Any suggestions?
Paul
This is an example for our Monochrome OLEDs based on SSD1306 drivers
Pick one up today in the adafruit shop!
------> http://www.adafruit.com/category/63_98
This example is for a 128x64 size display using I2C to communicate
3 pins are required to interface (2 I2C and one reset)
products from Adafruit!
BSD license, check license.txt for more information
All text above, and the splash screen must be included in any redistribution
#include <SPI.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
char* phrases[] = /* Known phrases */{" Ask again later", " It is certain",
" Without a doubt", " Yes definitely", " As I see it, yes", " Most likely",
" Outlook good", " Yes", " My reply is no", " Very doubtful", " No",
" Not a chance", " No way", "Absolutely not", "I doubt it", " Ask again",
" I'm uncertain"};
char* output;
int numberofphrases = 17; //Number of phrases known, must be the same as, well, the number of phrases known
#define OLED_RESET 4
Adafruit_SSD1306 display(OLED_RESET);
#if (SSD1306_LCDHEIGHT != 64)
#error("Height incorrect, please fix Adafruit_SSD1306.h!");
#endif
randomSeed(analogRead(1)); //Seed for random number generation
Serial.begin(9600);
// by default, we'll generate the high voltage from the 3.3v line internally! (neat!)
display.begin(SSD1306_SWITCHCAPVCC, 0x3D); // initialize with the I2C addr 0x3D (for the 128x64)
// init done
// Show image buffer on the display hardware.
// Since the buffer is intialized with an Adafruit splashscreen
// internally, this will display the splashscreen.
display.display();
delay(20);
// Clear the buffer.
display.clearDisplay();
// text display tests
display.setTextSize(2);
display.setTextColor(WHITE);
display.setCursor(0,12);
display.println(" I'm Thinking !");
display.display();
delay(1000);
for(int x=0; x < 30; x++)
output = phrases[random(numberofphrases)]; //Chooses phrase
display.println(output);
display.display();
delay(3);
delay(3000);
display.setCursor(0,0);
display.println(" Invert Ball to try again or quit");
display.display();
delay(1000);
C:\Users\reisinger\Documents\Arduino\trinket IDE\libraries\Robot_Control\ArduinoRobot.cpp: In constructor 'RobotControl::RobotControl()':
C:\Users\reisinger\Documents\Arduino\trinket IDE\libraries\Robot_Control\ArduinoRobot.cpp:8: error: 'LCD_CS' was not declared in this scope
C:\Users\reisinger\Documents\Arduino\trinket IDE\libraries\Robot_Control\ArduinoRobot.cpp:8: error: 'DC_LCD' was not declared in this scope
C:\Users\reisinger\Documents\Arduino\trinket IDE\libraries\Robot_Control\ArduinoRobot.cpp:8: error: 'RST_LCD' was not declared in this scope
C:\Users\reisinger\Documents\Arduino\trinket IDE\libraries\Robot_Control\ArduinoRobot.cpp: In member function 'void RobotControl::begin()':
C:\Users\reisinger\Documents\Arduino\trinket IDE\libraries\Robot_Control\ArduinoRobot.cpp:18: error: 'MUXA' was not declared in this scope
C:\Users\reisinger\Documents\Arduino\trinket IDE\libraries\Robot_Control\ArduinoRobot.cpp:18: error: 'MUXB' was not declared in this scope
C:\Users\reisinger\Documents\Arduino\trinket IDE\libraries\Robot_Control\ArduinoRobot.cpp:18: error: 'MUXC' was not declared in this scope
C:\Users\reisinger\Documents\Arduino\trinket IDE\libraries\Robot_Control\ArduinoRobot.cpp:18: error: 'MUXD' was not declared in this scope
C:\Users\reisinger\Documents\Arduino\trinket IDE\libraries\Robot_Control\ArduinoRobot.cpp:19: error: 'MUX_IN' was not declared in this scope
C:\Users\reisinger\Documents\Arduino\trinket IDE\libraries\Robot_Control\ArduinoRobot.cpp:22: error: 'BUZZ' was not declared in this scope
C:\Users\reisinger\Documents\Arduino\trinket IDE\libraries\Robot_Control\ArduinoRobot.cpp:25: error: 'Serial1' was not declared in this scope
