Arduino Ethernet with PoE
- marck1
I want to buy 4 Arduino Ethernet with PoE from you but I do not see them on your website, can I order or is there a replacement part number?
- Franklin97355
Re: Arduino Ethernet with PoE
That is not an item we carry. What is the application you need them for and could you use these instead?
- marck1
That is cool. Exactly what I was looking for. Once cable to carry both power and data, plus it's cheaper. I know the POE Arduino is like $80. I will order today. Thanks
- marck1
What power supply part number will I need when using these cable in conjunction with the Arduino Ethernet board?
- Franklin97355
This one from us https://www.adafruit.com/products/63 would work.
- rschramm
The Arduino Ethernet shield PID: 201 does not have a 2.1mm jack to receive the plug from the PoE Injector Cable Set PID: 435.
Can I just plug the Ethernet RJ45 connector straight in to the shield to power it and use the injector and a DC 'wall-wort' (9VDC PID: 63) at the opposite end (at my router) to drive it?
Said differently, will the 9VDC PoE power be brought thru the on-board RJ45 to the Vin of the Arduino?
- Franklin97355
That board has no provisions for power over ethernet.
- rschramm
Boy do I feel stupid... I ordered the wrong part.... I meant to order Arduino Uno Ethernet, it has the DC jack I was looking for .... and the Uno! Too many late night coding sessions I guess.
