im from Germany and would use an Mega2560 with an WS2812b Strip and your Library.
With an UNO all works fine.
But if i connect an MEGA2560 the animations runs to fast, the Colors and LED jumps around and flickering.
When i let blink only one led, with delay(500), it blinks three times, then 10 seconds nothing, and so on.
Whats wrong?
Should i change some program code?
Thanks fpr help, and sorry for the bad english.
Regards Mario
Neopixel & Mega2560 don't work
Re: Neopixel & Mega2560 don't work
Neopixel code for the UNO should run the same on a Mega. Both processors should have the same clock speed. Are these both official Arduino boards, or clones?
If you post the code you are using we can check for anything unusual.
- pburgess
Which pin number are you using?
If it's one of the analog pins...there's a -very- esoteric issue that affects the Arduino Mega, and you should try any of the digital pins and see if it changes.
- marber68
thanks all for the fast reply.
I don't know whats the matter.
After i have test the Mega several times, reconnect all four times, now it works. ??
I don't change anything, no code, no pins. Now i think, the Mega board is faulty.
Its an SaintSmart, that looks like an original Arduino.
The code i tested are the examples from the adafruit library.
Only the LED count and Pin number i changed.
I used several Pins from 6 to 53, all the same result.
Now i will test it for a while and look if the fault recur.
Thank you very much.
Regards Mario
Regards Mario
- pburgess
Could just be the connections. Like if you're using stranded wire in the Arduino sockets, usually a bit flaky.
