I'm using an Arduino MEGA with 2 Adafruit motor shields v2.
My program does not start after uploading it IF BOTH of the following things are declared in it:
1- One or two of the motor shield is started with the function [board].begin()
2- trying to use one of the external interrupts on PINs 20 or 21.
As far as I know, those are the I2C pins on the MEGA board and the communication with the shields could probably be causing the problem. Is there any way that I could still use the Adafruit shields and taking interrupts from the above mentioned PINs?
Thanks.
Interrupts on PINs 20,21 blocked on MEGA
Re: Interrupts on PINs 20,21 blocked on MEGA
The Motor Shield does use I2C to communicate with the controller. On the Mega, that's pins 20 and 21.
Thx. I already know that. But I mean that the PINs are still free because the shield is mounted on the arduino, so I thought I could probably still make use of their Interrupt abilities!
- adafruit_support_bill
It doesn't work that way. Pins 20 and 21 are directly connected to the SDA and SCL pins. Although the there is nothing physically connected at the pin 20/21 locations, the pins are in use for i2c communication.the PINs are still free because the shield is mounted on the arduino, so I thought I could probably still make use of their Interrupt abilities!
