Leonardo with ATMEGA16U4
- customdev
I have been trying to add a board to the Arduino IDE that is physically identical to the Leonardo, but instead of using an ATMEGA32U4 it uses and ATMEGA16U4. I created the board.txt file as well as I added the 16U4 entries to the avrdude.conf file, but no luck I keep on getting an error and I cannot burn the program (I am downloading direct using a USBTinyISP, without the bootloader). Any help on this subject will be greatly appreciated.
Re: Leonardo with ATMEGA16U4
You may be running into a factory defaults problem: apparently the ATmega16u4 ships with its lock bits set.
This page has more information, along with a part definition you can add to avrdude.conf:
http://www.dgkelectronics.com/adding-su ... the-fuses/
- customdev
Actually, I have not even gotten to that point, during compilation I get:
unknown MCU 'atmega16u4' specified
Known MCU names:
avr2
at90s2313
at90s2323
at90s2333
at90s2343...
I have already added the boards.txt file to my hardware folder so that I can select that configuration and I have added the definition for the ATMEGA16U4 to the avrdude config file
Known MCU names:
avr2
at90s2313
at90s2323
at90s2333
at90s2343...
What are the exact input and output when you try to program? What command do you enter, and what error messages do you get?
- customdev
When I press the "Check Compilation" button on the Arduino IDE I get the message on the posting above, just with a longer list of devices.
Scroll down through the list of responses and see if you find something that looks like 'ATmega16u4'. It's possible that this could be something as simple-but-hard-to-see as a typo.
- customdev
The Atmega16U4 is not part of the list, is there a place where you can list this devices?
I don't believe it is a typo, I have already re-checked. When you add a microcontroller to the Arduino IDE besides the boards.txt and the configuration on the avrdude.comf what else has to be done?
In the folder where your 'boards.txt' file lives, there should be another folder named 'variants'.
Inside that will be a set of folders whose names match the '[board name].build.mcu=[microcontroller]' lines in 'boards.txt'. In each of those will be a file named 'pins_arduino.h' that maps the physical pins on the chip to pin numbers in the Arduino libraries.
You'll need a variant folder named 'atmega16u4' (or whatever you put in the xxx.build.mcu=xxx line) with a header file for that chip.
- customdev
Thanks for you help, but after adding the folders and the pins_arduino.h file I am still getting the same error, is there any other place for the mcu to be listed?
At this point you're pretty much at my limit for modding the Arduino IDE. You'll probably need to check over in the Arduino forums for more information:
http://forum.arduino.cc/
