Hi, I am following along in the Halloween Pumpkin project, and adapting it to my sons Halloween costume. What I would like to do is replace the sensors in the original project, with a button that my son can press when needed, to play the sounds and turn on LEDs.
Are there any examples of code from other projects? Or does anyone know how I can alter the code from the halloween pumpkin project to fit my button idea?
Thank you.
Garret
How do I change the Halloween Pumpkin project from sensor to
- garret
Re: How do I change the Halloween Pumpkin project from senso
The pumpkin project code has 5 different actions responding to 5 distance ranges from the sensor. Did you want to use multiple buttons, or simplify the code to have just one action?
- garret
Yes, Im looking to simplify the action, so that one button push, both plays a wav file and turns on the LEDs. Sorry if this is a simple question, Im new to arduino.
The first step is to get the button wired up. Lesson 6 covers wiring and coding for buttons: https://learn.adafruit.com/adafruit-ard ... tal-inputs
You can eliminate the code in the loop() Just add a test for the button press and play a sound.
This code should turn on the leds and play one of 4 files at random. You can expand on that if you want.
void loop()
if (digitalRead(buttonPin) == LOW) // button press
digitalWrite(eyeleds, HIGH);
int i = random(4); // select a random track to play
switch(i)
case 0;
playcomplete("HPYHALWN.WAV");
break;
case 1;
playcomplete("SCREECH.WAV");
break;
case 2;
playcomplete("GHOULLAF.WAV");
break;
case 3;
playcomplete("BOOHAHA.WAV");
break;
digitalWrite(eyeleds, LOW);
- garret
Thank you very much for this. I will give it a shot and let you know how it goes.
- garret
So I have played around with the code and came up with this:
As you can see I swapped out the old sensor code for what you suggested, and fumbled through getting it to upload. Im sure its not 100% correct, and that is probably why Im getting weird behavior.
So, after successfully uploading the code, and testing the button. It will only play a few times before failing to play. Also since im only testing it, rather than soldering the button connections I am simply touching the wires from the bread board with a button setup to the ground and #9 pin on the WaveShield, and it plays without pressing the button.
Im sure there are a million things I did wrong. Ive attached a photo so that you can see how ive set things up. Hopefully you can see where Ive gone wrong.
Thanks again for your help,
Garret
#include <WaveHC.h>
#include <WaveUtil.h>
SdReader card; // This object holds the information for the card
FatVolume vol; // This holds the information for the partition on the card
FatReader root; // This holds the information for the volumes root directory
FatReader file; // This object represent the WAV file
WaveHC wave; // This is the only wave (audio) object, since we will only play one at a time
#define playcomplete(x) ROM_playcomplete(PSTR(x)) // save RAM by using program memory strings
int buttonApin = 9;
//#define servo 7
//#define redled 9
#define eyeleds 18
//#define mouthleds 17
//#define midmouthleds 16
//#define outermouthleds 19
void setup()
pinMode(buttonApin, INPUT_PULLUP);
void loop()
if (digitalRead(buttonApin) == LOW) // button press
int i = random(6); // select a random track to play
switch(i)
case 0:
playcomplete("TREX1.WAV");
break;
case 1:
playcomplete("TREX2.WAV");
break;
case 2:
playcomplete("TREX3.WAV");
break;
case 3:
playcomplete("TREX4.WAV");
break;
case 4:
playcomplete("TREX5.WAV");
break;
case 5:
playcomplete("TREX6.WAV");
break;
Serial.begin(9600); // set up Serial library at 9600 bps
Serial.println(F("Wave test!"));
pinMode(2, OUTPUT);
pinMode(3, OUTPUT);
pinMode(4, OUTPUT);
pinMode(5, OUTPUT);
//pinMode(redled, OUTPUT);
//pinMode(servo, OUTPUT);
pinMode(eyeleds, OUTPUT);
//pinMode(outermouthleds, OUTPUT);
//pinMode(midmouthleds, OUTPUT);
//pinMode(mouthleds, OUTPUT);
randomSeed(analogRead(0));
if (!card.init()) {
Serial.println(F("Card init. failed!")); return;
// enable optimize read - some cards may timeout. Disable if you're having problems
card.partialBlockRead(true);
// Now we will look for a FAT partition!
uint8_t part;
for (part = 0; part < 5; part++) { // we have up to 5 slots to look in
if (vol.init(card, part))
break; // we found one, lets bail
if (part == 5) { // if we ended up not finding one :(
Serial.println(F("No valid FAT partition!")); // Something went wrong, lets print out why
// Lets tell the user about what we found
putstring("Using partition ");
Serial.print(part, DEC);
Serial.print(F(", type is FAT"));
Serial.println(vol.fatType(), DEC); // FAT16 or FAT32?
// Try to open the root directory
if (!root.openRoot(vol)) {
Serial.println(F("Can't open root dir!")); // Something went wrong,
// Whew! We got past the tough parts.
Serial.println(F("Files found (* = fragmented):"));
// Print out all of the files in all the directories.
root.ls(LS_R | LS_FLAG_FRAGMENTED);
void pulseServo(uint8_t servopin, uint16_t p) {
digitalWrite(servopin, HIGH);
delayMicroseconds(600);
while (p--) {
delayMicroseconds(4);
digitalWrite(servopin, LOW);
delay(18);
uint8_t pumpkinstate = 0;
void ROM_playcomplete(const char *romname) {
char name[13], i;
uint8_t volume;
int v2;
for (i=0; i<13; i++) {
name[i] = pgm_read_byte(&romname[i]);
name[12] = 0;
Serial.println(name);
playfile(name);
while (wave.isplaying) {
volume = 0;
for (i=0; i<8; i++) {
v2 = analogRead(1) - 512;
if (v2 < 0)
v2 *= -1;
if (v2 > volume)
volume = v2;
delay(5);
file.close();
void playfile(char *name) {
if (!file.open(root, name)) {
Serial.println(F(" Couldn't open file")); return;
if (!wave.create(file)) {
Serial.println(F(" Not a valid WAV")); return;
// ok time to play!
wave.play();
Garret
- IMG_20141023_233421.jpg (181.55 KiB) Viewed 336 times
You have all your card initialization at the end of your loop. It should be in the setup as in the tutorial code.
- garret
After switching the order of the code its all working now. Thank you very much!!!
Good to hear. Hope your son has a good Halloween!
