Hey folks,
I am trying to get the snapshot example sketch working with the TTL serial camera and an Arduino uno.
The cardinfo sketch shows the sd card and partition fine.
The snapshot sketch says it finds camera, then takes photo and takes a few seconds to save it.
However 9/10 times the images saved on the SD card are corrupted/incomplete. Only twice has it successfully saved the images - and both times nothing different (wiring, pinouts etc) was changed.
I was under the impression that the example snapshot sketch was updated to use 32 bit chunks instead of 64 which was at first causing the issue – so this shouldn't still be the problem?
Any ideas would be appreciated,
TTL Camera - Corrupted Image Files
Re: TTL Camera - Corrupted Image Files
Smaller data blocks makes it less susceptible (but not completely immune) to data dropouts due to noise or intermittent connections. Post a photo of how you have it all connected.
I suspect that wires that are too long between the Arduino and SD card reader could be causing this?
Hard to say without seeing it. But long jumpers do tend to be more susceptible to noise.
Yeah, i am using standard dupont cables - so they are approx 20cm i guess.
In ideal conditions, 20cm should be workable. But breadboarded circuits are seldom ideal. There are so many opportunities for signal degradation and noise.
Make sure that all your jumper pins are firmly gripped by the spring contacts. Sometimes on well-used boards, it helps to move the circuit to a different section of the breadboard.
Thanks for the info. It is a relatively new breadboard and connections seem tight. What troubles me is that it worked fine for two photos, in amongst many photos that did not work.
That is consistent with one or more intermittent connections or noise. If you post a photo of your setup we'll look for any potential problem spots.What troubles me is that it worked fine for two photos, in amongst many photos that did not work.
I have shortened the SD card reader wires, but i still get corrupted image files (images appear as blank).
I have attached some images of the wiring.
I really need to get this camera working soon.
Watch out for those wire-splices. They look awfully close together and in danger of shorting out.
We need to figure out if the data corruption is happening on the camera side or the SD card side. Have you tested the camera using the COMM Tool? https://learn.adafruit.com/ttl-serial-c ... -comm-tool
Yeah i know about the splices - don't worry i wont finish the project with them like that! Just temporary to test with the wires shorter.
I guess i will have to dig out my usb to ftdi converter and try comm tool. Will post back...
I have tried using commtool.
The camera seems to work fine, taking snapshots and reading the images off to save them.
So the problem must be when the arduino tries to save the photos on the sd card.
Any thoughts?
Any thoughts?
I re-soldered the connections on the camera and it appears to be much more reliable now.
Could you tell me whats the best way to call a photo to be taken by modifying the example sketch provided.
I guess it would need to be in the loop section of the program if if i want each time an event occurs to take a photo?
If i call "cam.takePicture" does that take a photo?
cam.takePicture() is the call to take a photo. You would put that into your event loop.
Ok, thanks.
But i would need all the other functions after it as well in the event loop? Such as create image, name image, open sd card, close sd card write etc?
