I was able to get the example Arduino sketch to work with the mini 8x8 LED green dot matrix and a MEGA.
Confused by the datasheet, first question is:
What is the maximum current draw for this device?
30mA?
Second question is:
Is there any way to use software I2C?
Thanks.
mini 8x8 questions
- adafruit_support_bill
Re: mini 8x8 questions
I haven't measured the current draw, but since it is a multiplexed display, there will be 8 LEDs on at a time. I would estimate the max current draw to be about 180 mA (20 mA per led plus some for the chip).
Software I2C should be possible, but it would require a bit of library hacking.
- carlw
Thank you.
Most of this sketch was copied from another Adafruit learning example.
Space Invaders Aliens for a regular Arduino and the mini 8x8...
* This is a library for our I2C LED Backpacks
* Designed specifically to work with the Adafruit LED Matrix backpacks
* ----> http://www.adafruit.com/products/872
* ----> http://www.adafruit.com/products/871
* ----> http://www.adafruit.com/products/870
* These displays use I2C to communicate, 2 pins are required to
* interface. There are multiple selectable I2C addresses. For backpacks
* with 2 Address Select pins: 0x70, 0x71, 0x72 or 0x73. For backpacks
* with 3 Address Select pins: 0x70 thru 0x77
* Adafruit invests time and resources providing this open source code,
* please support Adafruit and open-source hardware by purchasing
* products from Adafruit!
* Written by Limor Fried/Ladyada for Adafruit Industries.
* BSD license, all text above must be included in any redistribution
#include <Wire.h>
#include "Adafruit_LEDBackpack.h"
#include "Adafruit_GFX.h"
Adafruit_8x8matrix matrix = Adafruit_8x8matrix();
Serial.begin(9600);
Serial.println("8x8 LED Matrix - Space Invaders - Display Aliens Test");
matrix.begin(0x70); // pass in the address
static const uint8_t PROGMEM
alien1A_bmp[] =
B00011000, // This is the first frame for alien #1
B00111100, // If you squint you can kind of see the
B01111110, // image in the 0's and 1's.
B11011011,
B11111111,
B00100100,
B01011010,
B10100101,
alien1B_bmp[] =
B00011000, // This is the second frame for alien #1
B00111100,
B01111110,
B11011011,
B11111111,
B00100100,
B01011010,
B01000010,
alien2A_bmp[] =
B00000000, // First frame for alien #2
B00111100,
B01111110,
B11011011,
B11011011,
B01111110,
B00100100,
B11000011,
alien2B_bmp[] =
B00111100, // Second frame for alien #2
B01111110,
B11011011,
B11011011,
B01111110,
B00100100,
B00100100,
B00100100,
alien3A_bmp[] =
B00100100, // First frame for alien #3
B00100100,
B01111110,
B11011011,
B11111111,
B11111111,
B10100101,
B00100100,
alien3B_bmp[] =
B00100100, // Second frame for alien #3
B10100101,
B11111111,
B11011011,
B11111111,
B01111110,
B00100100,
B01000010,
alien4A_bmp[] =
B00111100, // First frame for alien #4
B01111110,
B00110011,
B01111110,
B00111100,
B00000000,
B00001000,
B00000000,
alien4B_bmp[] =
B00111100, // Second frame for alien #4
B01111110,
B10011001,
B01111110,
B00111100,
B00000000,
B00001000,
B00001000,
alien4C_bmp[] =
B00111100, // Third frame for alien #4 (NOT a repeat of frame 1)
B01111110,
B11001100,
B01111110,
B00111100,
B00000000,
B00000000,
B00001000,
alien4D_bmp[] =
B00111100, // Fourth frame for alien #4 (NOT a repeat of frame 2)
B01111110,
B01100110,
B01111110,
B00111100,
B00000000,
B00000000,
B00000000,
matrix.setTextSize(1);
matrix.setTextWrap(false); // we dont want text to wrap so it scrolls nicely
matrix.setTextColor(LED_ON);
for (int8_t x=0; x>=-36; x--) {
matrix.clear();
matrix.setCursor(x,0);
matrix.print("Aliens!");
matrix.writeDisplay();
delay(100);
for (byte times = 1; times <= 2; times ++) {
matrix.clear();
matrix.drawBitmap(0, 0, alien1A_bmp, 8, 8, LED_ON);
delay(250);
matrix.clear();
matrix.drawBitmap(0, 0, alien1B_bmp, 8, 8, LED_ON);
delay(250);
matrix.clear();
matrix.drawBitmap(0, 0, alien2A_bmp, 8, 8, LED_ON);
delay(250);
matrix.clear();
matrix.drawBitmap(0, 0, alien2B_bmp, 8, 8, LED_ON);
delay(250);
matrix.clear();
matrix.drawBitmap(0, 0, alien3A_bmp, 8, 8, LED_ON);
delay(250);
matrix.clear();
matrix.drawBitmap(0, 0, alien3B_bmp, 8, 8, LED_ON);
delay(250);
matrix.clear();
matrix.drawBitmap(0, 0, alien4A_bmp, 8, 8, LED_ON);
delay(125);
matrix.clear();
matrix.drawBitmap(0, 0, alien4B_bmp, 8, 8, LED_ON);
delay(125);
matrix.clear();
matrix.drawBitmap(0, 0, alien4C_bmp, 8, 8, LED_ON);
delay(125);
matrix.clear();
matrix.drawBitmap(0, 0, alien4D_bmp, 8, 8, LED_ON);
delay(125);
