Flora and LED Sequins and RGB LEDs
digity
Post by digity »
I'm looking into using Flora to program some LEDs to twinkle and fade...
how many Adafruit LED Sequins (https://www.adafruit.com/product/1758) can Flora support? how many feet can the run be? how can Flora be configured to extend the run (i.e., use higher voltage or amperage, add more power after X feet or make a whole new run with another Flora)?
Aslo... how many NeoPixel 5050 RGB LEDs (https://www.adafruit.com/products/1655) can Flora support? how many feet can the run be? how can Flora be configured to extend the run (i.e., use higher voltage or amperage, add more power after X feet or make a whole new run with another Flora)?
Franklin97355
Re: Flora and LED Sequins and RGB LEDs
Post by Franklin97355 »
Can you be more specific in what you are trying to accomplish?
digity
Post by digity »
I'm trying to string 50 to 100 LEDs together (not sure yet if it'll be RGB or the warm white sequins) with each LED at least 1 to 2 feet apart which means the whole thing may be 50 to 200 feet long. So, I'm basically trying to find out Flora's limitations and how I could get around them if necessary
To drive that many sequins, you would need something like a MOSFET to switch the current. https://www.adafruit.com/product/355
For RGB sequins, you would need 3 of them.
The MOSFETs can drive several thousand sequins. Note that unlike Neopixels, sequins are not individually addressable. All sequins in a string will react the same.
The Flora can handle several hundred neopixel easily. Neopixels have their own built-in drivers and are individually controllable, so you don't need the MOSFETs. However, the spacing could be a problem. 6" spacing is easily achieved. Beyond that requires careful wiring and in some cases additional signal buffering.
In all cases (Neopixels or Sequins) you will need a power supply capable of supplying current to that many LEDs and wiring adequate to carry the current without excessive voltage drop over the distance.
digity
Post by digity »
On the Sequin product page it says "You can make the LEDs fade and twinkle by using the PWM (a.k.a. analogWrite) functionality of your Gemma or Flora..." Since I can't control them individually, can I at least set random lights to randomly brighten and dimmer while others stay lit at a certain brightness?
Franklin97355
You can make all the leds on a certain pin blink or fade at the same time and have more than one pin controling leds but you can't pick the individual leds with the sequins.
The processor has only so many PWM pins. You can connect a string to each of the PWM pins and control the different strings separately, but all the sequins on a string will react together.
If you want random changes, there are these LEDs. They will randomly flash by themselves without any need for a microprocessor:
https://www.adafruit.com/products/680
https://www.adafruit.com/products/679
Return to “Arduino”
