Hello! The codes below is what I want to happen. But before that, I need first to set a passcode by pressing buttons.
for example my passcode would be switches 1,4 and 3. Then it will proceed to run the below codes. If I entered incorrect password (132), then all LED's will on then off. Then I can try another passcode. It has 6 switches, 1 for reset and 8 LED's.
Please help me on the codes :D
Thanks a lot!
int timer = 100;
int ledPins[] = {
13,12,11, 10, 9, 8, 7, 6};
int pinCount = 8;
for (int thisPin = 0; thisPin < pinCount; thisPin++) {
pinMode(ledPins[thisPin], OUTPUT);
if (buttonState == HIGH) {
digitalWrite(ledPin, LOW);
digitalWrite(ledPins[thisPin], HIGH);
delay(timer);
digitalWrite(ledPins[thisPin], LOW);
for (int thisPin = pinCount - 1; thisPin >= 0; thisPin--) {
delay(timer);
press PASSCODE then proceed to program
- Untitledfd.png (45.87 KiB) Viewed 285 times
Re: press 3 random buttons then proceed to program
Is that what it does, or is that what you want it to do?When you press any 3 random buttons(like a go signal), it will then proceed to the main program like on assembly language.
If you can explain exactly what works and what does not work, we might be able to help.
adafruit_support_bill wrote:Is that what it does, or is that what you want it to do?When you press any 3 random buttons(like a go signal), it will then proceed to the main program like on assembly language.
It is what I want to do.
1. Press any 3 random buttons. Then 3 LED's will be HIGH
2. All Led's will on, rotating from left to right.
That's all. I'm having difficulty of how will I program the buttons.
Please help me :D
THANKS!
Lesson 6 covers wiring and programming for digital inputs like pushbuttons: https://learn.adafruit.com/adafruit-ard ... tal-inputsI'm having difficulty of how will I program the buttons.
