Logging Data from TCS34725 RGB Color Sensor
- adafruit_support_bill
Re: Logging Data from TCS34725 RGB Color Sensor
0-255 is an 8-bit range. To change a 16 bit value into an 8-bit value, you divide by 256. You can do that anywhere after you read the raw 16 bit values. Just keep in mind that you are throwing away most of your resolution in doing that.
