Hi All,
Shifted my focus to motors tonight and came across a very weird issue. My v2 shield has been acting up. As soon as I plug in a power source (12V) (and yes, I checked the polarity) the driver chip heats up to BURNING HOT (like, finger-burning-hot!) and no motor movement. I disconnected and it cools nearly instantly. I checked for any pieces of wayward wiring causing a short, nada. Solder is good, no pins are soldered together.
Any ideas? Is my board shot?
Motor Shield v2 no movement, extreme heat
- ppsieradzki
Re: Motor Shield v2 no movement, extreme heat
That doesn't sound good. Was there a motor connected at the time? Post photos of the board and your connections.
- ppsieradzki
There was. There was some stuttering of the motor and then nothing, so I felt the board and nearly burned myself and quickly yanked the power cord from the outlet to try to save it.
Picture of top (rocking the shield on a Mega 2560 r1): (the whiteout on one of the chips is so that I can tell which one is which more easily from a small distance (project is in a very tight enclosure))
- ppsieradzki
What kind of motor did you have connected? And which components were getting hot?
- ppsieradzki
The motor was the NEMA17 sold by Adafruit. I check the product picture every time to make sure my wiring is correct, so I don't think it's the motor or the wiring.
The component(s) that get hot are the two ICs towards either end of the board (like the one I marked in WhiteOut and it's "partner" across the board). And not just hot, like, burning hot. I must add that I've used this very board for a few different occasions with no problems, and I'm using the same exact Arduino and power supply, so that eliminates other confounding factors.
That motor is a relatively easy load - unless it has an internal short circuit. But even that would only affect one of the H-bridge chips. The chances of having two similarly defective motors connected are quite remote. In any case, it is simple to test. Each coil should have a resistance of about 35 ohms.
- ppsieradzki
Ah, my motor has a short!!
Does this mean that I might've burned out my driver? Since I tested it on both H-bridges to see if it was an anomaly..
Does the shield still heat up with no motor attached? Do you have a different motor to try?
- ppsieradzki
I do indeed. I have a second NEMA17 (also from Adafruit) that I know is working. H-bridge heats up without the motor as well. The second H-bridge likely met the same fate as the first because of testing the shorted motor.
When did you purchase the motor with the short?
- ppsieradzki
Over a year ago.. to be perfectly honest it was likely my fault. I've been working around a lot of dust and debris (including grinding down aluminum extrusions and custom parts) so some metal dust probably got in there and eventually built up to the point of a short.
Thanks so much for your help, though!
