I am using the below two products in project :-
1. Adafruit CC3000 WiFi Shield with Onboard Ceramic Antenna - PRODUCT ID: 1491"
Uses PINS 3,5,10
2. DS1307 REAL TIME CLOCK BREAKOUT BOARD KIT - PRODUCT ID 264.
Uses PIN 4,5 for I2C communication.
As you can see pin 5 is conflicted and we are not able to use both in one project, please help if there is any work around.
CC3000 & DS 1307 pin conflict
- Franklin97355
Re: CC3000 & DS 1307 pin conflict
The DS1307 uses Analog pins 4 and 5 while the CC3000 uses Digital pins 3, 4, 5, 11, 12, 13. So no conflict.
- hgmm
Thanks, it was because the breadboard did not have enough power so it was not working.
Its working now!!!
Its working now!!!
