Thanks for putting together an excellent Data and Light shield (product ID 1141). The tutorial works great for SD card and test code for the light and temperature sensors work great. Unfortunately the Wire.h is missing from the Arduino IDE and downloading from GITHUB does not seem to be an option. How do we get access to the "Wire.h" ZIP file to add to our Arduino IDE?
Many Thanks!
Dimos Katsis
need help with the temperature and light shield
- katsisdc
- adafruit_support_bill
Re: need help with the temperature and light shield
What version of the IDE are you using? The Wire Library is included in the current 1.0.5-r2 download.
- katsisdc
I am not sure, i think it is 1.0.5 but It was downloaded recently. In any case, is it just me or is it only possible to view the repository of Wire.h in GITHUB? I would not have a problem with downloading the libraries as needed but this seems harder than it looks.
You can view the wire sources here:
https://github.com/arduino/Arduino/tree ... aries/Wire
- katsisdc
Thanks! getting Wire.h worked!
