avrdude.exe: stk500_getsync(): not in sync: resp=0x00
David1995
Post by David1995 »
I tried to run a hacked EEG toy throught the Arduino uno and I received the message "avrdude.exe: stk500_getsync(): not in sync: resp=0x00". I've attempted to switch the usb chord, un-install and re-install the board to my computer and it's driver, and have tried using all the ports on my laptop. Regardless, I always get the same message. The only time the upload is successful is when there is nothing connected to rx <- 0. Is there anyway to remedy this problem?
Please and thank you
Franklin97355
Re: avrdude.exe: stk500_getsync(): not in sync: resp=0x00
Post by Franklin97355 »
The Arduino is programmed through the serial interface so you need to have other devices disconnected when you are programming.
David1995
Post by David1995 »
What do you mean?
David1995
Post by David1995 »
Wait, nevermind. I need to open the serial monitor in order to view the incoming data. Thanks for the response though :)
Return to “Arduino”
