7 seg i2c lcd
carlswanson60
7 seg i2c lcd
Post by carlswanson60 »
How and where do I code the brightness for this lcd? I found some examples but can't get it to work.
Re: 7 seg i2c lcd
Can you post a link to the specific display you are asking about?
carlswanson60
Re: 7 seg i2c lcd
I am trying to use your project for displaying temp and time, I don't want to use a switch and would like the script to just automatically display temp delay and then time.
Please be kind to me and show me how to do it within the script.
Large 7 seg lcd Pi-based Thermometer and Time
This project combines a whole heap of modules to enable a Raspberry Pi to power a large 1.2 inch 4 digit 7 segment display. A small switch switches the display between showing the temperature and the current time
Your help would be appreciated.
Thanks, Carl Swanson
Re: 7 seg i2c lcd
To alternate between time and temperature, change the main part of the program loop to:
while True:
        segment.clear()
        display_temp()
        segment.write_display()
        time.sleep(1.0)
        segment.clear()
        display_time()
        time.sleep(1.0)
carlswanson60
Re: 7 seg i2c lcd
Thank you very much!
carlswanson60
Re: 7 seg i2c lcd
Got that figured out, now new problem, timestamp within PIR program is not incrementing, prints the same number each time.
#!/usr/bin/python
import time
import RPi.GPIO as GPIO
import os
import datetime
from datetime import datetime, timedelta
t = datetime.now() + timedelta(seconds=3000)
print(t)
GPIO.setmode(GPIO.BCM)
#GPIO.setwarnings(False)
led1 = 21
pirPin = 17
GPIO.setup(led1,GPIO.OUT)
GPIO.setup(pirPin, GPIO.IN)
print t
def LIGHTS(pirPin):
    """Turns LEDS On and Off"""
    print(t)
    print("Lights on")
    GPIO.output(led1,GPIO.HIGH)
    time.sleep(7)
    print("Light off")
    GPIO.output(led1,GPIO.LOW)
print("Motion Sensor Alarm (CTRL+C to exit)")
time.sleep(.2)
print("Ready")
print t
try:
    GPIO.add_event_detect(pirPin, GPIO.RISING, callback=LIGHTS)
    while 1:
        time.sleep(1)
except KeyboardInterrupt:
    print("Quit")
    GPIO.cleanup()
Last edited by adafruit_support_bill on Tue Jun 18, 2019 4:12 pm, edited 1 time in total.
Reason: please use [code] tags when posting code to the forums
carlswanson60
Re: 7 seg i2c lcd
#!/usr/bin/python
import time
import os
import datetime
print(t)
led1 = 21
pirPin = 17
print t
def LIGHTS(pirPin):
print(t)
print("Lights on")
time.sleep(7)
print("Light off")
time.sleep(.2)
print("Ready")
print t
try:
while 1:
time.sleep(1)
print("Quit")
GPIO.cleanup()
Return to “Arduino”
