I would like to know if I can stack the following two shields to the same arduino uno and get them functioning together:
Adafruit "Music Maker" MP3 Shield for Arduino w/3W Stereo Amp
https://www.adafruit.com/product/1788
Arduino Ethernet shield R3 with micro SD connector - Assembled
https://www.adafruit.com/products/201
I have isolated the pins that the ethernet shield uses, and am trying to do the same with the mp3 shield. It turns out that they both employ the ISP/ISCP header pins.
I'm assuming this will be a problem, or can I work around this? any advice will be greatly appreciated. Thank you.
Stacking ethernet and mp3 shields to the same arduino uno
- embedgeek
- adafruit_support_rick
Re: Stacking ethernet and mp3 shields to the same arduino un
Both using the ICSP is OK - those are the SPI pins, and SPI is a bus architecture.
The problem is that both shields use pin 4 for the SD card chip select line.
You will only be able to use one SD card slot. Otherwise, both shields should just work.
I'm not sure about SRAM space - you may have a problem there on a Uno. Even without the hardware, you can always build a test sketch combining the libraries to see how much SRAM will be required. Use the freeRam() function from here to measure usage:
https://learn.adafruit.com/memories-of- ... ree-memory
- embedgeek
Yeah, I figured that the SD card would be an issue. I figure I can always use I2C between two arduinos and get everything functional. For the ICSP header, how would I go about "sharing" that between both shields. In other words, how would I go about wiring the ICSP blocks from both shields to the "host" arduino?
Use stacking headers with the MusicMaker shield. The ICSP headers will all plug together.
https://www.adafruit.com/product/85
There's a solder jumper on the bottom of the Music Maker Shield. It's normally connected. If you cut the trace, it will disconnect the SD CS from pin 4.
