When I try to upload my sketch I get the following error message
Binary sketch size: 12,218 bytes (of a 32,256 byte maximum)
avrdude: stk500_getsync(): not in sync: resp=0x00
Did I ruin the whole board, the chip or something else do you think.
If so does ADA check board for damage, is it worth the $$ and if so what is the procedure to have a board checked ?
Error message Did I damage my UNO
Re: Error message Did I damage my UNO
What serial port have you selected for communication with the Arduino?
- mjpcarbon
Com 8 which is recognized but doesnt complete the upload and gives the error only with one of my many UNOs
If it's only happening for one Arduino, that's probably a sign of something wrong in that device.
It could be something as simple as a corrupted bootloader though. If you have multiple Unos, you can use one to write a new bootloader onto the one that's misbehaving: http://arduino.cc/en/Tutorial/ArduinoISP
- mjpcarbon
Kool ! I will give that a try tonight.
One quick question I am going UNO to UNO do I have to make the following sketch mod ?
Note for Arduino 1.0: you need to make one small change to the ArduinoISP code. Find the line in the heartbeat() function that says "delay(40);" and change it to "delay(20);".
Probably. In all honesty, I have enough flavors of programmer that I haven't done an ArduinoISP project since before the Uno came out.
I'm pretty sure that line is just a timing parameter though, so the worst case of getting the wrong value should just be a "got no response" message.
- mjpcarbon
Orrrr maybe not so easy
avrdude: usbdev_open(): did not find any USB device "usb"
do you think shes a cooked ?
Hmm.. that may be a dead ATmega16u2 (the USB interface). That's significantly harder to fix.
Try swapping ATmega328s between the Arduino that isn't working and one that does. That should give us a better idea of where the problem lives.
- mjpcarbon
I swapped the chip and the board is fine so I will replace the chip with my next order
Well, of parts to replace, that's the easiest and least expensive. Good luck with the new one.
- mjpcarbon
thank you again and again .....
