Yun
- grogers
Yun
I think I have a defective Yun board. It occasionally works but has given me a lot of trouble. I am unable to see it as an access point, and when I do see it I am unable to connect. It did work when I first purchased it (early summer) but does not work now. I am usually unable to reset wifi -- when I push the reset button, usually nothing happens. I have another Yun, which has not given me any problems. I would like to send the defective one back and get another one.
- Franklin97355
Re: Yun
If you could describe the problems in more detail that would help. I'll see if any of the other techs have any ideas to help. Unfortunately we only have a 30 day warranty policy but you might check with the Arduino group at http://arduino.cc/en/Main/ContactUs
- subrosa
Re: Yun
The Yun has to be updated to be stable, especially on some of the first run models. I've pointed this out to the Yun team, and hopefully things will be a little more clear when you get the thing out of the box.
Once they're running the updated 1.4+ code things stabilize considerably.
It's always the top sticky post in the Arduino Yun forum: http://forum.arduino.cc/index.php?board=93.0
I'd at least try it first before sending it back!
