Hello
I am working on a project where I will have 12 force sensitive resistors (like these: http://www.adafruit.com/products/166). I am using a MPC23017 "port expander" to connect all these to my Uno. I am using the Adafruit MPC23017 library to communicate with the sensors -- via digitalRead. This returns a 0 or 1 (of course). There is no analogRead in the Adafruit library. Is there a way to get an analog value from the sensor? And... at what point does "no pressure" (i.e., a reading of 0) turn into "yes pressure" (i.e., a reading of 1)? Is there a way to fine-tune that if I must use the digitalRead function in absence of an analogRead function?
MPC23017 analogRead???
- adafruit_support_rick
Re: MPC23017 analogRead???
There is no defined point at which a 0 becomes a 1. It will vary across individual parts.
You should be using an ADC instead of an MCP23017. The MCP23017 is strictly a digital part - it has no analog input capability.
ADCs:
8-channel SPI: http://www.adafruit.com/products/856
4-channel I2C: http://www.adafruit.com/products/1083
ADCs:
