TFT Touch Shield for Arduino mega
- andrew4
I am using the TFT Touch Shield for Arduino with a mega and saw that you needed to use the ICSP for it to work. Is there a way so you don't have to use those the ICSP pins and just use the pins that you would for the uno? Thanks.
- Franklin97355
Re: TFT Touch Shield for Arduino mega
On the Mega the SPI pins are brought out on the ICSP pins you could also run wires.
SPI: 50 (MISO), 51 (MOSI), 52 (SCK), 53 (SS). These pins support SPI communication using the SPI library. The SPI pins are also broken out on the ICSP header, which is physically compatible with the Uno, Duemilanove and Diecimila.
- andrew4
So what you are saying is connect the MISO pin on the screen to pin 50 on the arduino and so on?
