX on
// Arduino, second argument to SoftwareSerial()) can be any
// pin, again excepting those used by the SD card.
// 2) You can use any of the additional three hardware UARTs on
// the Mega board (labeled as RX1/TX1, RX2/TX2, RX3,TX3),
// but must specifically use the two pins defined by that
// UART; they are not configurable. In this case, pass the
// desired Serial object (rather than a SoftwareSerial
// object) to the VC0706 constructor.
// Using SoftwareSerial (Arduino 1.0+) or NewSoftSerial (Arduino 0023 & prior):
//#if ARDUINO >= 100
// On Uno: camera TX connected to pin 2, camera RX to pin 3:
//SoftwareSerial cameraconnection = SoftwareSerial(2, 3);
// On Mega: camera TX connected to pin 69 (A15), camera RX to pin 3:
//SoftwareSerial cameraconnection = SoftwareSerial(69, 3);
//#else
//NewSoftSerial cameraconnection = NewSoftSerial(2, 3);
//#endif
Adafruit_VC0706 cam = Adafruit_VC0706(&cameraconnection);
// Using hardware serial on Mega: camera TX conn. to RX1,
// camera RX to TX1, no SoftwareSerial object is required:
Adafruit_VC0706 cam = Adafruit_VC0706(&Serial1);
// When using hardware SPI, the SS pin MUST be set to an
// output (even if not connected or used). If left as a
// floating input w/SPI on, this can cause lockuppage.
#if !defined(SOFTWARE_SPI)
#if defined(__AVR_ATmega1280__) || defined(__AVR_ATmega2560__)
if(chipSelect != 53) pinMode(53, OUTPUT); // SS on Mega
#else
if(chipSelect != 10) pinMode(10, OUTPUT); // SS on Uno, etc.
#endif
#endif
Serial.println("VC0706 Camera snapshot test");
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
return;
// Try to locate the camera
if (cam.begin()) {
Serial.println("Camera Found:");
} else {
Serial.println("No camera found?");
return;
// Print out the camera version information (optional)
char *reply = cam.getVersion();
if (reply == 0) {
Serial.print("Failed to get version");
} else {
Serial.println("-----------------");
Serial.print(reply);
// Set the picture size - you can choose one of 640x480, 320x240 or 160x120
// Remember that bigger pictures take longer to transmit!
cam.setImageSize(VC0706_640x480); // biggest
//cam.setImageSize(VC0706_320x240); // medium
//cam.setImageSize(VC0706_160x120); // small
// You can read the size back from the camera (optional, but maybe useful?)
uint8_t imgsize = cam.getImageSize();
Serial.print("Image size: ");
if (imgsize == VC0706_640x480) Serial.println("640x480");
if (imgsize == VC0706_320x240) Serial.println("320x240");
if (imgsize == VC0706_160x120) Serial.println("160x120");
Serial.println("Snap in 3 secs...");
delay(3000);
if (! cam.takePicture())
Serial.println("Failed to snap!");
else
Serial.println("Picture taken!");
// Create an image with the name IMAGExx.JPG
char filename[13];
strcpy(filename, "IMAGE00.JPG");
for (int i = 0; i < 100; i++) {
filename[5] = '0' + i/10;
filename[6] = '0' + i%10;
// create if does not exist, do not open existing, write, sync after write
if (! SD.exists(filename)) {
break;
// Open the file for writing
File imgFile = SD.open(filename, FILE_WRITE);
// Get the size of the image (frame) taken
uint16_t jpglen = cam.frameLength();
Serial.print("Storing ");
Serial.print(jpglen, DEC);
Serial.print(" byte image.");
int32_t time = millis();
pinMode(8, OUTPUT);
// Read all the data up to # bytes!
byte wCount = 0; // For counting # of writes
while (jpglen > 0) {
// read 32 bytes at a time;
uint8_t *buffer;
uint8_t bytesToRead = min(32, jpglen); // change 32 to 64 for a speedup but may not work with all setups!
buffer = cam.readPicture(bytesToRead);
imgFile.write(buffer, bytesToRead);
if(++wCount >= 64) { // Every 2K, give a little feedback so it doesn't appear locked up
Serial.print('.');
wCount = 0;
//Serial.print("Read "); Serial.print(bytesToRead, DEC); Serial.println(" bytes");
jpglen -= bytesToRead;
imgFile.close();
time = millis() - time;
Serial.println("done!");
Serial.print(time); Serial.println(" ms elapsed");
The code you have is already using the hardware Serial port 0 to print to the Serial Monitor - as in this line:
This uses Pins 0 and 1 (Rx & Tx) and will conflict with the camera as you have it connected.
But since the Mega has 4 hardware serial ports, I would recommend using Seral Port 1 for your camera. This is slightly simpler and much more efficient than using software serial.
Serial Port 1 is on pins 19 and 18: http://arduino.cc/en/Main/arduinoBoardMega2560
http://arduino.cc/en/reference/serial
Using Serial Port 1 on a Mega is the same as using Serial Port 0 - except you refer to it as Serial1 instead of just Serial:Serial: 0 (RX) and 1 (TX); Serial 1: 19 (RX) and 18 (TX); Serial 2: 17 (RX) and 16 (TX); Serial 3: 15 (RX) and 14 (TX). Used to receive (RX) and transmit (TX) TTL serial data. Pins 0 and 1 are also connected to the corresponding pins of the ATmega16U2 USB-to-TTL Serial chip.
- arduinonewb13
So wire the camera's Tx signal and the Rx signal's resistor (which is used to lower the voltage) to the corresponding Tx and Rx pins of Serial 1?
According to the default Snapshot sketch, the Rx and Tx values of the MEGA are not parallel to the camera's values. As indicated below:
Is this a misprint? Just asking for safety.
Not sure what you mean. Rx1 is pin 19 and Tx1 is pin 18.According to the default Snapshot sketch, the Rx and Tx values of the MEGA are not parallel to the camera's values. As indicated below:
- arduinonewb13
Does pin 19(Serial 1's Rx) connect to the camera's Tx? and pin 18(Serial 1's Tx) connect to the camera's Rx? Naturally, I would think to pair the board's Rx with the camera's Rx and the board's Tx with the camera's Tx, but the code says otherwise in the comments. Or Is it a misprint?
Here is the wiring of the project:
Furthermore, my code doesn't detect the camera...I can't understand why since the Adafruit_VC0706 object is legit and the begin() function is simple. Any suggestions????
// Public domain.
// change to:
#include <SD.h>
//#else
//#endif
//Adafruit_VC0706 cam = Adafruit_VC0706(&cameraconnection);
#else
#endif
#endif
return;
if (cam.begin()) {
} else {
return;
if (reply == 0) {
} else {
delay(3000);
else
char filename[13];
break;
pinMode(8, OUTPUT);
uint8_t *buffer;
Serial.print('.');
wCount = 0;
imgFile.close();
Tx is transmit. Rx is receive. What is transmitted from the camera is received by the Mega and vice-versa.I would think to pair the board's Rx with the camera's Rx and the board's Tx with the camera's Tx, but the code says otherwise in the comments.
- arduinonewb13
THANK YOU VERY MUCH!!!
