I have made no changes, so for simplicity I am posting the errors I received. I just want to see if the code would compile as it is before I started making changes and it does not.
SMS_Pet_Food_Dish.ino: In function 'void snsPublish(const char*, const char*, long unsigned int)':
SMS_Pet_Food_Dish:192: error: 'DateTime' was not declared in this scope
SMS_Pet_Food_Dish:192: error: expected `;' before 'dt'
SMS_Pet_Food_Dish:195: error: 'dt' was not declared in this scope
Also if I wanted to see the amount of times lets say a dog goes to the bowl to eat, to monitor someone over-feeding what is the set up change for the IR detector, I have looked at the example it has not quite clicked. I have also used a basic FSR for a prototype purposes to detects the change in pressure, of food in the bowl, can that be sent as a alert as well? Thanks and regards...
// Publish a message to an SNS topic.
// Note, both the topic and message strings _MUST_ be URL encoded before calling this function!
void snsPublish(const char* topic, const char* message, unsigned long currentTime) {
// Set dateTime to the URL encoded ISO8601 format string.
DateTime dt(currentTime);
char dateTime[25];
memset(dateTime, 0, 25);
dateTime8601UrlEncoded(dt.year(), dt.month(), dt.day(), dt.hour(), dt.minute(), dt.second(), dateTime);
// Generate the signature for the request.
// For details on the AWS signature process, see:
// http://docs.aws.amazon.com/general/latest/gr/signature-version-2.html
Sha1.initHmac((uint8_t*)AWS_SECRET_ACCESS_KEY, strlen(AWS_SECRET_ACCESS_KEY));
Sha1.print(F("POST\n"));
Sha1.print(AWS_HOST); Sha1.print(F("\n"));
Sha1.print(F("/\n"));
Sha1.print(F("AWSAccessKeyId="));
Sha1.print(AWS_ACCESS_KEY);
Sha1.print(F("&Action=Publish"));
Sha1.print(F("&Message="));
Sha1.print(message);
Sha1.print(F("&SignatureMethod=HmacSHA1"));
Sha1.print(F("&SignatureVersion=2"));
Sha1.print(F("&Timestamp="));
Sha1.print(dateTime);
Sha1.print(F("&TopicArn="));
Sha1.print(topic);
Sha1.print(F("&Version=2010-03-31"));
// Convert signature to base64
// Adapted from Adafruit code for SendTweet example.
uint8_t *in, out, i, j;
char b64[27];
memset(b64, 0, sizeof(b64));
static const char PROGMEM b64chars[] = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789+/";
for(in = Sha1.resultHmac(), out=0; ; in += 3) { // octets to sextets
b64[out++] = in[0] >> 2;
b64[out++] = ((in[0] & 0x03) << 4) | (in[1] >> 4);
if(out >= 26) break;
b64[out++] = ((in[1] & 0x0f) << 2) | (in[2] >> 6);
b64[out++] = in[2] & 0x3f;
b64[out] = (in[1] & 0x0f) << 2;
// Remap sextets to base64 ASCII chars
for(i=0; i<=out; i++) b64[i] = pgm_read_byte(&b64chars[(unsigned char)b64[i]]);
// URL encode base64 signature. Note, this is not a general URL encoding routine!
char b64Encoded[100];
memset(b64Encoded, 0, sizeof(b64Encoded));
for(i=0, j=0; i<=out; i++) {
uint8_t ch = b64[i];
if (ch == '+') {
b64Encoded[j++] = '%';
b64Encoded[j++] = '2';
b64Encoded[j++] = 'B';
else if (ch == '/') {
b64Encoded[j++] = 'F';
else {
b64Encoded[j++] = ch;
b64Encoded[j++] = '3';
b64Encoded[j++] = 'D';
// Make request to SNS API.
uint32_t ip = 0;
while (ip == 0) {
if (!cc3000.getHostByName(AWS_HOST, &ip)) {
Serial.println(F("Couldn't resolve!"));
delay(500);
Adafruit_CC3000_Client www = cc3000.connectTCP(ip, 80);
if (http://www.connected()) {
http://www.fastrprint(F("POST /?"));
http://www.fastrprint(F("AWSAccessKeyId="));
http://www.fastrprint(AWS_ACCESS_KEY);
http://www.fastrprint(F("&Action=Publish"));
http://www.fastrprint(F("&Message="));
http://www.fastrprint(message);
http://www.fastrprint(F("&SignatureMethod=HmacSHA1"));
http://www.fastrprint(F("&SignatureVersion=2"));
http://www.fastrprint(F("&Timestamp="));
http://www.fastrprint(dateTime);
http://www.fastrprint(F("&TopicArn="));
http://www.fastrprint(topic);
http://www.fastrprint(F("&Version=2010-03-31"));
http://www.fastrprint(F("&Signature="));
http://www.fastrprint(b64Encoded);
http://www.fastrprint(F(" HTTP/1.1\r\nHost: "));
http://www.fastrprint(AWS_HOST);
http://www.fastrprint(F("\r\nContent-Length: 0\r\n\r\n"));
else {
Serial.println(F("Connection failed"));
http://www.close();
return;
// Read data until either the connection is closed, or the idle timeout is reached.
Serial.println(F("AWS response:"));
unsigned long lastRead = millis();
while (http://www.connected() && (millis() - lastRead < TIMEOUT_MS)) {
while (http://www.available()) {
char c = http://www.read();
Serial.print(c);
http://www.close();
// Fill a 24 character buffer with the date in URL-encoded ISO8601 format, like '2013-01-01T01%3A01%3A01Z'.
// Buffer MUST be at least 24 characters long!
void dateTime8601UrlEncoded(int year, byte month, byte day, byte hour, byte minute, byte seconds, char* buffer) {
ultoa(year, buffer, 10);
buffer[4] = '-';
btoa2Padded(month, buffer+5, 10);
buffer[7] = '-';
btoa2Padded(day, buffer+8, 10);
buffer[10] = 'T';
btoa2Padded(hour, buffer+11, 10);
buffer[13] = '%';
buffer[14] = '3';
buffer[15] = 'A';
btoa2Padded(minute, buffer+16, 10);
buffer[18] = '%';
buffer[19] = '3';
buffer[20] = 'A';
btoa2Padded(seconds, buffer+21, 10);
buffer[23] = 'Z';
// Print a value from 0-99 to a 2 character 0 padded character buffer.
// Buffer MUST be at least 2 characters long!
void btoa2Padded(uint8_t value, char* buffer, int base) {
if (value < base) {
*buffer = '0';
ultoa(value, buffer+1, base);
else {
ultoa(value, buffer, base);
// getTime function adapted from CC3000 ntpTest sketch.
// Minimalist time server query; adapted from Adafruit Gutenbird sketch,
// which in turn has roots in Arduino UdpNTPClient tutorial.
unsigned long getTime(void) {
Adafruit_CC3000_Client client;
uint8_t buf[48];
unsigned long ip, startTime, t = 0L;
// Hostname to IP lookup; use NTP pool (rotates through servers)
if(cc3000.getHostByName("pool.ntp.org", &ip)) {
timeReqA[] = { 227, 0, 6, 236 },
timeReqB[] = { 49, 78, 49, 52 };
startTime = millis();
do {
client = cc3000.connectUDP(ip, 123);
} while((!client.connected()) &&
((millis() - startTime) < TIMEOUT_MS));
if(client.connected()) {
// Assemble and issue request packet
memset(buf, 0, sizeof(buf));
memcpy_P( buf , timeReqA, sizeof(timeReqA));
memcpy_P(&buf[12], timeReqB, sizeof(timeReqB));
client.write(buf, sizeof(buf));
while((!client.available()) &&
if(client.available()) {
client.read(buf, sizeof(buf));
t = (((unsigned long)buf[40] << 24) |
((unsigned long)buf[41] << 16) |
((unsigned long)buf[42] << 8) |
(unsigned long)buf[43]) - 2208988800UL;
client.close();
return t;
