SD vrs SdFat...Trouble changing file position.
harbingerx81
Post by harbingerx81 »
I posted something similar to this a litte over a week, but I have since narrowed the problem down and it needs a new thread...
This is code to read from an SD card and display a BMP on an LCD screen. Everything worked fine using the standard SD library that comes with the Arduino IDE, but my project is going to require 2 SD card readers, which means I have to switch over to SdFat for the multicard support. My problem is, I have apparently not made all the necessary changes to the sketch for it to work using the SdFat library. The changes I know I need to make are marked below with "<-----"s (other than the includes, obviously).
#include <Adafruit_GFX.h>    // Core graphics library
#include <Adafruit_ST7735.h> // Hardware-specific library
#include <SPI.h>
#include <SD.h>
#if defined(__SAM3X8E__)
    #undef __FlashStringHelper::F(string_literal)
    #define F(string_literal) string_literal
#endif
// TFT display and SD card will share the hardware SPI interface.
// Hardware SPI pins are specific to the Arduino board type and
// cannot be remapped to alternate pins.  For Arduino Uno,
// Duemilanove, etc., pin 11 = MOSI, pin 12 = MISO, pin 13 = SCK.
#define SD_CS    4  // Chip select line for SD card
#define TFT_CS  10  // Chip select line for TFT display
#define TFT_DC   9  // Data/command line for TFT
#define TFT_RST  8  // Reset line for TFT (or connect to +5V)
//Use these pins for the shield!
//#define TFT_CS   10
//#define TFT_DC   8
//#define TFT_RST  0  // you can also connect this to the Arduino reset
Adafruit_ST7735 tft = Adafruit_ST7735(TFT_CS, TFT_DC, TFT_RST);
void setup(void) {
  Serial.print("Initializing SD card...");
  if (!SD.begin(SD_CS)) {   ///<--if (!SECURE.begin(SD_SECURE, SPI_HALF_SPEED))
    Serial.println("failed!");/// ** SdFat SECURE, and SD_SECURE pin defined
    return;
  Serial.println("OK!");
  bmpDraw("parrot.bmp", 0, 0);
// This function opens a Windows Bitmap (BMP) file and
// displays it at the given coordinates.  It's sped up
// by reading many pixels worth of data at a time
// (rather than pixel by pixel).  Increasing the buffer
// size takes more of the Arduino's precious RAM but
// makes loading a little faster.  20 pixels seems a
// good balance.
#define BUFFPIXEL 20
void bmpDraw(char *filename, uint8_t x, uint8_t y) {
  File     bmpFile;      //////<--------------------SdFat mpFile;
  int      bmpWidth, bmpHeight;   // W+H in pixels
  uint8_t  bmpDepth;              // Bit depth (currently must be 24)
  uint32_t bmpImageoffset;        // Start of image data in file
  uint32_t rowSize;               // Not always = bmpWidth; may have padding
  uint8_t  sdbuffer[3*BUFFPIXEL]; // pixel buffer (R+G+B per pixel)
  uint8_t  buffidx = sizeof(sdbuffer); // Current position in sdbuffer
  boolean  goodBmp = false;       // Set to true on valid header parse
  boolean  flip    = true;        // BMP is stored bottom-to-top
  int      w, h, row, col;
  uint8_t  r, g, b;
  uint32_t pos = 0, startTime = millis();
  if((x >= tft.width()) || (y >= tft.height())) return;
  Serial.println();
  Serial.print("Loading image '");
  Serial.print(filename);
  Serial.println('\'');
  // Open requested file on SD card
  if ((bmpFile = SD.open(filename)) == NULL) {  ////<------if (!bmpFile.open(filename, O_READ))
    Serial.print("File not found");
    return;
  // Parse BMP header
  if(read16(bmpFile) == 0x4D42) { // BMP signature
    Serial.print("File size: "); Serial.println(read32(bmpFile));
    (void)read32(bmpFile); // Read & ignore creator bytes
    bmpImageoffset = read32(bmpFile); // Start of image data
    Serial.print("Image Offset: "); Serial.println(bmpImageoffset, DEC);
    // Read DIB header
    Serial.print("Header size: "); Serial.println(read32(bmpFile));
    bmpWidth  = read32(bmpFile);
    bmpHeight = read32(bmpFile);
    if(read16(bmpFile) == 1) { // # planes -- must be '1'
      bmpDepth = read16(bmpFile); // bits per pixel
      Serial.print("Bit Depth: "); Serial.println(bmpDepth);
      if((bmpDepth == 24) && (read32(bmpFile) == 0)) { // 0 = uncompressed
        goodBmp = true; // Supported BMP format -- proceed!
        Serial.print("Image size: ");
        Serial.print(bmpWidth);
        Serial.print('x');
        Serial.println(bmpHeight);
        // BMP rows are padded (if needed) to 4-byte boundary
        rowSize = (bmpWidth * 3 + 3) & ~3;
        // If bmpHeight is negative, image is in top-down order.
        // This is not canon but has been observed in the wild.
        if(bmpHeight < 0) {
          bmpHeight = -bmpHeight;
          flip      = false;
        // Crop area to be loaded
        w = bmpWidth;
        h = bmpHeight;
        if((x+w-1) >= tft.width())  w = tft.width()  - x;
        if((y+h-1) >= tft.height()) h = tft.height() - y;
        // Set TFT address window to clipped image bounds
        tft.setAddrWindow(x, y, x+w-1, y+h-1);
        for (row=0; row<h; row++) { // For each scanline...
          // Seek to start of scan line.  It might seem labor-
          // intensive to be doing this on every line, but this
          // method covers a lot of gritty details like cropping
          // and scanline padding.  Also, the seek only takes
          // place if the file position actually needs to change
          // (avoids a lot of cluster math in SD library).
          if(flip) // Bitmap is stored bottom-to-top order (normal BMP)
            pos = bmpImageoffset + (bmpHeight - 1 - row) * rowSize;
          else     // Bitmap is stored top-to-bottom
            pos = bmpImageoffset + row * rowSize;
          if(bmpFile.position() != pos) {  ///<---if(bmpFile.curPosition() != pos)
            bmpFile.seek(pos);                ///<----------bmpFile.seekSet(pos);
            buffidx = sizeof(sdbuffer); // Force buffer reload
          for (col=0; col<w; col++) { // For each pixel...
            // Time to read more pixel data?
            if (buffidx >= sizeof(sdbuffer)) { // Indeed
              bmpFile.read(sdbuffer, sizeof(sdbuffer));
              buffidx = 0; // Set index to beginning
            // Convert pixel from BMP to TFT format, push to display
            b = sdbuffer[buffidx++];
            g = sdbuffer[buffidx++];
            r = sdbuffer[buffidx++];
            tft.pushColor(tft.Color565(r,g,b));
          } // end pixel
        } // end scanline
        Serial.print("Loaded in ");
        Serial.print(millis() - startTime);
        Serial.println(" ms");
      } // end goodBmp
  bmpFile.close();
  if(!goodBmp) Serial.println("BMP format not recognized.");
// These read 16- and 32-bit types from the SD card file.
// BMP data is stored little-endian, Arduino is little-endian too.
// May need to reverse subscript order if porting elsewhere.
uint16_t read16(File f) {    ///<---------uint16_t read16(SdFile f)
  uint16_t result;
  ((uint8_t *)&result)[0] = f.read(); // LSB
  ((uint8_t *)&result)[1] = f.read(); // MSB
  return result;
uint32_t read32(File f) {   ///<-----uint16_t read16(SdFile f)
  uint32_t result;
  ((uint8_t *)&result)[2] = f.read();
  ((uint8_t *)&result)[3] = f.read(); // MSB
  return result;
What Seems to happen is that the pointer keeping track of file position no longer moves when I use SdFile.read()...The serial output reads the proper numbers of bytes for the first checks and outputs the 16-bit BMP signature properly, but the 32-bit reads that follow still take data from the beginning of the file:
Loading image 'device.bmp'
File size: 3224915266
Image Offset: 3224915266
Header size: 3224915266
The first read (16-bit) properly gets 0x4D42, but the subsequent reads (32-bit) return 0xC0384D42 so obviously the file position is not updating...
Is there some initializer that I am missing, some other method I should be using instead of file.read(), or does SdFat not automatically move the pointer like the SD library?
fat16lib
Re: SD vrs SdFat...Trouble changing file position.
Post by fat16lib »
There is a problem with both read16() and read32() since they use call by value. A copy for the file structure is made and the file position is never updated in the actual file structure.
SD.h happens to work since it is a wrapper for SdFat files and the SD.h File structure contains a pointer to the SdFat file structure. Therefore the file position gets updated in the SdFat structure which is accessed by the pointer.
You need to use a pointer like this:
uint16_t read16(File* f) {
  uint16_t result;
  ((uint8_t *)&result)[0] = f->read(); // LSB
  ((uint8_t *)&result)[1] = f->read(); // MSB
  return result;
Or call by reference like this.
uint16_t read16(File& f) {
  uint16_t result;
  return result;
Call by reference requires a simpler modification but is considered poor practice when the argument of a function is modified. References can be confusing, as they have value syntax but pointer semantics.
Return to “Arduino”
