Alarm Clock
Tom1988
Alarm Clock
Post by Tom1988 »
Hello!
I gotten quite far with creating my Arduino Uno powered alarm clock, with a Waveshield as well. I need a little help with setting the alarm time.
I am fine with adjusting the time, using adjustTime(1) etc. However, how could I do this for a variable such as 'Alarm'?
Another part of this, the alarm variable needs to be stored in such a way so that it can be displayed on the 4digit 7seg display.
Here is my code so far:
#include <WaveHC.h>
#include <WaveUtil.h>
#include <Time.h>
#include <Wire.h>
#include "Adafruit_LEDBackpack.h"
#include "Adafruit_GFX.h"
SdReader card;    // This object holds the information for the card
FatVolume vol;    // This holds the information for the partition on the card
FatReader root;   // This holds the information for the volumes root directory
WaveHC wave;      // This is the only wave (audio) object, since we will only play one at a time
uint8_t dirLevel; // indent level for file/dir names    (for prettyprinting)
dir_t dirBuf;     // buffer for directory reads
Adafruit_7segment matrix = Adafruit_7segment();
int hour1;
int hour2;
int minute1;
int minute2;
 * Define macro to put error messages in flash memory
#define error(msg) error_P(PSTR(msg))
#define TIME_HEADER  "T"   // Header tag for serial time sync message
#define TIME_REQUEST  7    // ASCII bell character requests a time sync message
int inPin = 17;      //Input pin for button minute
int inPin2 = 16;      //Input pin for button hour
int inPin3 = 15;    //Input pin for button set alarm
int inPin4 = 14;    //Input pin for alarm button LED
int inPin5 = 6;     //Input pin for button cancel alarm
int val;     // variables for reading the pin status, for buttons
int val2;
int val3;
int val4;
int val5;
int alarm1=1;
int alarm2=2;
int alarm3=2;
int alarm4=0;
int brightness1=1;
int brightness2=10;
int rate=2;
int Counter=0;
int AlarmOn=0;
//////////////////////////////////// SETUP
  Serial.begin(9600);           // set up Serial library at 9600 bps for debugging
    matrix.begin(0x70);
    matrix.setBrightness(brightness2);
  setTime(12,00,0,1,1,11); // set time to ... Jan 1 2011
  if (!card.init()) {         //play with 8 MHz spi (default faster!)
    error("Card init. failed!");  // Something went wrong, lets print out why
  // enable optimize read - some cards may timeout. Disable if you're having problems
  card.partialBlockRead(true);
  // Now we will look for a FAT partition!
  uint8_t part;
  for (part = 0; part < 5; part++) {   // we have up to 5 slots to look in
    if (vol.init(card, part))
      break;                           // we found one, lets bail
  if (part == 5) {                     // if we ended up not finding one  :(
    error("No valid FAT partition!");  // Something went wrong, lets print out why
  // Try to open the root directory
  if (!root.openRoot(vol)) {
    error("Can't open root dir!");      // Something went wrong,
//////////////////////////////////// LOOP
 //Dimming the display between 9pm and 8am
 if (hour()>20 || hour()<8){
 matrix.setBrightness(brightness1);
 else {
 //Displaying the time
 matrix.writeDigitNum(0, hour()/10);
 matrix.writeDigitNum(1, hour()%10);
 matrix.writeDigitNum(3, minute()/10);
 matrix.writeDigitNum(4, minute()%10);
 matrix.drawColon(true);
 matrix.writeDisplay();
 //Adjusting current time, using the pushbuttons to add 1 to the minute and hour
   val = digitalRead(inPin);  // read input value
   if (val == LOW) {         // check if the input is HIGH (button released)
   adjustTime(60);  // add 1
   delay(200);
 //  hour adjusting
   val2 = digitalRead(inPin2);  // read input value
   if (val2 == LOW) {         // check if the input is HIGH (button released)
   adjustTime(3600);  // add 1 hour
   delay(200);
 //Code to set the alarm. Press button, digits start to flash, then use normal adjustment time buttons
 //to change the alarm time (as well as display whilst changing). When alarm button is pressed again,
 // Save the displayed time as the alarm time and then revert back to the current time.
 Off:
  val3 = digitalRead(inPin3);
  if (val3 == LOW) {
      Serial.print(":");
      delay(500);
      Counter=1;
      if (AlarmOn==0){
      AlarmOn=1;
      alarm1=1;
      alarm2=2;
      alarm3=0;
      alarm4=0;
      digitalWrite(inPin4, HIGH);
      else{
      AlarmOn=0;
      digitalWrite(inPin4, LOW);
      goto Off;
      while(Counter==1) {
          matrix.blinkRate(rate);
          delay(200);
  // change alarm time hours
          alarm1=2;
          alarm2=3;
          delay(200);
  // change alarm time minutes
          alarm3=1;
          alarm4=6;
          val4 = digitalRead(inPin3);  // read input value
          if (val4== LOW) {
          delay(200);
          matrix.blinkRate(0);
          Counter=0;
          continue;
      matrix.writeDigitNum(0, alarm1);
      matrix.writeDigitNum(1, alarm2);
      matrix.writeDigitNum(3, alarm3);
      matrix.writeDigitNum(4, alarm4);
  // Setting the alarm off, needs to be coded for variable alarm time
  if (AlarmOn==1 && hour()/10==alarm1 && hour()%10==alarm2 && minute()/10==alarm3 && minute()%10==alarm4 && second()==0){
      root.rewind();
      play(root);
void processSyncMessage() {
  unsigned long pctime;
  const unsigned long DEFAULT_TIME = 1357041600; // Jan 1 2013
  if(Serial.find(TIME_HEADER)) {
     pctime = Serial.parseInt();
     if( pctime >= DEFAULT_TIME) { // check the integer is a valid time (greater than Jan 1 2013)
       setTime(pctime); // Sync Arduino clock to the time received on the serial port
/////////////////////////////////// HELPERS
 * print error message and halt
void error_P(const char *str) {
  PgmPrint("Error: ");
  SerialPrint_P(str);
  sdErrorCheck();
  while(1);
 * print error message and halt if SD I/O error, great for debugging!
void sdErrorCheck(void) {
  if (!card.errorCode()) return;
  PgmPrint("\r\nSD I/O error: ");
  Serial.print(card.errorCode(), HEX);
  PgmPrint(", ");
  Serial.println(card.errorData(), HEX);
  while(1);
 * play recursively - possible stack overflow if subdirectories too nested
void play(FatReader &dir) {
  FatReader file;
  while (dir.readDir(dirBuf) > 0) {    // Read every file in the directory one at a time
    // Skip it if not a subdirectory and not a .WAV file
    if (!DIR_IS_SUBDIR(dirBuf)
         && strncmp_P((char *)&dirBuf.name[8], PSTR("WAV"), 3)) {
      continue;
    Serial.println();            // clear out a new line
    for (uint8_t i = 0; i < dirLevel; i++) {
       Serial.write(' ');       // this is for prettyprinting, put spaces in front
    if (!file.open(vol, dirBuf)) {        // open the file in the directory
      error("file.open failed");          // something went wrong
    if (file.isDir()) {                   // check if we opened a new directory
      putstring("Subdir: ");
      printEntryName(dirBuf);
      Serial.println();
      dirLevel += 2;                      // add more spaces
      // play files in subdirectory
      play(file);                         // recursive!
      dirLevel -= 2;
    else {
      // Aha! we found a file that isnt a directory
      putstring("Playing ");
      printEntryName(dirBuf);              // print it out
      if (!wave.create(file)) {            // Figure out, is it a WAV proper?
        putstring(" Not a valid WAV");     // ok skip it
      } else {
        Serial.println();                  // Hooray it IS a WAV proper!
        wave.play();                       // make some noise!
        uint8_t n = 0;
        while (wave.isplaying) {// playing occurs in interrupts, so we print dots in realtime
          putstring(".");
          if (!(++n % 32))Serial.println();
          delay(100);
          val5 = digitalRead(inPin5);  // read input value
          if (val5== LOW) {
          delay(200);
          return;
        sdErrorCheck();                    // everything OK?
        // if (wave.errors)Serial.println(wave.errors);     // wave decoding errors
Another thing I have noticed just now. I set the alarm (using the poor script for 23:20 you can see in the code) and set it off, the music plays, I cancel the alarm fine. The script then goes back to being a clock. However, cycling back to 23:19 and allowing it to hit the alarm time again. It sets the alarm off, I hit the cancel button and it then changes to 12:00 and seems to freak out a little. Unsure of the cause of this so far!
Sorry for the essay,
Tom
Return to “Arduino”
