Dear folks,
Hi. I'm using an Arduino Micro to send but NOT receive MIDI. I'd love to use the RX pin as a simple digital input while the TX pin is chugging away sending MIDI. Is that possible? All other pins are already occupied.
Doug
Does Serial1 monopolize both RX and TX?
- adafruit_support_rick
Re: Does Serial1 monopolize both RX and TX?
Good question. I think that all you need to do is to clear bit 4 (receiver enable) of the USART Control and Status Register B (UCSR1B)
Try putting this into your setup AFTER you call Serial1.begin, and BEFORE you try to configure the pin for input:
cli(UCSR1B, RXEN1);
