I'm working with "Arduino ultimate GPS breakout" and I'm using adafruit_GPS library. Furthermore, I'm using Arduino uno to configure with the GPS-module. TX digital pin 3, and RX digital pin 2, like in the example on the adafruit site.
I want to ask if it is possible to use digital pin 0 for RX and digital pin 1 for TX, to avoid using interrupts when receiving longitude and latitude? I could't figure it out it by my self, therefore I ask if it is possible? Like in the image below:
The problem I face is, that I already have to use digital pin 2 for another RF-module that uses interrupt. Arduino uno just has two external interrupts.
Can someone help me, please ?
Is it possible to use digital pin 0 and 1 when using GPS-mod
- Adi777
- Franklin97355
Re: Is it possible to use digital pin 0 and 1 when using GPS
You can modify the code to use pins 0 and 1 but you then can't use the USB to communicate or program without unplugging the GPS unit.
- Adi777
Hmm how to do that? I was trying to that without success, do you have any examples?
- Franklin97355
Could you post the code you were using to test this? If you connect the GPS to pins 0 and 1 you would use Serial.read()I was trying to that without success,
