I'm trying to locate or search for the .h files or libraries in the Arduino IDE using Finder on a MAC (OS X).
I have installed the Adafruit Arduino 1.0.5 IDE which works fine and is located in the Applications Directory
I do see the Documents/Arduino/libraries folder, which contains a read me file, as well as a folder for each of my projects/sketches.
However I would like to find and examine the math.h files or even the Adafruit_NeoPixel header and library files.
The only way I can see them is by going to the Arduino application and "Show Package Contents" which is under the
Contents/Resources/Java/libraries folder I can then see the files and open them, but seems kinda counter intuitive.
Is this typical? Do I have it installed right? How can I use Finder to find the .h files or other libraries?
It seems this is more of a Mac / OSX question than Arduino, but would like to post as I see the Adafruit (and others I'm sure) work from a Mac.
Many thanks!
Viewing Libraries and .h files on a Mac / OSX
- adafruit_support_rick
Re: Viewing Libraries and .h files on a Mac / OSX
Open Package Contents is the way you do it. There's no other way.
- Doryen
Thanks for the quick response Rick!
I'll have to now experiment with adding a library to see where it ends up!
- egutting
Added libraries should go in your Arduino library (in the libraries folder) in Documents. (At least that's where they go for me and I'm on BANNED)
Your sketches should be in Documents/Arduino. Only the libraries should go in Documents/Arduino/librariesDoryen wrote:I do see the Documents/Arduino/libraries folder, which contains a read me file, as well as a folder for each of my projects/sketches.
Adafruit_NeoPixel should go in Documents/Arduino/libraries. Only system libraries should be in the package. You should never have a reason to add anything to the package.Doryen wrote:However I would like to find and examine the math.h files or even the Adafruit_NeoPixel header and library files.
- Doryen
Thanks Rick!
This library was already installed in the package under Contents/Resources/Java/libraries folder - I took the easy route installing the Adafruit Arduino IDE, so I guess it works either way, right?egutting wrote:Adafruit_NeoPixel should go in Documents/Arduino/libraries. Only system libraries should be in the package. You should never have a reason to add anything to the package.
It works either way, but if you install your libraries in the package, then you will lose them when you upgrade to a new version of the IDE. Similarly, I run both 1.0.5 and 1.5.6 (for the Due) simultaneously. They both use the same Documents/Arduino/libraries folder, so I don't have to duplicate anything.
- Doryen
Got it! Thanks again!
