Arduino due
adafruit_support_rick
Re: Arduino due
Post by adafruit_support_rick »
Adding a delay is the correct way to debounce touches.
PaulvZ
Re: Arduino due
Post by PaulvZ »
I am testing different sizes for #BUFFPIXEL when reading bitmaps, the Due has enough space. But only the value 20 gives the picture. The other values I tried gives just colored stripes. Is there a rule for changing the value of #BUFFPIXEL?
Re: Arduino due
I just tried 20, 30, and 40. They all work. What values are you trying?
PaulvZ
Re: Arduino due
Post by PaulvZ »
I tried 60, 90, 120 and 180.
Re: Arduino due
It works with 60 for me.
The problem with the larger numbers is this variable in bmpDraw
 uint8_t  buffidx = sizeof(sdbuffer); // Current position in sdbuffer
It's an 8-bit unsigned integer. The reason BUFF PIXEL 90 doesn't work is that the size of sdbuffer becomes 270, which is too large for an 8-bit integer. Change buffidx to type uint16_t, and the larger BUFFPIXEL sizes will work.
However, the comment about it getting faster with larger BUFFPIXEL values is just wrong. I clock it as the same with 180 as it is with 20.
MikeMenci
Re: Arduino due
Post by MikeMenci »
Hello ,
Why is this error - anyone can help me here - Im trying to solve this for 2 days now...
enabled in File > Preferences.
Arduino: 1.0.6 + Td: 1.21-test2 (Windows 7), Board: "Teensy 3.1"
In file included from Screensaver.h:8:0,
from Reflow.ino:15:
Adafruit_FT6206.h:47: error: redefinition of 'class TS_Point'
class TS_Point {
In file included from SplashScreen.h:8:0,
from ReflowChateau.ino:14:
Adafruit_FT6206.h:47: error: previous definition of 'class TS_Point'
class TS_Point {
from Reflow.ino:15:
Adafruit_FT6206.h:58: error: redefinition of 'class Adafruit_FT6206'
class Adafruit_FT6206 {
Errors of Adafruit_FT6206 go on and on....
class TS_point - public
any tips ?
Re: Arduino due
You have two different libraries that are defining TS_Point. Adafruit_FT6206 is one of them. What's the other one?
Please post your code.
jim_lee
Re: Arduino due
Post by jim_lee »
Bit late but I think this is the trouble..
#ifndef Adafruit_FT6206_h
#define Adafruit_FT6206_h
..code..
#endif
is missing in Adafruit_FT6206.h
-jim lee
Re: Arduino due
Good find. Fixed!
Return to “Arduino”
