I have a set up for a pump using a L293D and atmega328p and RTC kit all from Adafruit,They run two peristaltic pumps that i want to have run on Mondays and Thursdays and the other channel on Tuesday and Sunday but i don't see how to get the day of week out of the RTC The spec sheet seems to say that but what command do I need to use to get it.
Tim
RTC day of week Monday,Tuesday ect..
Re: RTC day of week Monday,Tuesday ect..
Call the DayOfWeek() function in the RTCLib. It returns a number between 0 (Sunday) and 6 (Saturday).
- timwjkl
Thank you I feel stupid I read through that RTClib h file 3 or 4 times and missed it works perfect now to just clean it up.
Thanks again love you guys
Tim
Tim
- timwjkl
I meant to post this earlier the command is dayOfWeek() not DayOfWeek() just in case someone else is reading this post it works perfect too. I still need to drill the case and quit adding extras like a LCD and solenoid for feeder. Next is a temp sensor since I have the LCD why not
- timwjkl
This Prints to a LCD in format Tue Sep xx year
time in 24 hr xx:xx:xx
This is the code for my fish dosing pumps and feeder and temp sensor and it tells the time :-) if you don't kneed the fish stuff just strip it and use the time code. i have a PCB on OSH park (poorly silk screened) for the dosser feeder
#include <Wire.h>
#include "RTClib.h"
#include "LiquidCrystal.h"
#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into port 4 on the Arduino
#define ONE_WIRE_BUS 4
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// Date and time functions using a DS1307 RTC connected via I2C and Wire lib
RTC_DS1307 RTC;
// Connect via i2c, default address #0 (A0-A2 not jumpered)
LiquidCrystal lcd(0);
const int motor1Pin = 8; // H-bridge leg 1 (pin 2, 1A) (L293D pin numbers)
const int motor2Pin = 7; // H-bridge leg 2 (pin 7, 2A)
const int enablePin1 = 6; // H-bridge enable pin 1
const int motor3Pin = 2; // H-bridge leg 3 (pin 15, 1B)
const int motor4Pin = 3; // H-bridge leg 4 (pin 10, 2B)
const int enablePin2 = 5; // H-bridge enable pin 9
void setup () {
Serial.begin(115200);
Wire.begin();
RTC.begin();
sensors.begin();
// set up the LCD's number of rows and columns:
lcd.begin(16, 2);
//un-comment to set time then re-comment and upload to keep
//from resetting time on every reset
//RTC.adjust(DateTime(__DATE__, __TIME__));
// set all the other pins you're using as outputs:
pinMode(motor1Pin, OUTPUT);
pinMode(motor2Pin, OUTPUT);
pinMode(enablePin1, OUTPUT);
pinMode(motor3Pin, OUTPUT);
pinMode(motor4Pin, OUTPUT);
pinMode(enablePin2, OUTPUT);
digitalWrite(motor1Pin, LOW); // set leg 1 of the H-bridge low PUMP 1
digitalWrite(motor2Pin, LOW); // set leg 2 of the H-bridge high EXTRA
digitalWrite(motor3Pin, LOW); // set leg 3 of the H-bridge low PUMP 2
digitalWrite(motor4Pin, LOW); // set leg 4 of the H-bridge high FEEDER
//set enablePin high so that motor can turn on:
digitalWrite(enablePin1, LOW);
digitalWrite(enablePin2, LOW);
sensors.requestTemperatures(); // Send the command to get temperatures
DateTime now = RTC.now(); //get time
lcd.setCursor(0, 0);
//set row and space to start word
switch(now.dayOfWeek())
case 0: lcd.print("Sun"); break;
case 1: lcd.print("Mon"); break;
case 2: lcd.print("Tue"); break;
case 3: lcd.print("Wed"); break;
case 4: lcd.print("Thu"); break;
case 5: lcd.print("Fri"); break;
case 6: lcd.print("Sat"); break;
default: lcd.print("Error");
lcd.print(' ');
switch(now.month())
case 1: lcd.print("Jan "); break;
case 2: lcd.print("Feb "); break;
case 3: lcd.print("Mar "); break;
case 4: lcd.print("Apr "); break;
case 5: lcd.print("May "); break;
case 6: lcd.print("Jun "); break;
case 7: lcd.print("Jul "); break;
case 8: lcd.print("Aug "); break;
case 9: lcd.print("Sep "); break;
case 10: lcd.print("Oct "); break;
case 11: lcd.print("Nov "); break;
case 12: lcd.print("Dec "); break;
default: lcd.print("Error ");
lcd.print(now.day(), DEC);
lcd.print(' ');
lcd.print(now.year(), DEC);
lcd.setCursor(0, 1); // start row 2 (1)
lcd.print(now.hour(), DEC);
lcd.print(':');
lcd.print(now.minute(), DEC);
lcd.print(':');
lcd.print(now.second(), DEC);
lcd.setCursor(9, 1); //move temp to 9 space row 2(1)
lcd.print(' ');
lcd.print(sensors.getTempCByIndex(0) * 1.8 + 32.0); //converts celc to fraenh C to F
lcd.print('F');
delay(30);
// Set the time you want the motors to START
if((now.hour () == 2)&&(now.minute () == 23 )&&(now.second () == 00)&&(now.dayOfWeek()==5))
lcd.clear();
lcd.print(" TRUE");
lcd.print(" ");
lcd.print("Pump 1");
digitalWrite(enablePin1, HIGH);
digitalWrite(motor1Pin, HIGH);
delay(8500); // set how long you want the motor to run... 1000 = aprox 1ml
lcd.clear();
lcd.print(" TRUE");
lcd.print(" ");
lcd.print("Pump 2");
digitalWrite(enablePin2, HIGH);
digitalWrite(motor3Pin, HIGH);
lcd.clear();
lcd.print(" TRUE");
lcd.print(" ");
lcd.print("FEEDER 1");
digitalWrite(motor4Pin, HIGH);
delay(8500);
// the feeder only need momentary power to start feed cycle using EHEIM modded feeder to use manual
//feed circuit. I'm only using long time to show on screen
