What kind of servo library is needed when using the Wave Shi
- isaace
Re: What kind of servo library is needed when using the Wave
When I run my code (as it was shown in my reply from 6:04pm yesterday) only the servo moves, but it does not play wave files.
- Franklin97355
Your code keeps changing. Could you post your code as you are running it now?
As explained in my previous post. Your code never initializes the SD card, so no files are ever played.When I run my code (as it was shown in my reply from 6:04pm yesterday) only the servo moves, but it does not play wave files.
No. I am referring to what is in your posted code.You are referring to what is in your posted code?
- isaace
It is still the same as yesterday at 6:04. I haven't changed it.
#include <WaveHC.h>
#include <WaveUtil.h>
#include <Wire.h>
#include <Adafruit_PWMServoDriver.h>
Adafruit_PWMServoDriver pwm = Adafruit_PWMServoDriver();
#define SERVOMIN 150 // this is the 'minimum' pulse length count (out of 4096)
#define SERVOMAX 600 // this is the 'maximum' pulse length count (out of 4096)
SdReader card; // This object holds the information for the card
FatVolume vol; // This holds the information for the partition on the card
FatReader root; // This holds the information for the volumes root directory
WaveHC wave; // This is the only wave (audio) object, since we will only play one at a time
int degrees;
int ServoPulse(int degrees)
return map(degrees, 0, 180, SERVOMIN, SERVOMAX);
uint8_t servonum = 0;
uint8_t dirLevel; // indent level for file/dir names (for prettyprinting)
dir_t dirBuf; // buffer for directory reads
* Define macro to put error messages in flash memory
#define error(msg) error_P(PSTR(msg))
// Function definitions (we define them here, but the code is below)
void play(FatReader &dir);
//////////////////////////////////// SETUP
Serial.begin(9600);
Serial.println("16 channel Servo test!");
pwm.begin();
pwm.setPWMFreq(60); // Analog servos run at ~60 Hz updates
void setServoPulse(uint8_t n, double pulse) {
double pulselength;
pulselength = 1000000; // 1,000,000 us per second
pulselength /= 60; // 60 Hz
Serial.print(pulselength); Serial.println(" us per period");
pulselength /= 4096; // 12 bits of resolution
Serial.print(pulselength); Serial.println(" us per bit");
pulse *= 1000;
pulse /= pulselength;
Serial.println(pulse);
pwm.setPWM(n, 0, pulse);
// Serial.begin(9600); // set up Serial library at 9600 bps for debugging
putstring_nl("\nWave test!"); // say we woke up!
putstring("Free RAM: "); // This can help with debugging, running out of RAM is bad
Serial.println(FreeRam());
// if (!card.init(true)) { //play with 4 MHz spi if 8MHz isn't working for you
if (!card.init()) { //play with 8 MHz spi (default faster!)
error("Card init. failed!"); // Something went wrong, lets print out why
// enable optimize read - some cards may timeout. Disable if you're having problems
card.partialBlockRead(true);
// Now we will look for a FAT partition!
uint8_t part;
for (part = 0; part < 5; part++) { // we have up to 5 slots to look in
if (vol.init(card, part))
break; // we found one, lets bail
if (part == 5) { // if we ended up not finding one :(
error("No valid FAT partition!"); // Something went wrong, lets print out why
// Lets tell the user about what we found
putstring("Using partition ");
Serial.print(part, DEC);
putstring(", type is FAT");
Serial.println(vol.fatType(), DEC); // FAT16 or FAT32?
// Try to open the root directory
if (!root.openRoot(vol)) {
error("Can't open root dir!"); // Something went wrong,
// Whew! We got past the tough parts.
putstring_nl("Files found (* = fragmented):");
// Print out all of the files in all the directories.
root.ls(LS_R | LS_FLAG_FRAGMENTED);
//////////////////////////////////// LOOP
pwm.setPWM(servonum, 0, ServoPulse(180));
delay(500);
pwm.setPWM(servonum, 0, ServoPulse(0));
delay(500);
pwm.setPWM(servonum, 0, ServoPulse(90));
delay(500);
pwm.setPWM(servonum, 0, ServoPulse(120));
delay(500);
root.rewind();
play(root);
/////////////////////////////////// HELPERS
* print error message and halt
void error_P(const char *str) {
PgmPrint("Error: ");
SerialPrint_P(str);
sdErrorCheck();
while(1);
* print error message and halt if SD I/O error, great for debugging!
void sdErrorCheck(void) {
if (!card.errorCode()) return;
PgmPrint("\r\nSD I/O error: ");
Serial.print(card.errorCode(), HEX);
PgmPrint(", ");
Serial.println(card.errorData(), HEX);
while(1);
* play recursively - possible stack overflow if subdirectories too nested
void play(FatReader &dir) {
FatReader file;
while (dir.readDir(dirBuf) > 0) { // Read every file in the directory one at a time
// Skip it if not a subdirectory and not a .WAV file
if (!DIR_IS_SUBDIR(dirBuf)
&& strncmp_P((char *)&dirBuf.name[8], PSTR("WAV"), 3)) {
continue;
Serial.println(); // clear out a new line
for (uint8_t i = 0; i < dirLevel; i++) {
Serial.write(' '); // this is for prettyprinting, put spaces in front
if (!file.open(vol, dirBuf)) { // open the file in the directory
error("file.open failed"); // something went wrong
if (file.isDir()) { // check if we opened a new directory
putstring("Subdir: ");
printEntryName(dirBuf);
Serial.println();
dirLevel += 2; // add more spaces
// play files in subdirectory
play(file); // recursive!
dirLevel -= 2;
else {
// Aha! we found a file that isnt a directory
putstring("Playing ");
printEntryName(dirBuf); // print it out
if (!wave.create(file)) { // Figure out, is it a WAV proper?
putstring(" Not a valid WAV"); // ok skip it
} else {
Serial.println(); // Hooray it IS a WAV proper!
wave.play(); // make some noise!
uint8_t n = 0;
while (wave.isplaying) {// playing occurs in interrupts, so we print dots in realtime
putstring(".");
if (!(++n % 32))Serial.println();
delay(100);
sdErrorCheck(); // everything OK?
// if (wave.errors)Serial.println(wave.errors); // wave decoding errors
You need to move the SD card initialization and directory operations back into setup() as they are in the daphc example code you started with.
As you have it now, that code has been merged into your setServoPulse() function. Since you never call that function, the SD card never gets initialized and no files are available to play.
- isaace
Ok, thanks! Now it is playing the wave files and the servo, but not simultaneously. First, the servo, then the waves, then the servo and so on.
How can I get them to play at the exact same time? I commented out the setServoPulse() function. I figured that would be the same as what you recommended.
Thanks for your help and patience.
Isaac
Isaac
#include <WaveHC.h>
#include <Wire.h>
int degrees;
Serial.begin(9600);
pwm.begin();
/* void setServoPulse(uint8_t n, double pulse) {
double pulselength;
pulse *= 1000;
pwm.setPWM(n, 0, pulse); */
uint8_t part;
delay(500);
delay(500);
delay(500);
delay(500);
root.rewind();
play(root);
SerialPrint_P(str);
sdErrorCheck();
while(1);
PgmPrint(", ");
while(1);
FatReader file;
continue;
Serial.println();
dirLevel -= 2;
else {
} else {
uint8_t n = 0;
putstring(".");
delay(100);
You still have that while loop in your play function. That keeps your from returning from the play function until the file has finished playing. You need to remove that if you want to keep moving the servos.
putstring(".");
delay(100);
- isaace
Thanks, so I tried by commenting it out. Now just the servo moves and I don't hear the wave files. According to the serial, it looks like it thinks its playing the waves.
Estimated pre-scale: 112.03
Final pre-scale: 112
Wave test!
Free RAM: 381
Using partition 1, type is FAT16
BATHROOM.WAV
NAME.WAV
BYE.WAV
UM.WAV
FROM.WAV
HELLO.WAV
HI.WAV
AREYOU.WAV
Playing BATHROOM.WAV
Playing NAME.WAV
Playing BYE.WAV
Playing UM.WAV
Playing FROM.WAV
Playing HELLO.WAV Not a valid WAV
Playing HI.WAV Not a valid WAV
Playing AREYOU.WAV Not a valid WAV
Playing NAME.WAV
Playing BYE.WAV
Playing UM.WAV
Playing FROM.WAV
Playing NAME.WAV
Playing BYE.WAV
Playing UM.WAV
Playing FROM.WAV
Playing NAME.WAV
Playing BYE.WAV
Playing UM.WAV
Playing FROM.WAV
#include <WaveHC.h>
#include <Wire.h>
int degrees;
Serial.begin(9600);
pwm.begin();
double pulselength;
pulse *= 1000;
uint8_t part;
delay(500);
delay(500);
delay(500);
delay(500);
root.rewind();
play(root);
SerialPrint_P(str);
sdErrorCheck();
while(1);
PgmPrint(", ");
while(1);
FatReader file;
continue;
Serial.println();
dirLevel -= 2;
else {
} else {
uint8_t n = 0;
/* while (wave.isplaying) {// playing occurs in interrupts, so we print dots in realtime
putstring(".");
delay(100); */
Your function is trying to play the entire directory. It skip through the whole list. And since the last file is not a valid wav file it ends up not laying anything.
You need to decide which files you want to play and pay those. The playfile function from Play6 is a better example to start from.
https://learn.adafruit.com/adafruit-wav ... o/play6-hc
void playfile(char *name) {
// see if the wave object is currently doing something
if (wave.isplaying) {// already playing something, so stop it!
wave.stop(); // stop it
// look in the root directory and open the file
if (!f.open(root, name)) {
putstring("Couldn't open file "); Serial.print(name); return;
// OK read the file and turn it into a wave object
if (!wave.create(f)) {
putstring_nl("Not a valid WAV"); return;
// ok time to play! start playback
wave.play();
- isaace
Ok, I am back. I admit. I have changed the code significantly. I am still using the PCA and wave shield, with BitVoicer. When I say a specific command, I want the servo and wave to play simultaneously. It works, but the waves don't play regardless of which command I give. Note that the commands are hello, name, goodbye, etc.
As soon as I comment out this line, it works, but it gives me the same result for every command: //if (bvSerial.strData == "hello"
If I don't comment it out, it works like it is supposed to, but I don't get the servo. By the way, as you can see I added some h-bridge code in there to drive a PMDC. It seems to react just like the servo, but other than that, it doesn't interfere with what is going on.
#include <FatReader.h>
#include <SdReader.h>
#include <avr/pgmspace.h>
#include "WaveUtil.h"
#include "WaveHC.h"
#include <BitVoicer11.h>
#include <Wire.h>
int led = 6;
BitVoicerSerial bvSerial = BitVoicerSerial(); //Stores true if the Audio Streaming Calibration tool is running
boolean sampleTest = false; //Stores the data type retrieved by getData()
byte dataType = 0; //Sets up the pins and default variables
FatReader root; // This holds the information for the filesystem on the card
FatReader f; // This holds the information for the file we're play
int mot1ana=6;
int mot1a=1;
int mot1b=8;
int degrees;
#define DEBOUNCE 5 // button debouncer
// here is where we define the buttons that we'll use. button "1" is the first, button "6" is the 6th, etc
byte buttons[] = {14, 15, 16, 17, 18, 19};
// This handy macro lets us determine how big the array up above is, by checking the size
#define NUMBUTTONS sizeof(buttons)
// we will track if a button is just pressed, just released, or 'pressed' (the current state
volatile byte pressed[NUMBUTTONS], justpressed[NUMBUTTONS], justreleased[NUMBUTTONS];
// this handy function will return the number of bytes currently free in RAM, great for debugging!
int freeRam(void)
extern int __bss_end;
extern int *__brkval;
int free_memory;
if((int)__brkval == 0) {
free_memory = ((int)&free_memory) - ((int)&__bss_end);
else {
free_memory = ((int)&free_memory) - ((int)__brkval);
return free_memory;
putstring("\n\rSD I/O error: ");
putstring(", ");
while(1);
pinMode(mot1ana,OUTPUT);
pinMode(mot1a,OUTPUT);
pinMode(mot1b,OUTPUT);
pwm.begin();
pinMode(led, OUTPUT);
bvSerial.setAudioInput(1);
Serial.begin(115200); //Sets up the pinModes
byte i;
putstring_nl("WaveHC with ");
Serial.print(NUMBUTTONS, DEC);
putstring_nl("buttons");
Serial.println(freeRam()); // if this is under 150 bytes it may spell trouble!
for (i=0; i< NUMBUTTONS; i++) {
pinMode(buttons[i], INPUT);
digitalWrite(buttons[i], HIGH);
putstring_nl("Card init. failed!"); // Something went wrong, lets print out why
sdErrorCheck();
while(1); // then 'halt' - do nothing!
uint8_t part;
putstring_nl("No valid FAT partition!");
sdErrorCheck(); // Something went wrong, lets print out why
Serial.println(vol.fatType(),DEC); // FAT16 or FAT32?
putstring_nl("Can't open root dir!"); // Something went wrong,
putstring_nl("Ready!");
TCCR2A = 0;
TCCR2B = 1<<CS22 | 1<<CS21 | 1<<CS20;
//Timer2 Overflow Interrupt Enable
TIMSK2 |= 1<<TOIE2;
SIGNAL(TIMER2_OVF_vect) {
check_switches();
void check_switches()
static byte previousstate[NUMBUTTONS];
static byte currentstate[NUMBUTTONS];
byte index;
for (index = 0; index < NUMBUTTONS; index++) {
currentstate[index] = digitalRead(buttons[index]); // read the button
if (currentstate[index] == previousstate[index]) {
if ((pressed[index] == LOW) && (currentstate[index] == LOW)) {
// just pressed
justpressed[index] = 1;
else if ((pressed[index] == HIGH) && (currentstate[index] == HIGH)) {
// just released
justreleased[index] = 1;
pressed[index] = !currentstate[index]; // remember, digital HIGH means NOT pressed
//Serial.println(pressed[index], DEC);
previousstate[index] = currentstate[index]; // keep a running tally of the buttons
if (sampleTest == true)
bvSerial.BANNED(46);
if (bvSerial.engineRunning)
void serialEvent()
dataType = bvSerial.getData();
if (dataType == BV_COMMAND)
sampleTest = bvSerial.cmdData;
if (dataType == BV_STATUS && bvSerial.engineRunning == true)
bvSerial.startStopListening();
if (dataType == BV_STR)
//if (bvSerial.strData == "hello")
playcomplete("hello.WAV");
delay(500);
delay(500);
delay(500);
delay(500);
analogWrite(mot1ana,500); //Forward left
digitalWrite(mot1a,HIGH);
digitalWrite(mot1b,LOW);
delay(2000);
digitalWrite(mot1a,LOW);
delay(200);
digitalWrite(mot1b,HIGH);
delay(2000);
delay(200);
// if (bvSerial.strData == "hi")
// playcomplete("hello.wav");
if (bvSerial.strData == "name")
playcomplete("name.wav");
if (bvSerial.strData == "bathroom")
playcomplete("bathroom.WAV");
if (bvSerial.strData == "from")
playcomplete("from.WAV");
if (bvSerial.strData == "bye")
playcomplete("bye.WAV");
if (bvSerial.strData == "creator")
playcomplete("creator.WAV");
if (bvSerial.strData == "um")
playcomplete("um.WAV");
byte i;
void playcomplete(char *name) {
playfile(name);
// now its done playing
wave.play();
- Franklin97355
What result is that?it works, but it gives me the same result for every command: //if (bvSerial.strData == "hello"
- isaace
If I comment out the said line (189) it does the same thing, regardless of what word I say. I could say 'hello,' 'bye' or 'from' and it plays the same "hello" wave file and simultaneously moves the servos and DC motors accordingly. I just want different commands to control a different arrangement of outputs, especially a different wave file.
If I don't comment out 'if (bvSerial.strData == "hello")' then it doesn't play any wave file. Only the servos and the DC motor actuate as programmed.
I have several command words loaded into the Bitvoicer GUI. You can see them in lines 190 and 218 through 228.
Isaac
Isaac
- Franklin97355
If you replace the "hello" in the "if" line with one of the other phrases does it work? It looks like your if statements are not working.
- isaace
If I replace "hello" in line 190 [playcomplete("hello.WAV")] with 'name,' then it plays the "name.wav" file regardless of what I say (as long as I use one of my commands).
If I change the said IF statement (on line 189) from "hello" to 'name,' then I still don't get any wave files to play (unless I comment out the if statement).
- Franklin97355
Then you have a problem with the bitvoice library and you should ask these questions on their site. There seems to be nothing wrong with the wave shield or your microcontroller.
