I'm trying to simply output date and time to and LCD via i2c backpack from the RTC on the datalogger shield.
Heres the code:
#include <LiquidCrystal.h>
#include "Wire.h"
#include "RTClib.h"
RTC_DS1307 RTC;
LiquidCrystal lcd(0);
void setup () {
Serial.begin(57600);
Wire.begin();
RTC.begin();
lcd.begin(16, 2);
pinMode(10, OUTPUT);
void loop ()
DateTime now = RTC.now();
lcd.setCursor(0,0);
//curent time
lcd.print(now.hour(), DEC);
lcd.print(':');
lcd.print(now.minute(), DEC);
lcd.print(':');
lcd.print(now.second()), DEC;
Ok, first problem is the seconds count from :1, :2, :3,...etc. for the first minute after uploading, then after :59th sec. count :09,:19,:29,:39, :49,....etc until :10sec then increment as normal.
Second, not really a problem, but when the minutes are in single digits there is no 0 in front, for example: 1:9:14 not 1:09:14. any help is very appreciated, I'm new to this and have very limited coding knowledge. Thanks again!
RTC output formatting problem
- Franklin97355
Re: RTC output formatting problem
Both problems are the same in that you need to write code to tell the display if the number is less than 10 it needs to add the leading 0.
- jigsawnz
This will probably solves both problems.
good luck
if ( now.hour() < 10 )
lcd.print( '0' );
lcd.print(':');
if ( now.minute() < 10 )
lcd.print('0');
lcd.print(':');
if ( now.second() < 10 )
lcd.print( '0' );
