Trinket Help
SPOD
Trinket Help
Post by SPOD »
I have purchased a trinket 3v from one of your distributors and I am having a hard time programming it.
I use Windows 8.1 and I was following the trinket tutorial "Setting up with Arduino IDE." I chose the fast way by downloading the trinket compatible Arduino IDE for windows. When I attempt the blink program I still get the large stream of errors, as per your help page. I have also installed the driver for the trinket.
Please help. Thank you for your time.
adafruit_support_rick
Re: Trinket Help
Post by adafruit_support_rick »
Please post the errors you're getting. You should be able to copy and paste from the error window.
SPOD
Re: Trinket Help
Post by SPOD »
The errors are as follows plus a whole lot more:
avrdude: error: usbtiny_receive: usb_control_msg: sending control message failed, win error: The device does not recognize the command.
(expected 4, got -5)
Re: Trinket Help
Please see this item in the Trinket FAQ:
https://learn.adafruit.com/introducing- ... /faq#faq-3
SPOD
Re: Trinket Help
Post by SPOD »
I only followed the advice of the article and edit the following:
chip_erase_delay = 900000;
under the ATtiny85 heading to
chip_erase_delay = 400000;
Now I only have this error appear:
Binary sketch size: 832 bytes (of a 5,310 byte maximum)
avrdude: error: usbtiny_receive: usb_control_msg: sending control message failed, win error: A device attached to the system is not functioning.
Re: Trinket Help
Sometime we see that error, but the download still succeeds.
Does your sketch work after the download? If so, you can ignore the error.
If not, try a different USB cable, try a different USB port, and/or try connecting the trinket through a self-powered USB hub.
SPOD
Re: Trinket Help
Post by SPOD »
Yes, I tried a different USB, 2.0 instead of 3.0, and the program is downloading.
I still get the error, but it works.
Thank you very much for your help.
Return to “Arduino”
