I'm trying to install Teensyduino, Version 1.20 on my Arduino 1.0.5 IDE. This is a clean install.
I Dled the teensyduino.64bit package from the http://www.pjrc.com/teensy/td_download. ... nux_issues and tried to install it.
On the site it says:
Install Step 1: Download & Extract Arduino
First, you must download the Arduino Software. Remember the location where you extracted the files.
I did this. It's in /home/arduino-1.0.5
Install Step 2: (Linux only) Install udev Rules
The udev rule file gives non-root users permission to use the Teensy device. More Linux tips below.
sudo cp 49-teensy.rules /etc/udev/rules.d/
I tried to do this and got this error:
cp: cannot stat `49-teensy.rules': No such file or directory
I followed the link found on http://www.pjrc.com/teensy/td_download. ... nux_issues
Linux udev rules
and found this:
sudo cp 49-teensy.rules /etc/udev/rules.d/49-teensy.rules
(note the difference)
I ran this and got this error:
I resoned that I may have to actually install the teensyduino into the arduino 1.0.5 before I can install the udev rule.
Install Step 3: Run Teensyduino Installer
I Dled this:
teensyduino.64bit
When I open it I got a message that some other python files needed to be installed. The installation seemed to go well enough and ran automatically.
When I tried to run the teensyduino.64bit again the PyPar2 window came up and talked about protecting my /Download directory. I allowed the window to create a series of files and put them in my /home/arduino-1.0.5 directory.
I have not yet been able to get any GUI to install the teensyduino into android 1.0.5.
I am at a loss.
Thoughts?
Install Teensyduino into Arduino IDE
- Franklin97355
Re: Install Teensyduino into Arduino IDE
Which distro are you running?
- BillFann
franklin97355,
I'm running UBUNTU 12.04.
I tried 14.04 but it had too many problems.
- BillFann
I may be making some porgress.
I think I have the 49-teensy.rules installed in my /etc/udev/rules.d/
At least when I go to that directory and do a "ls" it appears there.
I'm still having an issue with the "teensy" install program.
when I click on the icon it opens up the "pypar2" program.
That extracts
teensy.par2
teensy.vol001+02.par2
teensy.vol015+16.par2
teensy.vol003+04.par2
teensy.vol031+32.par2
teensy.vol000+01.par2
teensy.vol007+08.par2
teensy.vol063+37.par2
I cant get this to do anything.
How do I use this to create the executable for the "teensy" install programr?
That extracts
teensy.par2
- BillFann
Got it!
Go to
http://forum.pjrc.com/threads/4912-Inst ... ght=PyPar2
follow the instructions there.
Teensy is now loaded into my arduino-1.0.5 IDE.
Thank you to all who replied to this posting.
Bill
Go to
Bill
