We have an huge project, in a brand new building we want to made one digital led strip on each levels (6) on vertical position near the elevator door for mark the elevator level
when it's on move.
For each level an 2.3 meters segement of led strip x 6 = 13.8 meters x 32(led) = 441 pixels .....
Of course we want to made 6 lengths of led strip connect together by wiring and powered by an Arduino Mega, could you think we could use only one power supply on the middle of this segments ?
Do you think we are risk to lost RGB power signal between the lengths ?
Warmest regards.
Peter
Very long digital led strip ...
Re: Very long digital led strip ...
You could probably get by with one power supply in the middle of each 2.3 meter segment. You might get a little fading toward the ends. It would be better to feed power from both ends, or V+ to one end and GND to the other.could use only one power supply on the middle of this segments ?
How much wire length is between segments? If it is a meter or more, you may need an extra "repeater" pixel.
- Franklin97355
If this is for a permanent installation I would consider a driver micro at each floor with communications between them and also power at each floor. Could you draw up something to show us your idea?
- peterpan69
Thank's for your quick answers
In attachement little drawing of the idea.
By "driver micro" , you mean an Arduino by floor ?
Peter
Peter
- 6 sens principe.jpg (54.62 KiB) Viewed 330 times
Your diagram does not indicate the length of the wires between floors.
At minimum, you would need to supply power to the center of each segment of strip. Pixels much more than about 1 meter from your power feed will start to dim noticibly. By 2 or 3 meters, they may start to malfunction due to the voltage drop.
Also, yo need to connect your controller to the start of the strip. If you connect to the middle as shown it will only control the pixels downstream from the connection point.
- peterpan69
Ok I estimate the wiring between strip to 0.8 meter.
I have make correction to the drawing with your suggestions; it's really a big disadvantage to put the power on the middle of each segment
May really can connect the same PWN output in parallel on the two way of strips ?
- 6 sens principe.jpg (63.97 KiB) Viewed 323 times
It doesn't have to be the middle. You could connect it at both ends of each segment if that is more convenient. The point is that no pixel on the strip should be too far from a power feed.it's really a big disadvantage to put the power on the middle of each segment
Digital strips are not controlled by a PWM signal. But the control signal can be connected in parallel to two different strips. In this case the two strips will display identical patterns.May really can connect the same PWN output in parallel on the two way of strips ?
- peterpan69
Ok by this way I can put power supply in the ceiling empty zone what are you think by "not to far" ? (in meter)
I think we put the arduino too in the top ceiling and the start of the strip on the top level.
Ok, that exactly what we want the same patterns
hundred of thank's for your ultra fast answers !
(update drawing )
(update drawing )
- 6 sens principe.jpg (44.59 KiB) Viewed 310 times
That depends on how many leds are lit and how bright they are. I try not to go more than about 2 meters without a power feed.what are you think by "not to far" ? (in meter)
