Hello - I've recently bought and built this project (https://learn.adafruit.com/kaleidoscope ... a/overview) and it's all working and really great. The thing is, I need it for a specific thing, and I just want the lights to be white, and on all the time. I've tried to decipher the code of it all (using examples I've found on various sites), but I think I'm better with a soldering iron than with coding! If anyone has the simple code to just make these rings shine white all the time - or can point me to where it can be found - it would be deeply appreciated.
Kaleidoscope Eyes - some simple code
Re: Kaleidoscope Eyes - some simple code
Replace your loop() function with the following:just make these rings shine white all the time
void loop()
for (int i = 0; i < 32; i++)
setPixelColor(i, 100, 100, 100);
To make it dimmer, use smaller numbers.
- DomMorley
Wow - that was fast!
Thank you so much. I'll try that tonight!
Dom
Dom
- DomMorley
OK, so I've hacked it onto some previously working code I have, ending up in this:
but now I get the error:
Any ideas what's going wrong there?
Thanks again.
#define PIN 0
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(32, PIN);
uint8_t mode = 0, // Current animation effect
offset = 0; // Position of spinny eyes
uint32_t color = 0x000000; // Start red
uint32_t prevTime;
pixels.begin();
pixels.setBrightness(85); // 1/3 brightness
prevTime = millis();
void loop()
Did I mention that I'm a noob! ;-)error: 'setPixelColor' was not declared in this scope
Thanks again.
Reason: Please use [code] tags when posting code they look like </> above the reply window
- Franklin97355
That line should read pixels.setPixelColor(i, 100, 100, 100);
- DomMorley
That's much happier (no errors) although I've found it just has the effect of pausing the previous programming as opposed to re-setting it and turning it all white.
The spinning rainbows have now stopped going round and are stationary, so it's obviously having some controlling effect, just not doing the 'all just white' thing I was hoping for :-(
Sorry if I'm being a pain!
You have to completely replace your loop() function with the one I posted (plus Franklin's correction)I've found it just has the effect of pausing the previous programming as opposed to re-setting it and turning it all white.
- DomMorley
Ah - sorry. I thought I had! I replaced everything after void loop() with what you said, and I've just tried erasing all manner of combinations as it's clear there's more to the loop() function than I thought. I either make it go to error or it has no effect though. It's painful being a noob :-(
The loop function is everything from "void loop()" to the end of the file.
This should do what you want.
// Low power NeoPixel goggles example. Makes a nice blinky display
// with just a few LEDs on at any time.
#ifdef __AVR_ATtiny85__ // Trinket, Gemma, etc.
#include <avr/power.h>
#endif
#define PIN 0
uint32_t color = 0xFF0000; // Start red
uint32_t prevTime;
if(F_CPU == 16000000) clock_prescale_set(clock_div_1);
#endif
pixels.begin();
void loop()
- DomMorley
Thanks so much for your effort here - truly appreciated.
I fear there must be something more fundamental wrong with my unit though, as this still doesn't work. In fact, if I load this code when I turn it on, it doesn't do anything at all. I have to load another bit of code (I have a flashy rainbow one that works), and then load this one to get it to do something. And then it just pauses the flashing and moving of the coloured lights from the rainbow display. Nothing white and a couple of the LEDs out (as per the movement of the previous code). Perhaps I have a dodgy Trinket or something?
Sorry, I forgot a line. Try this one:
#endif
#define PIN 0
uint32_t prevTime;
#endif
pixels.begin();
void loop()
pixels.show();
- DomMorley
EUREKA!!!!
FANTASTIC - thank you so much. You have no idea the hours I've spent trawling the web until I got onto this forum, just trying to learn enough code to make this happen.
Thank you very, very much.
