Is there anything I can do to try to salvage it? Or potentially get a replacement?avrdude: initialization failed, rc=-1
this check.
Arduino Micro Dead
- laptopman
Arduino Micro Dead
I recently purchased a Micro for use in an ongoing project. I had it hooked up to an Ultimate GPS and SD breakout, and was having issues with the serial port. Windows would ding when it was plugged in, and the COM port would show up in the device manager, but not in the IDE. I successfully reburnt the bootloader and connected, but shortly after the board stopped being recognized. Plugging it in to the USB returns nothing and attempting to burn the bootloader returns
Re: Arduino Micro Dead
That part is a Java runtime issue. It has problems keeping track of COM ports at times. If it is showing up as a COM port in the Device Manager, the board is working.Windows would ding when it was plugged in, and the COM port would show up in the device manager, but not in the IDE.
Does it show up at all in Device Manager now? Perhaps as an unknown device?I successfully reburnt the bootloader and connected, but shortly after the board stopped being recognized.
- laptopman
Thank you for the information about the Java runtime error. I will keep that in mind for the future.
It doesn't show up in the device manager at all, and I get no sound when it plugs in.
When exactly did you purchase the Micro?
- laptopman
August 14th
I actually dont necessarily need a replacement. An arduino nano turns out to be much more effective for my purpose
If you decide you do want one, we have a 30-day replacement policy. Just contact [email protected] with a link to this thread.August 14th
