I am working on my first project, and it involves a keypad. Beginner programmer too.
I wrote a routine where a user presses a key to start data entry, a keycode is entered, and another key is pressed to finish the entry. The Arduino Uno then goes back to monitoring temperatures.
The design is often seen in systems where you have to press *(pin)# to open a gate.
The issue is how to 'timeout' if the '#' key is not pressed in a certain amount of time, so the controller can exit the keypress sequence and resume its regular routine.
Any suggestions?
Limiting time for keypress code.
Re: Limiting time for keypress code.
There are several ways to solve that problem, some more complicated than others.
The most beginner-friendly version is probably based on the same ideas used in the "Blink Without Delay" example from the Arduino Playground: http://arduino.cc/en/Tutorial/BlinkWithoutDelay
The general principle involves converting a 'blocking' operation (one that won't let you do anything else until it's done) to a 'non-blocking' equivalent (one that checks to see if it should do something, but then lets you do other things if the answer is no).
See this project for some code that is very similar to what you are looking for: http://learn.adafruit.com/biometric-sec ... m-and-test
- unbound
Thank you for the info!
