Passing PGM_P into functions
Postby morrijr » Tue Aug 26, 2008 7:17 am
I'm having problems using progmem, I'm correctly getting "Test working?" when directly calling strcpy_P in the loop but not for the other cases. I need to pass the string into another function where, as below, I do the conversion to buffer there. As far as I can tell (with limited embedded knowledge) these should be all the same...
Can anyone help?
Thanks.
#include <avr/pgmspace.h>
const prog_char PROGMEM stringTest[] = "Test working?";
PGM_P PROGMEM stringTestTable[] = { stringTest };
char buffer[17];
   Serial.begin(9600);
   strcpy_P(buffer, (char*)pgm_read_word(&(stringTestTable[0])));
   Serial.print(buffer);
   Serial.print(" : ");
   strcpy_P(buffer, (char*)pgm_read_word(&(stringTest)));
   Print(stringTestTable[0]);
   Print(stringTest);
void Print(PGM_P str) {
   strcpy_P(buffer, (char*)pgm_read_word(&(str)));
   Serial.println(buffer);
morrijr
Re: Passing PGM_P into functions
Postby mtbf0 » Tue Aug 26, 2008 8:08 am
don't have time to research it properly, but something like this ought to be a start.
   Print(&stringTestTable[0]);
void Print(PGM_P *str) {
   strcpy_P(buffer, (char*)pgm_read_word(str));
maybe
mtbf0
Postby morrijr » Tue Aug 26, 2008 10:20 am
That gives me
error: cannot convert ‘const prog_char*’ to ‘const prog_char**’ for argument ‘1’ to ‘void Print(const prog_char**)’
PGM_P is typedef'd to const prog_char*
thanks for the response, I've been asking on several boards/irc for a few days now and this is the first time somebodies actually suggested something!
J.
morrijr
Postby mtbf0 » Tue Aug 26, 2008 7:33 pm
see, that's what i didn't have time to look up.
i'd suggest changing the function definition back to what it was, i.e. lose the asterisk, and either keep the other change i suggested or use
   Print(stringTestTable);
your original code passes the character 'T' to the function. either of my versions pass its address.
sorry to have answered before i was fully awake and while i was trying to get out the door.
mtbf0
Postby morrijr » Wed Aug 27, 2008 3:41 am
Hi mtbf0,
westfw on the Arduino Forum pointed me in the right direction. BTW, I didn't typedef PGM_P, it's a standard one in avr/pgmspace.h
Anyway, for anyone wanting to know what the answer is;
char buffer[17];
   Serial.begin(9600);
   // the pgm_read_word here is to get the correct pointer from the PROGMEM array
   // pgm_read_word is not required here because it is handled within strcpy_P
   strcpy_P(buffer, stringTest);
   // I don't understand why pgm_read_word isn't required for
   // this one but is for the first?
   // within the called function (Print)
   Print(stringTest);
   Serial.println("");
   strcpy_P(buffer, str);
As you can see, I still don't understand why the third test works, but *shrug* :)
But, as I said; thank you very much for at least attempting to help.
J.
morrijr
Postby mtbf0 » Wed Aug 27, 2008 6:57 am
i'm so ashamed.
but maybe i can help you uncerstand what's going on...
this declares a zero terminated array of characters, i.e. a string, in program memory.
this declares an array, (a very short array), of addresses of strings in program memory. note that these addresses are 16 bit values.
this will read the address of stringTest from program memory.
an array reference without a subscript gives the address of the array, thus "stringTest" resolves to the address of stringTest.
stringTestTable is an array of string addresses, so "stringTestTable[0]" resolves to the address of stringTest.
the difference between the first and third examples is that in the first example the address resolves at run time and in the third it is resolved at compile time. this doesn't really seem right until you consider that data stored in program memory are implicitly const and so will not be altered at run time.
this means that the third example will run faster than the first and in this case would be the one you want to use. you would want to use the first example in the case where your stringTestTable is longer than one entry and you are using a variable index, because that reference would not be resolvable at compile time.
so...
  int i = 0;
  Print(stringTestTable[i]);
... should not work.
but i've been wrong before. at least twice that we know of.
mtbf0
Return to Arduino
Users browsing this forum: No registered users and 8 guests
New Products [105]
LEDs[108]
Cables[60]
Prototyping[69]
