Friends:
In an if statement, if I want to indicate that any one of several inputs to the serial port should cause an event to occur, how is it coded? For instance, if I want a pin set high, or to serialPrint something if the serial port receives the character "a", the code might read as follows:
if (Serial.available() > 0);
char letter = Serial.read();
if (letter == 'a')
Serial.println (F("ON"));
However, what if I want the same thing done-- i.e., Serial.println (F("ON"))-- if the port receives an "a", or "b", or "c"?
I cannot seem to find an informative answer or tutorial.
Thank you in advance.
if statement with multiple conditions
- Franklin97355
- fprete
Re: if statement with multiple conditions
Thank you very much.
