How to get accurate time???
Re: How to get accurate time???
any ideas on why its not getting values???
- tatanka
Well, I am not sure. I have an Ultimate GPS attached to an Arduino Pro Mini. I have it connected as such:
GPS Arduino
Vin 5V
GND GND
RX D2
TX D3
I have the parsing sketch going, I am inside so no actual GPS data but I am getting a Serial response. See attached pic. I have my serial monitor set to 115200 baud.
I think maybe one of the adafruit guys might need to step in.
T
GPS Arduino
Vin 5V
GND GND
RX D2
TX D3
T
- GPS Test.jpg (53.26 KiB) Viewed 356 times
i get something the serial read out but i get
Time: 0 : 0 : 00.000
Date: 0/0/2000
Fix: 0 quality 0
Date: 0/0/2000
Fix: 0 quality 0
- tatanka
Well, time to get down and dirty then, follow the instructions here:
https://learn.adafruit.com/adafruit-ult ... ter-wiring
The biggest difference is AFTER loading the 'blank' sketch, change the wiring to pins 0 and 1 per the instructions. Send some pictures of your setup and serial monitor if you can.
Tim
Tim
I'm not using the breakout board. .. I have the shield....
- tatanka
- tatanka
Okay, reading through the info for the shield, they use pins 7 and 8 for the serial connection. So change the code:
Try that in the parsing sketch first and see if it works then.
Tim
SoftwareSerial mySerial(3, 2);
to this:
SoftwareSerial mySerial(8, 7);
Tim
After reading that...... Parsing and echo work... however, i still cant figure out what is keeping my code from collecting the time...
#include <SPI.h>
#include <Adafruit_GPS.h>
#include <SoftwareSerial.h>
#include <SD.h>
#include <string.h>
#include <ccspi.h>
SoftwareSerial mySerial(8,7);
Adafruit_GPS GPS(&mySerial);
#define GPSECHO true
int interval = 1000;
float S1=0;
float S2=0;
float S3=0;
float S4=0;
unsigned long previousMillis=0;
unsigned int reading=0;
File logfile;
void setup(){
Serial.begin(115200);
GPS.begin(9600);
delay(1000);
Serial.println("Hello!!! Let's begin science");
GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ);
GPS.sendCommand(PGCMD_ANTENNA);
delay(2000);
mySerial.println(PMTK_Q_RELEASE);
char c=GPS.read();
#ifdef UDRO
if (GPSECHO)
if (c) UDRO=c;
#endif
Serial.println(c);
int n=0;
/*while(n==0){
if(GPS.hour==0){
Serial.println("Waiting on satalite");
c=GPS.read();
Serial.println(GPS.hour);
Serial.println(GPS.hour,DEC);
delay(5000);
}else{
n=1;
//Serial.print("Finding the SD Card....");
pinMode(10,OUTPUT);
delay(1000);
//if (!SD.begin(10)) {
//Serial.println("Couldn't find it..... Sorry.");
//return;
//Serial.println("FOUNTD IT!!!! Lets start recording.");
Serial.print("\nTime: ");
Serial.print(GPS.hour, DEC); Serial.print(':');
Serial.print(GPS.minute, DEC); Serial.print(':');
Serial.print(GPS.seconds, DEC); Serial.print('.');
Serial.println(GPS.milliseconds);
Serial.print("Date: ");
Serial.print(GPS.day, DEC); Serial.print('/');
Serial.print(GPS.month, DEC); Serial.print("/20");
Serial.println(GPS.year, DEC);
Serial.print("Reading");
Serial.print(",");
Serial.print("Time");
Serial.print(",");
Serial.print("A0");
Serial.print(",");
Serial.print("A1");
Serial.print(",");
Serial.print("A2");
Serial.print(",");
Serial.println("A3");
/*File dataFile=SD.open("timetes1.txt",FILE_WRITE);
if (dataFile){
dataFile.print("Reading");
dataFile.print(",");
dataFile.print("Time");
dataFile.print("A0");
dataFile.print("A1");
dataFile.print("A2");
dataFile.print("A3");
dataFile.println(starttime);
dataFile.close();
unsigned long currentMillis = millis();
if ((unsigned long)(currentMillis-previousMillis)>=interval) {
S1=analogRead(0)*2.4437927;
S2=analogRead(1);
S3=analogRead(2);
S4=analogRead(3);
reading=reading+1;
Serial.print(reading);
Serial.print(",");
Serial.print(currentMillis);
Serial.print(",");
Serial.print(S1);
Serial.print(",");
Serial.print(S2);
Serial.print(",");
Serial.print(S3);
Serial.print(",");
Serial.println(S4);
if(dataFile){
dataFile.print(reading);
dataFile.print(currentMillis);
dataFile.print(S1);
dataFile.print(S2);
dataFile.print(S3);
dataFile.println(S4);
dataFile.close();
previousMillis=currentMillis;
- adafruit_support_rick
You have the code which reads the GPS located in the setup() function, where it will only be executed once.
Once you get to loop(), you will never read the GPS again.
Beyond that, you aren't calling GPS.parse(), so you will never extract the timestamp from the GPS data.
If I were you, I would start over with a fresh copy of the parsing example sketch. Add your sensor readings to that, without disturbing the GPS code.
char c=GPS.read();
#ifdef UDRO
if (GPSECHO)
if (c) UDRO=c;
#endif
Serial.println(c);
I only want to call the gps to get the data and time of when the log is created....
well i have figured somethings out and have what i want working.... however, my time jumps every once and a while.... does anything jump out that screams dont do that, that slows everything down???
#include <Adafruit_GPS.h> //Call Libraries
#include<SPI.h>
#include<SD.h>
SoftwareSerial mySerial(8, 7); //Set pins on GPS unit
File logfile;
uint32_t timer = millis();
int n=0;
void setup()
Serial.println("Hello. Let' start the test.");
GPS.begin(9600);
pinMode(10,OUTPUT);
if(!SD.begin(10)){
Serial.println("SD card not found... Ending program.");
return;
delay(1000);
while(n==0){
char c = GPS.read();
if (GPS.newNMEAreceived()) {
if (!GPS.parse(GPS.lastNMEA()))
n=0;
if (millis() - timer > 2000) {
timer = millis(); // reset the timer
if(GPS.hour!=0 && GPS.day!=0){
Serial.println("Let us get started...");
File dataFile=SD.open("Log02.txt",FILE_WRITE);
if(dataFile){
dataFile.print("\nTime: ");
dataFile.print(GPS.hour, DEC); dataFile.print(':');
dataFile.print(GPS.minute, DEC); dataFile.print(':');
dataFile.print(GPS.seconds, DEC); dataFile.print('.');
dataFile.println(GPS.milliseconds);
dataFile.print("Date: ");
dataFile.print(GPS.day, DEC); dataFile.print('/');
dataFile.print(GPS.month, DEC); dataFile.print("/20");
dataFile.println(GPS.year, DEC);
dataFile.println("Reading,Time,Sensor1,Sensor2,Sensor3,Sensor4");
dataFile.close();
Serial.println("Begin");
n=5;
int S1=0;
int S2=0;
int S3=0;
int S4=0;
void loop(){
if(n==5){
if(millis()-timer>=50){
timer=millis();
S1=analogRead(0);
S2=analogRead(1);
S3=analogRead(2);
S4=analogRead(3);
reading=reading+1;
if(dataFile){
dataFile.print(timer);
dataFile.print(S1);
dataFile.print(S2);
dataFile.print(S3);
dataFile.close();}
Only thing I can suggest is to open the data file once, in setup, instead of every time through loop():
#include<SPI.h>
#include<SD.h>
File dataFile;
int n=0;
void setup()
GPS.begin(9600);
pinMode(10,OUTPUT);
if(!SD.begin(10)){
return;
delay(1000);
while(n==0){
n=0;
if(dataFile){
dataFile.close();
if(dataFile)
n=5;
int S1=0;
int S2=0;
int S3=0;
int S4=0;
void loop(){
if(n==5){
timer=millis();
S1=analogRead(0);
S2=analogRead(1);
S3=analogRead(2);
S4=analogRead(3);
reading=reading+1;
dataFile.print(S1);
dataFile.print(S2);
dataFile.print(S3);
dataFile.flush();
What happens when power is shut off? ??
I put a dataFile.flush() at the end of your loop. That should ensure that all the current data is written to the file at end of the loop.
so what is the difference form dataFile.close() and dataFile.flush()? Is it just something that will be more efficient when writing so many times a second?
A flush and a close are two different events.
Device drivers don't always write data to the physical media when you send them a write() command. It's more efficient (and often better for the device) to write data in blocks of a specific size. The device driver manages that by keeping a buffer of data it's been told to write to the file, but only writing when the buffer size reaches a certain limit.
A flush tells the driver "no, really.. write the data to the physical medium. I want your buffer to be empty before anything else happens." A close disposes of the data structures used to represent the file in the program's address space. Closing a file might force a flush, but that's not guaranteed. There are cases where it's better to stop immediately and abandon any data that's still hanging around in the buffer.
