So far I have modded the Untzrument step sequencer code, the mini OOntz arpeggiator code, and the original mini untztrument code to suit a singletrellis. Usb-Midi with a TeenOnArdu is working fine. What I want to do is have a setup program which reads the switches on the trellis and picks a mode so that I can have all 3 sketches stored on the arduino and choose which one I want to use when I am using the mini Untztrument. How would I go about combining three different code "apps" so I could choose between them at startup using the trellis keypad? Would this be hard to implement. I have a very basic understanding of Arduino coding.
the code I'm using
// Simple UNTZtrument MIDI step sequencer.
// Requires an Arduino Leonardo w/TeeOnArdu config (or a PJRC Teensy),
// software on host computer for synth or to route to other devices.
#include <Wire.h>
#include <Adafruit_Trellis.h>
#include <Adafruit_UNTZtrument.h>
#define LED 13 // Pin for heartbeat LED (shows code is working)
#ifndef HELLA
// A standard UNTZtrument has four Trellises in a 2x2 arrangement
// (8x8 buttons total). addr[] is the I2C address of the upper left,
// upper right, lower left and lower right matrices, respectively,
// assuming an upright orientation, i.e. labels on board are in the
// normal reading direction.
Adafruit_Trellis T[4];
Adafruit_UNTZtrument untztrument(&T[3]);
const uint8_t addr[] = { 0x70, 0x71, 0x72, 0x73 };
#else
// A HELLA UNTZtrument has eight Trellis boards...
Adafruit_Trellis T[8];
Adafruit_UNTZtrument untztrument(&T[0], &T[1], &T[2], &T[3],
&T[4], &T[5], &T[6], &T[7]);
const uint8_t addr[] = { 0x70, 0x71, 0x72, 0x73,
0x74, 0x75, 0x76, 0x77 };
#endif // HELLA
#define WIDTH ((sizeof(T) / sizeof(T[3])) * 1)
#define N_BUTTONS ((sizeof(T) / sizeof(T[0])) * 16)
// Encoder on pins 4,5 sets tempo. Optional, not present in
// standard UNTZtrument, but won't affect things if unconnected.
enc e(4, 5);
uint8_t grid[WIDTH]; // Sequencer state
uint8_t heart = 0, // Heartbeat LED counter
col = WIDTH-1; // Current column
unsigned int bpm = 240; // Tempo
unsigned long beatInterval = 60000L / bpm, // ms/beat
prevBeatTime = 0L, // Column step timer
prevReadTime = 0L; // Keypad polling timer
// The note[] and channel[] tables are the MIDI note and channel numbers
// for to each row (top to bottom); they're specific to this application.
// bitmask[] is for efficient reading/writing bits to the grid[] array.
static const uint8_t PROGMEM
note[8] = { 72, 71, 69, 67, 65, 64, 62, 60 },
channel[8] = { 1, 1, 1, 1, 1, 1, 1, 1 },
bitmask[8] = { 1, 2, 4, 8, 16, 32, 64, 128 };
pinMode(LED, OUTPUT);
#ifndef HELLA
untztrument.begin(addr[0], addr[1], addr[2], addr[3]);
#else
untztrument.begin(addr[0], addr[1], addr[2], addr[3],
addr[4], addr[5], addr[6], addr[7]);
#endif // HELLA
#ifdef __AVR__
// Default Arduino I2C speed is 100 KHz, but the HT16K33 supports
// 400 KHz. We can force this for faster read & refresh, but may
// break compatibility with other I2C devices...so be prepared to
// comment this out, or save & restore value as needed.
TWBR = 12;
#endif
untztrument.clear();
untztrument.writeDisplay();
memset(grid, 0, sizeof(grid));
e.setBounds(60 * 4, 480 * 4 + 3); // Set tempo limits
e.setValue(bpm * 4); // *4's for encoder detents
// Turn on (or off) one column of the display
void line(uint8_t x, boolean set) {
for(uint8_t mask=1, y=0; y<8; y++, mask <<= 1) {
uint8_t i = untztrument.xy2i(x, y);
if(set || (grid[x] & mask)) untztrument.setLED(i);
else untztrument.clrLED(i);
uint8_t mask;
boolean refresh = false;
unsigned long t = millis();
enc::poll(); // Read encoder(s)
if((t - prevReadTime) >= 20L) { // 20ms = min Trellis poll time
if(untztrument.readSwitches()) { // Button state change?
for(uint8_t i=0; i<N_BUTTONS; i++) { // For each button...
uint8_t x, y;
untztrument.i2xy(i, &x, &y);
mask = pgm_read_byte(&bitmask[y]);
if(untztrument.justPressed(i)) {
if(grid[x] & mask) { // Already set? Turn off...
grid[x] &= ~mask;
usbMIDI.sendNoteOff(pgm_read_byte(¬e[y]),
127, pgm_read_byte(&channel[y]));
} else { // Turn on
grid[x] |= mask;
refresh = true;
prevReadTime = t;
digitalWrite(LED, ++heart & 32); // Blink = alive
if((t - prevBeatTime) >= beatInterval) { // Next beat?
// Turn off old column
line(col, false);
for(uint8_t row=0, mask=1; row<8; row++, mask <<= 1) {
if(grid[col] & mask) {
usbMIDI.sendNoteOff(pgm_read_byte(¬e[row]), 127,
pgm_read_byte(&channel[row]));
// Advance column counter, wrap around
if(++col >= WIDTH) col = 0;
// Turn on new column
line(col, true);
usbMIDI.sendNoteOn(pgm_read_byte(¬e[row]), 127,
prevBeatTime = t;
refresh = true;
bpm = e.getValue() / 4; // Div for encoder detents
beatInterval = 60000L / bpm;
if(refresh) untztrument.writeDisplay();
while(usbMIDI.read()); // Discard incoming MIDI messages
// OONTZ ARPY
// Arpeggiator for the Adafruit OONTZ & HELLA OONTZ
// Plays a MIDI note sequence relative to button pressed
// For HELLA OONTZ change HELLA value to 1 (line 20)
// For external MIDI clock sync change EXT_CLOCK value to 1 (line 21)
// Scale can be chosen by specifying a mode on line 129
// Optional hardware:
// Pattern control - connect rotary encoder to pins 4 & 5
// Tempo control - connect rotary encoder to pins 8 & 9
void setup(); // Added to avoid Arduino IDE #ifdef bug
#include <Wire.h>
#include <Adafruit_OONTZ.h>
#define CHANNEL 1 // MIDI channel number
#define HELLA 0 // 0 for standard OONTZ, 1 for HELLA OONTZ
#define EXT_CLOCK 0 // 0 for internal clock, 1 for external
#if HELLA
OONTZ oontz(&T[3]);
#else
OONTZ oontz(&T[3]);
0x72, 0x73 };
#endif
#define HEIGHT (N_BUTTONS / WIDTH)
#define ARP_NOTES 6
#define NULL_INDEX 255
uint8_t heart = 0; // Heartbeat LED counter
unsigned long prevReadTime = 0L; // Keypad polling timer
//bool extClock = true;
uint8_t quantDiv = 8; // Quantization division, 2 = half note
uint8_t clockPulse = 0;
#define QUANT_PULSE (96/quantDiv)// Number of pulses per quantization division
uint8_t noteDivs[] = { 1,2,4,8,16,32};
// Note patterns for arpeggiator
int8_t
arpA[ARP_NOTES][2] = {
{ 0, 0 },
{ -1, -1 },
{ 1, -1 },
{ 1, 1 },
{ -1, 1 },
{ -1, 1 },
arpB[ARP_NOTES][2] = {
{ 0, 0 },
{ 1, -1 },
{ 2, -2 },
{ 2, -2 },
{ 1, -1 },
{ 2, -1 },
arpC[ARP_NOTES][2] = {
{ 0, 0 },
{ -1, 0 },
{ 0, 0 },
{ 0, -1 },
{ 0, 0 },
{ 1, 0 },
arpD[ARP_NOTES][2] = {
{ 0, 0 },
{ 1, 0 },
{ 0, 0 },
{ 1, 0 },
{ 1, 2 },
{ 1, 2 }
arpE[ARP_NOTES][2] = {
{ 0, 0 },
{ 1, 0 },
{ 2, 0 },
{ 3, 0 },
{ 3, 1 },
{ 2, 1 }
arpF[ARP_NOTES][2] = {
{ 0, 0 },
{ 1, 0 },
{ -1, 0 },
{ 2, 0 },
{ -2, 0 },
{ 0, 0 }
arpG[ARP_NOTES][2] = {
{ 0, 0 },
{ 1, -1 },
{ 2, 0 },
{ 3, -1 },
{ 2, -1 },
{ 1, 0 }
int8_t (*arpCollection[])[ARP_NOTES][2] = { &arpA, &arpB, &arpC, &arpD,
&arpE, &arpF, &arpG };
uint8_t arpCount = sizeof(arpCollection) / sizeof(arpCollection[0]);
int8_t (*arp)[ARP_NOTES][2] = &(*arpCollection)[0];
uint8_t pitchMap[N_BUTTONS];
// Musical mode/scale intervals
uint8_t chromatic[12] = { 0, 1, 2, 3, 4, 5, 6, 7, 8, 9,10,11 },
ionian[12] = { 0, 0, 2, 4, 4, 5, 5, 7, 7, 9,11,11 },
dorian[12] = { 0, 0, 2, 3, 3, 5, 5, 7, 7, 9,10,10 },
phrygian[12] = { 0, 1, 2, 3, 3, 5, 5, 7, 8, 8,10,10 },
lydian[12] = { 0, 0, 2, 2, 4, 4, 6, 7, 7, 9,10,11 },
mixolydian[12] = { 0, 0, 2, 2, 4, 5, 5, 7, 7, 9,10,10 },
aeolian[12] = { 0, 0, 2, 3, 3, 5, 5, 7, 8, 8,10,10 },
locrian[12] = { 0, 1, 1, 3, 3, 5, 6, 6, 8, 8,10,10 };
uint8_t (*scale)[12] = &dorian; // Chosen scale
uint8_t firstNote = 16, // First note, upper left of grid
colIntvl = 10, // Semitones between each column
rowIntvl = 5; // Semitones between each row
boolean pressedButtonIndex[N_BUTTONS] = {false}; // Pressed state for each button
uint8_t arpSeqIndex[N_BUTTONS] = {NULL_INDEX}, // Current place in button arpeggio sequence
arpButtonIndex[N_BUTTONS] = {NULL_INDEX}; // Button index being played for each actual pressed button
// Encoders for tempo and arpeggio selection
enc tempoEncoder(8, 9);
enc arpEncoder(4, 5);
unsigned int bpm = 320; // Tempo
prevArpTime = 0L;
//uint8_t arpVelocityMax = 102,
// arpVelocityMin = 65;
void setup(){
// 8x8
if (WIDTH <= 8) {
oontz.begin(addr[0], addr[1], addr[2], addr[3]);
// HELLA 16x8
else{
oontz.begin(addr[0], addr[1], addr[2], addr[3],
#ifdef __AVR__
TWBR = 12;
#endif
oontz.clear();
oontz.writeDisplay();
#if EXT_CLOCK
// Set up tempo encoder for External clock mode
uint8_t divCount = sizeof(noteDivs) / sizeof(noteDivs[0]) -1;
tempoEncoder.setBounds(0, divCount * 4, true); // Set tempo limits
tempoEncoder.setValue(3 * 4); // *4's for encoder detents
#else
// Set up tempo encoder for Internal clock mode
tempoEncoder.setBounds(60 * 4, 480 * 4 + 3); // Set tempo limits
tempoEncoder.setValue(bpm * 4); // *4's for encoder detents
#endif
//Set up arpeggio pattern encoder
arpEncoder.setBounds(0, arpCount * 4 - 1, true);
arpEncoder.setValue(6 * 4);
//Set up the note for the grid
writePitchMap();
#if EXT_CLOCK
usbMIDI.setHandleRealTimeSystem(handleRealTimeSystem);
#endif
void loop(){
checkMidi();
unsigned long tDiff = t - prevReadTime;
if(tDiff >= 20L) { // 20ms = min Trellis poll time
if(oontz.readSwitches()) { // Button state change?
//Button was pressed
if(oontz.justPressed(i)) {
//add note to pressed buttons array
pressedButtonIndex[i] = true;
//Button was released
else if(oontz.justReleased(i)) {
//remove note from pressed buttons array
pressedButtonIndex[i] = false;
stopArp(i);
// Iterate array, play arp sequence for pressed buttons
#if EXT_CLOCK
// EXTERNAL CLOCK
//Set note length from encoder value
quantDiv = noteDivs[tempoEncoder.getValue() / 4];
#else
// INTERNAL CLOCK
if ((t - prevArpTime) >= beatInterval) {
respondToPresses();
prevArpTime = t;
//Set Tempo from encoder value
bpm = tempoEncoder.getValue() / 4; // Div for encoder detents
#endif
//Set current arp notes
int16_t arpIndex = arpEncoder.getValue() / 4;
arp = &(*arpCollection)[arpIndex];
//update LEDs
prevReadTime = t;
void checkMidi(){
#if EXT_CLOCK
// EXTERNAL CLOCK
usbMIDI.read(CHANNEL);
#else
// INTERNAL CLOCK
while(usbMIDI.read(CHANNEL)); // Discard incoming MIDI messages
#endif
void handleRealTimeSystem(uint8_t data){
if (data == 0xF8) { // Clock pulse
clockPulse++;
if (clockPulse > 96) { //MIDI clock sends 24 pulses per quarter note
clockPulse = 1;
else if ((clockPulse % QUANT_PULSE) == 0){
respondToPresses();
else if (data == 0xFA){ // START message
clockPulse = 0;
// else if (data == 0xFC){ // STOP message
// else if (data == 0xFB){ // CONTINUE message
void writePitchMap(){
//Write first row of notes, establish column intervals
for (int i = 0; i < WIDTH; i++){
pitchMap[i] = i * colIntvl + firstNote;
//Write remaining rows, first row + row intervals
for (int i = WIDTH; i < N_BUTTONS; i++) {
pitchMap[i] = i / WIDTH * rowIntvl + pitchMap[i%WIDTH];
//Apply diatonic filter - TESTING
for (int i = 0; i < N_BUTTONS; i++) {
uint8_t deg = pitchMap[i] % 12;
uint8_t oct = pitchMap[i] / 12;
pitchMap[i] = oct * 12 + (*scale)[deg];
//Test notes
// int x,y = 0;
// for (int i = 0; i < (WIDTH); i++) {
// if (x >= WIDTH){ x = 0; y++; }
// if (y >= HEIGHT) { break; }
// uint8_t index = oontz.xy2i(x,y);
// playNoteForButton(index);
// delay(200);
// oontz.writeDisplay();
// delay(20);
// stopNoteForButton(index);
// x++;
void respondToPresses(){
for (uint8_t i=0; i < N_BUTTONS; i++) {
if (pressedButtonIndex[i]) {
playArp(i);
void setAllLEDs(bool lit){
if (lit) {
oontz.setLED(i);
else{
oontz.clrLED(i);
void playArp(uint8_t buttonIndex){
uint8_t seqIndex, seqButtonIndex, seqNote,
x, y;
seqIndex = arpSeqIndex[buttonIndex] + 1;
// Loop sequence
if (seqIndex >= ARP_NOTES) {
seqIndex = 0;
// Find current button coordinates
oontz.i2xy(buttonIndex, &x, &y);
// Add note offsets
x = (int8_t)x + (*arp)[seqIndex][0];
y = (int8_t)y + (*arp)[seqIndex][1];
// Wrap notes to grid
if (x >= WIDTH) {x %= WIDTH;}
if (y >= HEIGHT) {y %= HEIGHT;}
// Find new note and index
seqNote = findNoteFromXY(x, y);
seqButtonIndex = oontz.xy2i(x, y);
// Stop prev note in sequence
stopNoteForButton(arpButtonIndex[buttonIndex]);
// Store new note
arpSeqIndex[buttonIndex] = seqIndex;
arpButtonIndex[buttonIndex] = seqButtonIndex;
// Play new note
playNoteForButton(seqButtonIndex);
void stopAll(){
stopArp(i);
void stopArp(uint8_t button){
//stop playing the note
stopNoteForButton(arpButtonIndex[button]);
//store an invalid button index in its place
arpSeqIndex[button] = NULL_INDEX; //check for invalid
uint8_t findNoteFromIndex(uint8_t buttonIndex){
uint8_t x, y;
return findNoteFromXY(x,y);
uint8_t findNoteFromXY(uint8_t x, uint8_t y){
return pitchMap[y * WIDTH + x];
void playNoteForButton(uint8_t buttonIndex){
// Set a random velocity
// uint8_t vel = random(arpVelocityMin, arpVelocityMax);
usbMIDI.sendNoteOn(findNoteFromIndex(buttonIndex), 100, CHANNEL); //default velocity of 100
oontz.setLED(buttonIndex);
void stopNoteForButton(uint8_t buttonIndex){
usbMIDI.sendNoteOff(findNoteFromIndex(buttonIndex), 0, CHANNEL);
oontz.clrLED(buttonIndex);
#include <Wire.h>
Adafruit_Trellis trellis;
uint8_t mod;
uint8_t vel;
uint8_t fxc;
uint8_t rate;
uint8_t note[] = {
60, 61, 62, 63,
56, 57, 58, 59,
52, 53, 54, 55,
48, 49, 50, 51
trellis.begin(0x70); // Pass I2C address
#ifdef __AVR__
TWBR = 12;
#endif
trellis.clear();
trellis.writeDisplay();
if(trellis.readSwitches()) { // Button state change?
for(uint8_t i=0; i<16; i++) { // For each button...
if(trellis.justPressed(i)) {
usbMIDI.sendNoteOn(note[i], 127, CHANNEL);
trellis.setLED(i);
} else if(trellis.justReleased(i)) {
usbMIDI.sendNoteOff(note[i], 0, CHANNEL);
trellis.clrLED(i);
uint8_t newModulation = map(analogRead(0), 0, 1023, 0, 127);
if(mod != newModulation) {
mod = newModulation;
usbMIDI.sendControlChange(1, mod, CHANNEL);
uint8_t newVelocity = map(analogRead(1), 0, 1023, 0, 127);
if(vel != newVelocity) {
vel = newVelocity;
usbMIDI.sendControlChange(11, vel, CHANNEL);
uint8_t newEffect = map(analogRead(2), 0, 1023, 0, 127);
if(fxc != newEffect) {
fxc = newEffect;
usbMIDI.sendControlChange(12, fxc, CHANNEL);
uint8_t newRate = map(analogRead(3), 0, 1023, 0, 127);
if(rate !=newRate) {
rate = newRate;
usbMIDI.sendControlChange(13, rate, CHANNEL);
prevReadTime = t;
