My mac runs 10.9.2 and I routinely program Trinkets from it.
In the Arduino IDE's preferences, click the option for "verbose output" from avrdude. Let's make sure it's using the config file you edited.
Trinket - Can't download. Mac OSX 10.9.2
- michael_lloyd
Re: Trinket - Can't download. Mac OSX 10.9.2
/Applications/Adafruit Arduino 1.0.5.app/Contents/Resources/Java/hardware/tools/avr/bin/avrdude -C/Applications/Adafruit Arduino 1.0.5.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf -v -v -v -v -pattiny85 -cusbtiny -Uflash:w:/var/folders/tw/9plnkg1163sgb9xzbtypqsrw0000gn/T/build7113444700062656203.tmp/Trinket_SpaceInvader.cpp.hex:i
avrdude: Version 5.11, compiled on Sep 2 2011 at 18:52:52
Copyright (c) 2000-2005 Brian Dean, http://www.bdmicro.com/
Copyright (c) 2007-2009 Joerg Wunsch
System wide configuration file is "/Applications/Adafruit Arduino 1.0.5.app/Contents/Resources/Java/hardware/tools/avr/etc/avrdude.conf"
User configuration file is "/Users/mikell/.avrduderc"
User configuration file does not exist or is not a regular file, skipping
Using Port : unknown
Using Programmer : usbtiny
avrdude: usbdev_open(): Found USBtinyISP, bus:device: 003:002-1781-0c9f-ff-00
AVR Part : ATtiny85
Chip Erase delay : 400000 us
PAGEL : P00
BS2 : P00
RESET disposition : possible i/o
RETRY pulse : SCK
serial program mode : yes
parallel program mode : yes
Timeout : 200
StabDelay : 100
CmdexeDelay : 25
SyncLoops : 32
ByteDelay : 0
PollIndex : 3
PollValue : 0x53
Memory Detail :
Block Poll Page Polled
Memory Type Mode Delay Size Indx Paged Size Size #Pages MinW MaxW ReadBack
eeprom 65 12 4 0 no 512 4 0 4000 4500 0xff 0xff
flash 65 6 32 0 yes 8192 64 128 30000 30000 0xff 0xff
signature 0 0 0 0 no 3 0 0 0 0 0x00 0x00
lock 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
lfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
hfuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
efuse 0 0 0 0 no 1 0 0 9000 9000 0x00 0x00
calibration 0 0 0 0 no 2 0 0 0 0 0x00 0x00
Programmer Type : USBtiny
Description : USBtiny simple USB programmer, http://www.ladyada.net/make/usbtinyisp/
avrdude: programmer operation not supported
avrdude: Using SCK period of 10 usec
CMD: [ac 53 00 00] [00 00 53 00]
avrdude: AVR device initialized and ready to accept instructions
Reading | CMD: [30 00 00 00] [00 00 00 1e]
CMD: [30 00 01 00] [00 00 00 93]
################CMD: [30 00 02 00] [00 00 00 0b]
################################## | 100% 0.01s
avrdude: Device signature = 0x1e930b
avrdude: NOTE: FLASH memory has been specified, an erase cycle will be performed
To disable this feature, specify the -D option.
CMD: [a0 01 fc 00] [00 00 01 00]
CMD: [a0 01 fd 00] [00 00 01 00]
CMD: [a0 01 fe 00] [00 00 01 00]
CMD: [a0 01 ff 00] [00 00 01 00]
avrdude: erasing chip
avrdude: error: usbtiny_receive: usb_control_msg(DeviceRequestTO): unknown error (expected 4, got -1)
avrdude: 10 retries during SPI command
avrdude: reading input file "/var/folders/tw/9plnkg1163sgb9xzbtypqsrw0000gn/T/build7113444700062656203.tmp/Trinket_SpaceInvader.cpp.hex"
avrdude: writing flash (1866 bytes):
Writing | CMD: [4c 00 00 00] [00 00 00 00]
#avrdude: 1 retries during SPI command
CMD: [4c 00 20 00] [00 00 00 00]
##avrdude: 1 retries during SPI command
CMD: [4c 00 40 00] [00 00 00 00]
CMD: [4c 00 60 00] [00 00 00 00]
CMD: [4c 00 80 00] [00 00 00 00]
CMD: [4c 00 a0 00] [00 00 00 00]
CMD: [4c 00 c0 00] [00 00 00 00]
CMD: [4c 00 e0 00] [00 00 00 00]
CMD: [4c 01 00 00] [00 00 01 00]
CMD: [4c 01 20 00] [00 00 01 00]
CMD: [4c 01 40 00] [00 00 01 00]
CMD: [4c 01 60 00] [00 00 01 00]
CMD: [4c 01 80 00] [00 00 01 00]
CMD: [4c 01 a0 00] [00 00 01 00]
CMD: [4c 01 c0 00] [00 00 01 00]
CMD: [4c 01 e0 00] [00 00 01 00]
CMD: [4c 02 00 00] [00 00 02 00]
CMD: [4c 02 20 00] [00 00 02 00]
CMD: [4c 02 40 00] [00 00 02 00]
CMD: [4c 02 60 00] [00 00 02 00]
CMD: [4c 02 80 00] [00 00 02 00]
CMD: [4c 02 a0 00] [00 00 02 00]
CMD: [4c 02 c0 00] [00 00 02 00]
CMD: [4c 02 e0 00] [00 00 02 00]
CMD: [4c 03 00 00] [00 00 03 00]
CMD: [4c 03 20 00] [00 00 03 00]
CMD: [4c 03 40 00] [00 00 03 00]
CMD: [4c 03 60 00] [00 00 03 00]
CMD: [4c 03 80 00] [00 00 03 00]
CMD: [4c 03 a0 00] [00 00 03 00]
# | 100% 1.53s
avrdude: 1866 bytes of flash written
avrdude: verifying flash memory against /var/folders/tw/9plnkg1163sgb9xzbtypqsrw0000gn/T/build7113444700062656203.tmp/Trinket_SpaceInvader.cpp.hex:
avrdude: load data flash data from input file /var/folders/tw/9plnkg1163sgb9xzbtypqsrw0000gn/T/build7113444700062656203.tmp/Trinket_SpaceInvader.cpp.hex:
avrdude: input file /var/folders/tw/9plnkg1163sgb9xzbtypqsrw0000gn/T/build7113444700062656203.tmp/Trinket_SpaceInvader.cpp.hex contains 1866 bytes
avrdude: reading on-chip flash data:
Reading | ################################################## | 100% 0.28s
avrdude: verifying ...
avrdude: 1866 bytes of flash verified
avrdude done. Thank you.
That sounds like a timing issue. Having to produce more output slowed avrdude down enough to keep the Trinket's ATtiny85 happy.
If you're willing to live with that as a working solution, running verbose shouldn't cause any new problems.
- michael_lloyd
It works so I think I can live with it :o)
Thanks for hanging in there.
- CamWow
I found this post after doing some research when my Trinket started acting up. I had installed the trinket in one of my projects and wanted to reprogram it. I'm on a Mac as well and was getting some of the same error messages when uploading to the Trinket. After trying a few things I noticed something that was mentioned in the Introducing Trinket tutorial in reference to GPIO pins #3 and #4.
"We didn't want to keep these pins off the board but we strongly recommend not using them unless you're sure you need them since you might have to disconnect any connections to reprogram the Trinket!"
I had these pins connected and as a result could not upload to the Trinket. Disconnecting these pins solved my problem. It was a mistake on my part forgetting that connecting these pins may cause problems when uploading.
- jagalbraith
To simpify this thread here are instructions. I tested this on OS X 10.10.4.
Trinket programming on the Mac:
It will NOT show up in your network connections as a USB device like other Arduino. Trinkets have a built in programmer. Follow these steps to upload your sketch:
1. Write your sketch.
2. Pick your Trinket model in the board list.
3. Set programmer to USBtinyISP
4. Press the reset button on the Trinket.
5. Press the upload button on your Arduino IDE window.
Done and done.
Done and done.
- keshishiana
Hello Please point out what am I doing wrong!
El Capitan 10.11.2
Arduino 1.6.7
Trinket 3v.
I can not load the program because it does not see the serial port- when I switch my board to an UNO, then I see the port and able to load.
This is the error massage I get"
Arduino: 1.6.7 (Mac OS X), Board: "Arduino/Genuino Uno"
Sketch uses 1,112 bytes (3%) of program storage space. Maximum is 32,256 bytes.
Global variables use 13 bytes (0%) of dynamic memory, leaving 2,035 bytes for local variables. Maximum is 2,048 bytes.
avrdude: ser_open(): can't open device "/dev/cu.usbmodemFA131": No such file or directory
ioctl("TIOCMGET"): Inappropriate ioctl for device
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
enabled in File > Preferences.
I have uninstalled and reinstalled Ardunio,
Followed the instructions below:
http://arduino.stackexchange.com/questi ... for-uno-r3
Thank you
El Capitan 10.11.2
Arduino 1.6.7
Trinket 3v.
Thank you
- Attachments
- Screen Shot 2016-01-07 at 9.27.40 PM.png (56.71 KiB) Viewed 1766 times
- Screen Shot 2016-01-07 at 9.27.13 PM.png (57.71 KiB) Viewed 1766 times
Drop back to version 1.6.5 of the Arduino IDE. Versions 1.6.6 and 1.6.7 contain changes that have caused all sorts of trouble.
- keshishiana
Still the same problem- not showing or giving the option for a serial port.
- Attachments
- Screen Shot 2016-01-08 at 11.55.15 PM.png (63.37 KiB) Viewed 1749 times
- Screen Shot 2016-01-08 at 11.55.08 PM.png (59.16 KiB) Viewed 1749 times
- Screen Shot 2016-01-08 at 11.54.54 PM.png (50.43 KiB) Viewed 1749 times
The Trinket doesn't register a serial port.
Take a look at the tutorial for information on programming the Trinket from the Arduino IDE: https://learn.adafruit.com/introducing- ... troduction
- keshishiana
Thank you for your help- I am clearly missing something- I have looked over that page numerous times.
This is the error that I get.
avrdude: ser_open(): can't open device "/dev/cu.usbmodemFD121": No such file or directory
thank you
thank you
- michael_lloyd
USB bootloader with a nice LED indicator looks just like a USBtinyISP so you can program it with AVRdude (with a simple config modification) and/or the Arduino IDE (with a few simple config modifications)
Reset button for entering the bootloader or restarting the program. No need to unplug/replug the board every time you want to reset or update!
- keshishiana
Thank you for the help- and now this error-
avrdude: Expected signature for ATmega328P is 1E 95 0F
Double check chip, or use -F to override this check.
Wrong microcontroller found. Did you select the right board from the Tools > Board menu?
- Attachments
- Screen Shot 2016-01-09 at 4.54.12 PM.png (49.49 KiB) Viewed 1668 times
- michael_lloyd
You have selected the wrong board.
It's a Trinket not an Uno
- keshishiana
There is no option for trinket -
- Attachments
- Screen Shot 2016-01-09 at 5.22.34 PM.png (102.61 KiB) Viewed 986 times
