Arduino and servo control
by slurry bowl on Tue Feb 18, 2014 11:42 pm
Hello Adafruit Arduino community.
I am attempting to change the speed that my servo sweeps. from slowly going 180 one way then one 180 the other to fast, then faster, but still ........relatively slow, the fastest rotation being 4 seconds to complete one 180 sweep.
I am using the microseconds servo code.
I want to control the speed with a potentiometer. I can not get it to work and would appreciate any help.
Here is my code, any help THANK YOU :D :D 8)
#include <Servo.h>
const int analogInPin = A0;
int sensorValue = 0;
int j;
int outputValue = 0;
Servo myservo;
int pos = 0;
void setup()
  Serial.begin(9600);
  myservo.attach(9);
  myservo.writeMicroseconds(1600);  // set servo to mid-point
  sensorValue = analogRead(analogInPin);
  outputValue = map(sensorValue, 1023, 0, 1, 10);
  outputValue = j;
  Serial.print("sensorValue = " );
  Serial.println(sensorValue);
for(pos = 700; pos < 2300; pos += (j))  // goes from 0 degrees to 180 degrees
  {                                  // in steps of 1 degree
    myservo.writeMicroseconds(pos);              // tell servo to go to position in variable 'pos'
    delay(20);                       // waits 15ms for the servo to reach the position
  for(pos = 2300; pos>=700; pos-=(j))     // goes from 180 degrees to 0 degrees
    delay(20);
 delay(2);
slurry bowl
Re: Arduino and servo control
by franklin97355 on Wed Feb 19, 2014 1:26 am
Not reading all your code but
 outputValue = j;
shouldn't this be j = outputValue; ?
franklin97355
by slurry bowl on Thu Feb 20, 2014 1:18 am
yup so simple !
thanks.
Is there a way to have the code check the pot. reading at the end of each 180 turn?
Now it only checks at the end of a full back/forth..
:o
slurry bowl
by adafruit_support_bill on Thu Feb 20, 2014 7:54 am
Sure. Just take the code that you have before the first "for' loop, and replicate it before the second 'for' loop:
  outputValue = j;
  outputValue = j;
    delay(20);
 delay(2);
by slurry bowl on Sat Mar 15, 2014 6:58 pm
thanks for all the help.
I am currently running two servos off the same pin and everything is working great.
If I wanted the servos to rotate in opposite directions, how would I adjust the code to use a second output pin so that each servo would have its own pin.
here is the current code:
#include <Servo.h>
int j;
Servo myservo;
int pos = 0;
void setup()
  Serial.begin(9600);
  myservo.attach(9);
  j = outputValue;
  outputValue = j;
    delay(20);
 delay(2);
slurry bowl
by slurry bowl on Sat Mar 15, 2014 7:25 pm
How would I run two servos using this code that rotate in the opposite direction? On separate pins. Ive tried a few different ideas and nothing seems to work. the servos just freeze.
Here is current working code:
#include <Servo.h>
int j;
Servo myservo;
int pos = 0;
void setup()
  Serial.begin(9600);
  myservo.attach(9);
  j = outputValue;
  outputValue = j;
    delay(20);
 delay(2);
slurry bowl
by adafruit_support_bill on Sun Mar 16, 2014 7:06 am
It is easier if you use myservo.write() instead of myservo.writemicroseconds().
Using write() you specify directly in degrees. To have two servos moving in opposite directions you would do:
servo1.write(angle);
servo2.write(180 - angle);
