GPS CLOCK
louie003
GPS CLOCK
Post by louie003 »
I am trying to build a GPS clock and ive searched for months for help online and yeah there is a ton of code but not one signal book website youtube video explain what each line of code does even the test code included in your GPS library explain it i can upload photo but my issue line in knowledge i need some help filling in the gaps of my code like converting it to PST and programing the day light saves line code ive got it printing out the UTC time once but then it does nothing so i am going to paste my code and if some one is willing to help me that would be awesome> my last posting hear led me to get utter fustrate and walk away from arduino for a while cause i was being fed the loop back into mystery I genuinely need help this was suppose to be a gift # months ago but i have failed to unlock the code key I am using an arduino leonardo the serial RGB LCD20,4
#include <Adafruit_GPS.h>
#include <SoftwareSerial.h>
#include <LiquidCrystal.h>
#include <Wire.h>
#include "RTClib.h"
#include "Adafruit_HTU21DF.h"
Adafruit_GPS GPS(&Serial1);
HardwareSerial mySerial = Serial1;
LiquidCrystal lcd(7, 8, 9, 10, 11, 12);
Adafruit_HTU21DF htu = Adafruit_HTU21DF();
#define GPSECHO true
void setup()
  Serial.begin(115200);
  Wire.begin();
  htu.begin();
  GPS.begin(9600);
  GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_RMCGGA);
  GPS.sendCommand(PMTK_SET_NMEA_UPDATE_1HZ);
  delay(1000);
  lcd.begin(20,4);
  lcd.print ("  Markie's Clock!");
void loop () {
  char c = GPS.read();
  // if you want to debug, this is a good time to do it!
  if (GPSECHO)
      if (c) Serial.print(c);
  if (GPS.newNMEAreceived())
    Serial.println(GPS.lastNMEA());
    if (!GPS.parse(GPS.lastNMEA()))
      return;
    lcd.setCursor(0,1);
    lcd.print(GPS.hour, DEC); lcd.print(':');
    lcd.print(GPS.minute, DEC); lcd.print(':');
    lcd.print(GPS.seconds, DEC);
    lcd.setCursor(10,1);
    lcd.print(GPS.day, DEC); lcd.print('/');
    lcd.print(GPS.month, DEC); lcd.print("/20");
    lcd.println(GPS.year, DEC);
    delay(1000);
  htu.readTemperature();
  htu.readHumidity();
  lcd.setCursor(0,2);
  lcd.print(htu.readTemperature()*9/5+32);
  lcd.print("F");
  lcd.setCursor(8,2);
  lcd.print(htu.readHumidity());
  lcd.print("%H");
  delay(30500);
Franklin97355
Re: GPS CLOCK
Post by Franklin97355 »
What do you get on the serial monitor when the program is running? To convert to PST you just subtract 8 hours from GMT (making allowances for crossing midnight)
louie003
Re: GPS CLOCK
Post by louie003 »
Thanks my issue is that it will not refresh the display it only shows the time once and never updates even though I have it set to refresh every second
adafruit_support_mike
Re: GPS CLOCK
Let's drop back to a basic hardware test and work our way up from there.
If you connect the GPS module to the Arduino as shown in the "direct computer wiring" method on this tutorial page:
https://learn.adafruit.com/adafruit-ult ... ter-wiring
Do the NMEA sentences appear in the Arduino IDE's Serial Monitor? If so, do they eventually show a fix and start providing time data?
fmbfla
Re: GPS CLOCK
Post by fmbfla »
This "Lil bit" should get you started with formating your time to your ZONE.
However, I am not sure if I have the exact HOUR right for your TZ And I might have the DST times Backwards
and I might be off an HOUR on each
I don't have your setup to test it your way but it works with an UNO and the Flora GPS module.
You should be able to replace the Serial print with LCD print.
Try it and post your thoughts/Results
Drew
   //DST STARTS March 9
    //DST ENDS November 2
    if ((GPS.month==11)&&(GPS.day==2)){// if the month is NOV and the day is the SECOND.....take 7 from UTC for WEST COAST U.S.A.
    float ((GPS.hour) = GPS.hour - 7);// I think this is for PST... Minus 7  hours from ZULU time
    if ((GPS.month==3)&&(GPS.day==9)){// if the month is MARCH and the day is the NINTH....take 6 from UTC for WEST COAST U.S.A.
    float ((GPS.hour) = GPS.hour - 6);// I think this is for PST... Minus 6  hours from ZULU time
    Serial.print("\nTime: ");
// This is where you get regular time displayed like your Microwave oven or your alarm clock
    if (GPS.hour < 10){                // Zero padding if value less than 10 ie."09"
    Serial.print(" ");//leave a blank space " 9" so that the second number of the hour stays in it's same spot on the LCD
//Do the same for the Minutes and Seconds.
    Serial.print((GPS.hour> 12) ? GPS.hour - 12 : ((GPS.hour == 0) ? 12 : GPS.hour)); // Conversion to AM/PM
  else{
    Serial.print((GPS.hour > 12) ? GPS.hour - 12 : ((GPS.hour == 0) ? 12 : GPS.hour)); // Conversion to AM/PM
  Serial.print(':');
  if(GPS.minute < 10){         // Zero padding if value less than 10 ie."09" instead of "9"
    Serial .print("0");
    Serial.print(GPS.minute);
  else{
  Serial.print(':');
  if(GPS.seconds < 10){         // Zero padding if value less than 10 ie."09" instead of "9"
    Serial.print("0");
    Serial.print(GPS.seconds);
  else{
  if(GPS.hour < 12){                  // Adding the AM/PM sufffix
    Serial.println(" AM");
  else{
    Serial.println(" PM");
louie003
Re: GPS CLOCK
Post by louie003 »
Thank you I'll will definitely try this out.
rcomito
Re: GPS CLOCK
Post by rcomito »
Hi Louie,
To take care of your time zone needs, check out Timezone.h written by Jack Christensen.
You can get the library at: https://github.com/JChristensen/Timezone
I used Jack's library for my GPS clock. It works great.
For the Pacific time zone, the associated time zone rules are:
// Pacific
TimeChangeRule pDST = { "PDT", Second, Sun, Mar, 2, -420 };  // UTC - 7 hrs.
TimeChangeRule pSTD = { "PST", First, Sun, Nov, 2, -480 };   // UTC - 8 hrs.
TimeChangeRule myDST = pDST;
TimeChangeRule mySTD = pSTD;
Timezone myTZ(myDST, mySTD);
Rick Comito
louie003
Re: GPS CLOCK
Post by louie003 »
rcomito i downloaded that and tinygps library but i keep getting time_t is not a name type error i have check everything out and am lost.
fmbfla
your suggestion where do i put the little bit of code in my sketch???
and adafruit i am not going back to backs for a 5th time i know you must say that first but as i learned from my last 2 fails at making an arduino project that what you do first and every component works fine alone serial monitor shows the time hows the attena is doing and everything but i dont know the proper arduino code im glad others are helping but i would love to see adafruit post more or even one tutorial on code writing i don't get how us even babies are suppose to just know instantly the code and how to integrate it into a project based of an example code i have books ive read them and then i go to apply knowledge and arduino say error then i find online the book published 2013 or even this year has wrong code have someone teach us on the net how to write code is all im saying i live in a one trick town about 100 miles away from any major cities maker fair workshop never are anywhere close that i could afford to drive to.
rcomito
Re: GPS CLOCK
Post by rcomito »
Hi Louie,
Here's a copy of my GPS clock code. It shows everything in context.
// GPSClock        Rick Comito et al.
#define VERSION "Ver. 1.00.201400412 Rick Comito"
// Version history:
//     1.00 - add AM / PM indicator and call it done
//     0.90 - General code optimization and tweaking
//     0.80 - Display colon between HH and MM.  Add light sensor dimming.
//     0.70 - Display satellite count and fix status on display 1
//     0.60 - Display HHMM on display 0 and SS on display 1
//     0.50 - Incorporate standard / daylight time change
//     0.40 - Increase _SS_MAX_RX_BUFF to allow for faster polling.
//     0.30 - Incorporate timezone.h.  Adjust UTC to local standard time
//     0.20 - Move TX and RX pins to 8 and 9 to allow program upload without wireing changes
//     0.10 - Parse time and date from GPS data and send to serial monitor
//     0.00 - Just read the GPS module and send the data to the serial monitor
// This clock uses a GPS module to get the time and date.  We need the date so we know when to
// adjust for Standard Time/Daylight Saving Time.
// Thanks to the crews at http://www.adafruit.com and http://www.arduino.cc for all of the ideas,
// source code shared, and the great products and support.
// This clock uses two 4 x 7 segment displays on I2C backplanes to display hours, minutes, seconds,
// and number of satellites seen.  The first is addressed at 0x70 (default) and the second is addressed
// at 0x71 by shorting the address pads at A0.
// It uses an optional light sensor to adjust the display brightness based on ambient lighting.
// This code started with code written by Jay Doscher.  Turns out he used the same microcontroller and
// GPS module that I had decided on.  The slick interrupt stuff is his.  Thanks for the jumpstart Jay.
// http://www.polyideas.com/blog/2012/12/16/gps-clock-using-an-arduino-micro
// Parts list:                                                             \\
// Arduino Micro                     http://www.adafruit.com/products/1086 \\
// Adafruit Ultimate GPS module      http://www.adafruit.com/products/746  \\
// Two 4 x 7 segment displays with I2C backplanes:                         \\
//                            1.2"   http://www.adafruit.com/products/1270 \\
//                            .56"   http://www.adafruit.com/products/865  \\
// Optional parts:                                                         \\
// Light sensor                      http://www.adafruit.com/products/1384 \\
// GPS external antenna              http://www.adafruit.com/products/960  \\
// uFL to SMA adapter                http://www.adafruit.com/products/851  \\
// One stop shopping. Pick them up today at the Adafruit electronics shop
// and help support open source hardware & software!
#include <SoftwareSerial.h>        // Part of the Arduino standard library.
#include <Wire.h>                  // Part of the Arduino standard library.
#include <Time.h>                  //http://www.arduino.cc/playground/Code/Time
#include <Timezone.h>              //https://github.com/JChristensen/Timezone    Thanks to Jack Christensen (Nice work)
#include <Adafruit_GPS.h>          //https://github.com/adafruit/Adafruit-GPS-Library
#include <Adafruit_GFX.h>          //https://github.com/adafruit/Adafruit-GFX-Library
#include <Adafruit_LEDBackpack.h>  //https://github.com/adafruit/Adafruit-LED-Backpack-Library
// Increase _SS_MAX_RX_BUFF in SoftwareSerial.h from 64 to 128 in order to be able to pole the GPS
// faster than 1HZ.  Thanks to Wayne Holder over at SparkFun.com for this one.  He did it a little
// differently, but I got the idea from him.
#ifdef _SS_MAX_RX_BUF
#  undef _SS_MAX_RX_BUF
#  define _SS_MAX_RX_BUF 128
#endif
#define TIMETOUPDATE  10     // Milliseconds between clock updates.  Update frequently so there's no delay
                             // between second rollovers (ticks).
//#define LIGHTSENSOR          // Defined if this build has a light sensor
//#define WAKEUP               // Run our "Teddy Ruxpin" boot-up routine
// Debugging flags - Allows for eight levels of debugging
#define DB       0b00000000  // Debugging off
#define DBGPS    0b00000001  // Show raw GPS sentences (also good for show and tell)
#define DBSATS   0b00000010  // Fix status and satellite count
#define DBUTC    0b00000100  // UTC time and date
#define DBLOCAL  0b00001000  // Local time and date
#define DBDISP   0b00010000  // Data to be sent to the displays
#define DBBRIGHT 0b00100000  // Display brightness settings
byte DEBUG = DB | DBGPS;     // OR in the levels that you need e.g: DEBUG = DB | DBGPS | DBSATS | DBCLOCK;
// Timezone rules.  Select yours from the following.  If you need space, comment out the rest.
// Atlantic
TimeChangeRule aDST = { "ADT", Second, Sun, Mar, 2, -180 };  // UTC - 3 hrs.
TimeChangeRule aSTD = { "AST", First, Sun, Nov, 2, -240 };   // UTC - 4 hrs.
// Eastern
TimeChangeRule eDST = { "EDT", Second, Sun, Mar, 2, -240 };  // UTC - 4 hrs.
TimeChangeRule eSTD = { "EST", First, Sun, Nov, 2, -300 };   // UTC - 5 hrs.
// Central
TimeChangeRule cDST = { "CDT", Second, Sun, Mar, 2, -300 };  // UTC - 5 hrs.
TimeChangeRule cSTD = { "CST", First, Sun, Nov, 2, -360 };   // UTC - 6 hrs.
// Mountain
TimeChangeRule mDST = { "MDT", Second, Sun, Mar, 2, -360 };  // UTC - 6 hrs.
TimeChangeRule mSTD = { "MST", First, Sun, Nov, 2, -420 };   // UTC - 7 hrs.
// Arizona - Does not observe daylight time
TimeChangeRule azDST = { "MST", Second, Sun, Mar, 2, -420 };  // UTC - 7 hrs.
TimeChangeRule azSTD = { "MST", First, Sun, Nov, 2, -420 };   // UTC - 7 hrs.
// Pacific
// Alaska
TimeChangeRule akDST = { "AKDT", Second, Sun, Mar, 2, -480 }; // UTC - 8 hrs.
TimeChangeRule akSTD = { "AKST", First, Sun, Nov, 2, -540 };  // UTC - 9 hrs.
// Hawaii-Aleution
TimeChangeRule haDST = { "HADT", Second, Sun, Mar, 2, -540 }; // UTC - 9 hrs.
TimeChangeRule haSTD = { "HAST", First, Sun, Nov, 2, -600 };  // UTC - 10 hrs.
// Hawaii - Does not observe daylight time
TimeChangeRule hiDST = { "HDT", Second, Sun, Mar, 2, -600 };  // UTC - 10 hrs.
TimeChangeRule hiSTD = { "HST", First, Sun, Nov, 2, -600 };   // UTC - 10 hrs.
// Mine is US Eastern Time Zone (Boston, Detroit)
TimeChangeRule myDST = eDST;
TimeChangeRule mySTD = eSTD;
TimeChangeRule *tcr;        //pointer to the time change rule, used to get TZ abbrev
time_t utc, local;          // Universal and local time in time_t format
// Connect the GPS Power pin to 5V
// Connect the GPS Ground pin to ground
// If using software serial (sketch example default):
//   Connect the GPS TX (transmit) pin to Digital 8
//   Connect the GPS RX (receive) pin to Digital 7
// If using hardware serial (e.g. Arduino Mega):
//   Connect the GPS TX (transmit) pin to Arduino RX1, RX2 or RX3
//   Connect the GPS RX (receive) pin to matching TX1, TX2 or TX3
#define TX 8
#define RX 7
SoftwareSerial mySerial(TX, RX);
Adafruit_GPS GPS(&mySerial);
// If using hardware serial (e.g. Arduino Mega), comment
// out the above four lines and enable this line instead:
//Adafruit_GPS GPS(&Serial1);
boolean firstFix = false;    // Clock has had it's first satellite fix and the GPS onboard RTC is set.
// The two 4 x 7 segment displays are at I2C addresses 0x70 and 0x71
Adafruit_7segment matrix0, matrix1 = Adafruit_7segment();
byte display0 = 0x70;
byte display1 = 0x71;
#ifdef LIGHTSENSOR
  // Light sensor pin
  uint8_t sensorPin = A0;    // Wire the sensor "OUT" pin to A0
#endif
// Set aside a small buffer to build sprintf() formatted debugging messages
char sbuffer[64] = "";
// This keeps track of whether we're using the interrupt.
// On by default!
boolean usingInterrupt = true;
// Stumbled across this in a thread on arduino.cc. Sets the fix interval.
// Match this with your PMTK_SET_NMEA_UPDATE_xxHZ.  Thanks Kas.
#define PMTK_SET_NMEA_FIX_1HZ  "$PMTK300,1000,0,0,0,0*1C"
#define PMTK_SET_NMEA_FIX_5HZ  "$PMTK300,200,0,0,0,0*2F"
#define PMTK_SET_NMEA_FIX_10HZ "$PMTK300,100,0,0,0,0*2"
void setup(void)
  // 9600 NMEA is the default baud rate for Adafruit MTK GPS - some use 4800
  GPS.begin(9600);
  // Turn off all data output while we set our preferences.
  GPS.sendCommand(PMTK_SET_NMEA_OUTPUT_OFF);
  delay(100);
  // Turn off antenna status
  GPS.sendCommand(PGCMD_NOANTENNA);
  // Set the GPS update rate
  GPS.sendCommand(PMTK_SET_NMEA_UPDATE_5HZ);
  // Set the GPS fix interval
  GPS.sendCommand(PMTK_SET_NMEA_FIX_5HZ);
  // Turn on GPS RMC (recommended minimum) and GGA (fix data) sentences
  // Initialize, clear, and dim the displays.
  // Note: my display0 is not quite as bright is display1, so set 0 to level 1, and 1 to level 0
  matrix0.begin(display0);
  matrix0.clear();
  matrix0.setBrightness(1);
  matrix1.begin(display1);
  matrix1.clear();
  matrix1.setBrightness(0);
  // Set the satellite count to 0
  matrix1.writeDigitNum(4, 0);
  matrix0.writeDisplay();
  matrix1.writeDisplay();
#ifdef LIGHTSENSOR
  // The light sensor needs a 3.3v reference.  Jumper 3.3v to AREF
  analogReference(EXTERNAL);
#endif
  // the nice thing about this code is you can have a timer0 interrupt go off
  // every 1 millisecond, and read data from the GPS for you. That makes the
  // loop code a heck of a lot easier!
  useInterrupt(true);
  // If we're debugging, connect the serial console at 115200 so we can read the GPS
  // fast enough and echo without dropping chars.
  if (DEBUG)
  delay(1000);
#ifdef WAKEUP
  wakeup();    // Just a little animation thing for fun.
#endif
} // setup
uint32_t timer = millis();
void loop(void) {
  uint8_t hh, mm, ss, dd, mo, yy;
  // if a sentence is received, we can verify the checksum, parse it ...
  if (GPS.newNMEAreceived()) {
      return;  // If we fail to parse a sentence, we should just wait for another
  // if millis() timer wraps around, reset it
  if (timer > millis())
    timer = millis();
  // Update the clock approximately every TIMETOUPDATE milliseconds or so.
  // this should be often enough to ensure that we don't miss any seconds
  // rollover.
  if ((uint32_t)millis() - timer >= TIMETOUPDATE) {
    if (DEBUG & DBGPS)
    timer = millis(); // reset the timer
    // If we have a GPS fix, the RTC on the GPS board has been set and is getting updated.
    if ((firstFix) || (GPS.fix > 0)) {
      if (DEBUG & DBSATS) {
        sprintf(sbuffer, "Fix: %d Satellites: %d\n", GPS.fix, GPS.satellites);
        Serial.print(sbuffer);
      firstFix = true;
      hh = GPS.hour;
      mm = GPS.minute;
      ss = GPS.seconds;
      mo = GPS.month;
      dd = GPS.day;
      yy = GPS.year;
      // Set the Arduino software RTC
      setTime(hh, mm, ss, dd, mo, yy);
    // Get the time from the software RTC in time_t format
    // so we can have the timezone tools do their magic.
    utc = now();
    if (DEBUG & DBUTC) {
      sprintf(sbuffer, "%02d:%02d:%02d ", hour(utc), minute(utc), second(utc));
      sprintf(sbuffer, "%s %02d %s %d\n", dayShortStr(weekday(utc)), day(utc), monthShortStr(month(utc)), year(utc));
    local = myTZ.toLocal(utc, &tcr);
    if (DEBUG & DBLOCAL) {
      sprintf(sbuffer, "%02d:%02d:%02d ", hour(local), minute(local), second(local));
      sprintf(sbuffer, "%s %02d %s %d %s\n", dayShortStr(weekday(local)), day(local), monthShortStr(month(local)), year(local), tcr -> abbrev);
    updateClock(local);
#ifdef LIGHTSENSOR
      setBrightness();
#endif
} // loop
// Interrupt is called once a millisecond, looks for any new GPS data, and stores it
SIGNAL(TIMER0_COMPA_vect) {
  volatile char c = GPS.read();
void useInterrupt(boolean v) {
  if (v) {
    // Timer0 is already used for millis() - we'll just interrupt somewhere
    // in the middle and call the "Compare A" function above
    OCR0A = 0xAF;
    TIMSK0 |= _BV(OCIE0A);
  else {
    // do not call the interrupt function COMPA anymore
    TIMSK0 &= ~_BV(OCIE0A);
    usingInterrupt = false;
} // useInterrupt
// updateClock
// Update the clock displays.
// This function gets passed time_t localtime which is the current time adjusted for timezone and
// standard / daylight time with the great tools built by Jack Christensen.
// If you're building any kind of clock and you want to display local time, check out
// https://github.com/JChristensen/Timezone   Nice work Jack.  Thanks.
// The displays get cleared in setup().  We'll show the number of satellites we can see,
// but leave the time blank until we get our first satellite fix.  We can't count on the
// RTC if this is the first time the code has been run, or if it has had a recent battery
// change (or doesn't have one installed).  Besides, it adds a little drama to the clock
// when it's first plugged in.  You see the satellite count incrementing, then BAM, clock
// display.
#define PMDOT 0x08              // Leftmost lower dot for PM indicator
#define AMDOT 0x04              // Leftmost upper dot for AM indicator
#define COLON 0x02              // Colon between HH and MM
void updateClock(time_t localtime) {
  int hhmm;                     // Hours and minutes
  int secs;                     // Seconds
  uint8_t sats;                 // How many satellites we can see
  int ssss;                     // Second and satellites displayed as ss.ss
  static int lasthhmm = 0;      // Hour and minute last time we set the displays
  static int lastssss = 0;      // Second and satellites last time we set the displays
  byte ampmdot;                 // Code to present AM or PM dot indicator
  boolean showdot;              // Show the dot in ss.ss if we still have a fix
  sats = GPS.satellites;
  // If we haven't established our first satellite fix yet, leave the hours, minutes and
  // seconds blank, but display how many satellites (if any) we can see.
  if(!firstFix) {
    ssss = sats;
    if (ssss != lastssss) {
      matrix1.print(ssss);
  // We've had at least one satellite fix, so update the displays if they need it.
  else {
    // Display 12 hour time (My bride doesn't do military time)
    hhmm = ((hour(localtime) % 12) * 100) + minute(localtime);
    if (hhmm < 100)  // Midnight hour
      hhmm += 1200;
    ssss = (second(localtime) * 100) + sats;
    showdot = (GPS.fix > 0) ? true : false;
    // Update displays if something has changed.
    if (hhmm != lasthhmm) {
      matrix0.print(hhmm);
      ampmdot = (hour(localtime) < 12) ? AMDOT : PMDOT;
      matrix0.writeDigitRaw(2, COLON | ampmdot);
    // Handle this display one digit at a time to preserve leading zeros.
      matrix1.writeDigitNum(0, (ssss / 1000));
      matrix1.writeDigitNum(1, (ssss / 100) % 10, showdot); // true turns on the dot in ss.ss
      matrix1.writeDigitNum(3, (ssss / 10) % 10);
      matrix1.writeDigitNum(4, ssss % 10);
    if (DEBUG & DBDISP) {
      sprintf(sbuffer, "%4d %04d\n", hhmm, ssss);
  lasthhmm = hhmm;
  lastssss = ssss;
} // updateClock
#ifdef LIGHTSENSOR
  // setBrightness
  // Set the display brightness based on ambient light.
  // Sensor readings range from 1 to 1024
  // Display brightness ranges from 0 (dim) to 15 (bright).
  // The 1.2" and .56" displays have slightly different brightness
  // so we'll try to adjust accordingly.
#  define BRIGHT 15   // Maximum setting
#  define DIM 0       // Minimum display brightness setting
#  define HILIMIT 850 // Upper raw limit to set bright setting
#  define LOLIMIT 100 // Lower raw limit to set dim setting
#  define BIAS0  1    // Extra brightness to add to display 0
#  define BIAS1 -2    // Extra dimness to add to display 1
  void setBrightness()
    static uint8_t lastsetting = 0; // Last display0 setting
    uint8_t bsetting0 = BIAS0;      // Brightness setting for display 0
    uint8_t bsetting1 = 0;          // Brightness setting for display 1
    // read the raw value from the sensor:
    uint8_t rawvalue = analogRead(sensorPin);
    // Set brightness accordingly
    if (rawvalue >= HILIMIT) {
      bsetting0 = BRIGHT;
      bsetting1 = BRIGHT + BIAS1;
    else if (rawvalue <= LOLIMIT) {
      bsetting0 = DIM + BIAS0;
      bsetting1 = DIM;
    if (bsetting0 != lastsetting) {
      matrix0.setBrightness(bsetting0);
      matrix1.setBrightness(bsetting1);
    if (DEBUG & DBBRIGHT) {
      sprintf(sbuffer, "Raw %d Settings %d %d\n",  rawvalue, bsetting0, bsetting1);
    lastsetting = bsetting0;
  } // setBrightness
#endif
#ifdef WAKEUP
  // wakeup
  // A little "Teddy Ruxpin" inspired animation.
  void wakeup() {
    uint8_t i;
    for (i = 0; i < 2; i++) {
      closeeyes(500);
      openeyes(250);
    while(!GPS.fix) {
        GPS.parse(GPS.lastNMEA());
      lookaround();
      //matrix0.clear();
  } // wakeup
  // Segment layout:
  //The decimal point is mapped to 0x80.
  //       0x01
  // 0x20 |    |0x02
  // 0x10 |0x40|0x04
  //       0x08
  void closeeyes(uint8_t dly) {
    matrix0.writeDigitRaw(1, 0x08);
    matrix0.writeDigitRaw(3, 0x08);
    delay(dly);
  } // closeeyes
  void openeyes(uint8_t dly) {
    matrix0.writeDigitRaw(1, 0x08 | 0x10 | 0x40 | 0x04);
    matrix0.writeDigitRaw(3, 0x08 | 0x10 | 0x40 | 0x04);
    delay(dly);
  } // openeyes
  void lookaround() {
    matrix0.clear();
    matrix0.writeDigitRaw(0, 0x40 | 0x20 | 0x01 | 0x02);
    matrix0.writeDigitRaw(1, 0x40 | 0x20 | 0x01 | 0x02);
    delay(1000);
    //matrix0.clear();
    //matrix0.writeDigitRaw(0, 0);
    //matrix0.writeDigitRaw(1, 0x40 | 0x20 | 0x01 | 0x02);
    //matrix0.writeDigitRaw(3, 0x40 | 0x20 | 0x01 | 0x02);
    //matrix0.writeDisplay();
    //delay(50);
    matrix0.clear();
    matrix0.writeDigitRaw(4, 0x40 | 0x20 | 0x01 | 0x02);
    delay(1000);
  } // lookaround
#endif
That should get you started.
Rick Comito
Return to “Arduino”
