Im following step by step the Make a Guggenhat Project.
So I'm at the Dry Run Stage and have come to a bump in the road. First off Soldering is done, got the libraries downloaded and put it the proper folders.
When I powered the micro from the start the Blue light on the bottom of the board lights up and so does the RX light. Not sure if that means anything???
Then I had trouble getting the Micro to be a visible com port when choosing Tools>Serial Port>Usb
I read online that the serial port on the micro is virtual and if need you can hold the rest button on the micro making the port visible and then to hold it until uploading appears, then release and the sketch will upload RX light blinks . It does seem to work the upload finishes and says done uploading.
Then the RX light goes out for a few seconds and then comes on solid again and the com port disappears.
According to the steps in the Project Guide I should be seeing a blinking green light and then a faster blinking green light. No such luck.
Any help would be welcomed. Im new to Arduino but have worked with several SCADA systems and have a decent base for this stuff.
TIA
Need help with Arduino Micro and Bluefruit project.
- F3ckLand
- Franklin97355
Re: Need help with Arduino Micro and Bluefruit project.
Could you post clear pictures of your board, any soldering you did and the connections to it?
Could you post your code and a description or drawing of your connections between it all? Please use the code button "</>" in the button bar when posting code to the forums.
Also don't forget to install the drivers http://arduino.cc/en/Guide/Windows#toc4Rather than requiring a physical press of the reset button before an upload, the Micro is designed in a way that allows it to be reset by software running on a connected computer. The reset is triggered when the Micro's virtual (CDC) serial / COM port is opened at 1200 baud and then closed. When this happens, the processor will reset, breaking the USB connection to the computer (meaning that the virtual serial / COM port will disappear). After the processor resets, the bootloader starts, remaining active for about 8 seconds. The bootloader can also be initiated by pressing the reset button on the Micro. Note that when the board first powers up, it will jump straight to the user sketch, if present, rather than initiating the bootloader.
Because of the way the Micro handles reset it's best to let the Arduino software try to initiate the reset before uploading, especially if you are in the habit of pressing the reset button before uploading on other boards. If the software can't reset the board you can always start the bootloader by pressing the reset button on the board.
- F3ckLand
GUGGENHAT: a Bluefruit LE-enabled wearable NeoPixel marquee.
Requires:
- Arduino Micro or Leonardo microcontroller board. An Arduino Uno will
NOT work -- Bluetooth plus the large NeoPixel array requires the extra
512 bytes available on the Micro/Leonardo boards.
- Adafruit Bluefruit LE nRF8001 breakout: http://www.adafruit.com/products/1697
- 4 Meters 60 NeoPixel LED strip: http://www.adafruit.com/product/1461
- 3xAA alkaline cells, 4xAA NiMH or a beefy (e.g. 1200 mAh) LiPo battery.
- Late-model Android or iOS phone or tablet running nRF UART or
Bluefruit LE Connect app.
- BLE_UART, NeoPixel, NeoMatrix and GFX libraries for Arduino.
Written by Phil Burgess / Paint Your Dragon for Adafruit Industries.
MIT license. All text above must be included in any redistribution.
#include <SPI.h>
#include <Adafruit_BLE_UART.h>
#include <Adafruit_NeoMatrix.h>
#include <Adafruit_GFX.h>
// NEOPIXEL STUFF ----------------------------------------------------------
// 4 meters of NeoPixel strip is coiled around a top hat; the result is
// not a perfect grid. My large-ish 61cm circumference hat accommodates
// 37 pixels around...a 240 pixel reel isn't quite enough for 7 rows all
// around, so there's 7 rows at the front, 6 at the back; a smaller hat
// will fare better.
#define NEO_PIN 6 // Arduino pin to NeoPixel data input
#define NEO_WIDTH 37 // Hat circumference in pixels
#define NEO_HEIGHT 7 // Number of pixel rows (round up if not equal)
#define NEO_OFFSET (((NEO_WIDTH * NEO_HEIGHT) - 240) / 2)
// Pixel strip must be coiled counterclockwise, top to bottom, due to
// custom remap function (not a regular grid).
Adafruit_NeoMatrix matrix(NEO_WIDTH, NEO_HEIGHT, NEO_PIN,
NEO_MATRIX_TOP + NEO_MATRIX_LEFT +
NEO_MATRIX_ROWS + NEO_MATRIX_PROGRESSIVE,
NEO_GRB + NEO_KHZ800);
char msg[21] = {0}; // BLE 20 char limit + NUL
uint8_t msgLen = 0; // Empty message
int msgX = matrix.width(); // Start off right edge
unsigned long prevFrameTime = 0L; // For animation timing
#define FPS 20 // Scrolling speed
// BLUEFRUIT LE STUFF-------------------------------------------------------
// CLK, MISO, MOSI connect to hardware SPI. Other pins are configrable:
#define ADAFRUITBLE_REQ 10
#define ADAFRUITBLE_RST 9
#define ADAFRUITBLE_RDY 2 // Must be an interrupt pin
Adafruit_BLE_UART BTLEserial = Adafruit_BLE_UART(
ADAFRUITBLE_REQ, ADAFRUITBLE_RDY, ADAFRUITBLE_RST);
aci_evt_opcode_t prevState = ACI_EVT_DISCONNECTED;
// STATUS LED STUFF --------------------------------------------------------
// The Arduino's onboard LED indicates BTLE status. Fast flash = waiting
// for connection, slow flash = connected, off = disconnected.
#define LED 13 // Onboard LED (not NeoPixel) pin
int LEDperiod = 0; // Time (milliseconds) between LED toggles
boolean LEDstate = LOW; // LED flashing state HIGH/LOW
unsigned long prevLEDtime = 0L; // For LED timing
// UTILITY FUNCTIONS -------------------------------------------------------
// Because the NeoPixel strip is coiled and not a uniform grid, a special
// remapping function is used for the NeoMatrix library. Given an X and Y
// grid position, this returns the corresponding strip pixel number.
// Any off-strip pixels are automatically clipped by the NeoPixel library.
uint16_t remapXY(uint16_t x, uint16_t y) {
return y * NEO_WIDTH + x - NEO_OFFSET;
// Given hexadecimal character [0-9,a-f], return decimal value (0 if invalid)
uint8_t unhex(char c) {
return ((c >= '0') && (c <= '9')) ? c - '0' :
((c >= 'a') && (c <= 'f')) ? 10 + c - 'a' :
((c >= 'A') && (c <= 'F')) ? 10 + c - 'A' : 0;
// Read from BTLE into buffer, up to maxlen chars (remainder discarded).
// Does NOT append trailing NUL. Returns number of bytes stored.
uint8_t readStr(char dest[], uint8_t maxlen) {
int c;
uint8_t len = 0;
while((c = BTLEserial.read()) >= 0) {
if(len < maxlen) dest[len++] = c;
return len;
// MEAT, POTATOES ----------------------------------------------------------
matrix.begin();
matrix.setRemapFunction(remapXY);
matrix.setTextWrap(false); // Allow scrolling off left
matrix.setTextColor(0xF800); // Red by default
matrix.setBrightness(31); // Batteries have limited sauce
BTLEserial.begin();
pinMode(LED, OUTPUT);
digitalWrite(LED, LOW);
unsigned long t = millis(); // Current elapsed time, milliseconds.
// millis() comparisons are used rather than delay() so that animation
// speed is consistent regardless of message length & other factors.
BTLEserial.pollACI(); // Handle BTLE operations
aci_evt_opcode_t state = BTLEserial.getState();
if(state != prevState) { // BTLE state change?
switch(state) { // Change LED flashing to show state
case ACI_EVT_DEVICE_STARTED: LEDperiod = 1000L / 10; break;
case ACI_EVT_CONNECTED: LEDperiod = 1000L / 2; break;
case ACI_EVT_DISCONNECTED: LEDperiod = 0L; break;
prevState = state;
prevLEDtime = t;
LEDstate = LOW; // Any state change resets LED
digitalWrite(LED, LEDstate);
if(LEDperiod && ((t - prevLEDtime) >= LEDperiod)) { // Handle LED flash
prevLEDtime = t;
LEDstate = !LEDstate;
// If connected, check for input from BTLE...
if((state == ACI_EVT_CONNECTED) && BTLEserial.available()) {
if(BTLEserial.peek() == '#') { // Color commands start with '#'
char color[7];
switch(readStr(color, sizeof(color))) {
case 4: // #RGB 4/4/4 RGB
matrix.setTextColor(matrix.Color(
unhex(color[1]) * 17, // Expand to 8/8/8
unhex(color[2]) * 17,
unhex(color[3]) * 17));
break;
case 5: // #XXXX 5/6/5 RGB
(unhex(color[1]) << 12) +
(unhex(color[2]) << 8) +
(unhex(color[3]) << 4) +
unhex(color[4]));
break;
case 7: // #RRGGBB 8/8/8 RGB
(unhex(color[1]) << 4) + unhex(color[2]),
(unhex(color[3]) << 4) + unhex(color[4]),
(unhex(color[5]) << 4) + unhex(color[6])));
break;
} else { // Not color, must be message string
msgLen = readStr(msg, sizeof(msg)-1);
msg[msgLen] = 0;
msgX = matrix.width(); // Reset scrolling
if((t - prevFrameTime) >= (1000L / FPS)) { // Handle scrolling
matrix.fillScreen(0);
matrix.setCursor(msgX, 0);
matrix.print(msg);
if(--msgX < (msgLen * -6)) msgX = matrix.width(); // We must repeat!
matrix.show();
prevFrameTime = t;
Last edited by Franklin97355 on Mon Aug 25, 2014 11:54 pm, edited 1 time in total.
Reason: Added right square bracket on [/code] tag
- F3ckLand
Hope this helps
- F3ckLand
This is what i followed
- F3ckLand
This project has been on the back burner but I have made progress. Sorted out the wiring and got the leds working, got the bluetooth working good, I cant sent it words and they are displayed, I can change the color, all is well. My coiled grid is slightly different than the example and therefore my words are all crooked (Sorta looks like italics) The top row displays sooner that the bottom. So there is a place in the code to adjust this exact thing #define NEO_WIDTH # (also explanied in the comments)
Im new to the programming side of things, not sure exactly what value to change because it seems when i change the number right after #define NEO_WIDTH (currently 6) it doesnt affect the pattern on my message board.
If someone would like to read through this post and the previous posts the whole story is layed out for you, let me know what they think that would be super helpfull.
TIA
TIA
- F3ckLand
- adafruit_support_mike
NEO_WIDTH is the circumfrence of your loop in pixels. NEO_HEIGHT is the number of times the coil loops back on itself.
To find the width, locate the first pixel in the strip, then go up to the one directly above it. Call that pixel-0. Work your way back along the strip toward the first pixel, numbering the pixels as you go. The final number (for the first pixel in the strip) will the NEO_WIDTH.
When the code wants to light the first pixel of the second row, it will skip ahead to pixel NEO_WIDTH+1, which should be the one directly above the first pixel in the strip.
- F3ckLand
thanks, so i have adjusted the Neo width several times, the issue im having is that it seem that its not accepting the change or its just not enacting the change. The same crooked letters occur no matter what i put in for a neo width
Just to refresh, post the code you're using now please (between CODE tags).
