Adafruit 1-Wire Thermocouple Amplifier - MAX31850K for 3 K-t
- runnu
Hi i am using Adafruit 1-Wire Thermocouple Amplifier - MAX31850K for 3 thermocouples. the programme is detecting 3 devices in the serial console but it is only giving 2 temperature readings the other one is not appearing. What should i do?
- Screen Shot 2015-03-07 at 16.24.14.png (612.01 KiB) Viewed 596 times
Re: Adafruit 1-Wire Thermocouple Amplifier - MAX31850K for 3
Post the code you're using (between CODE tags please) and we'll take a look.
- runnu
Thanks for your help. This is the code I'm using
[#include <OneWire.h>
#include <DallasTemperature.h>
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS 2
#define TEMPERATURE_PRECISION 9
// Setup a oneWire instance to communicate with any OneWire devices (not just Maxim/Dallas temperature ICs)
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// arrays to hold device addresses
DeviceAddress insideThermometer, outsideThermometer;
void setup(void)
// start serial port
Serial.begin(9600);
Serial.println("Dallas Temperature IC Control Library Demo");
// Start up the library
sensors.begin();
// locate devices on the bus
Serial.print("Locating devices...");
Serial.print("Found ");
Serial.print(sensors.getDeviceCount(), DEC);
Serial.println(" devices.");
// report parasite power requirements
Serial.print("Parasite power is: ");
if (sensors.isParasitePowerMode()) Serial.println("ON");
else Serial.println("OFF");
// assign address manually. the addresses below will beed to be changed
// to valid device addresses on your bus. device address can be retrieved
// by using either oneWire.search(deviceAddress) or individually via
// sensors.getAddress(deviceAddress, index)
//insideThermometer = { 0x28, 0x1D, 0x39, 0x31, 0x2, 0x0, 0x0, 0xF0 };
//outsideThermometer = { 0x28, 0x3F, 0x1C, 0x31, 0x2, 0x0, 0x0, 0x2 };
// search for devices on the bus and assign based on an index. ideally,
// you would do this to initially discover addresses on the bus and then
// use those addresses and manually assign them (see above) once you know
// the devices on your bus (and assuming they don't change).
// method 1: by index
if (!sensors.getAddress(insideThermometer, 0)) Serial.println("Unable to find address for Device 0");
if (!sensors.getAddress(outsideThermometer, 1)) Serial.println("Unable to find address for Device 1");
if (!sensors.getAddress(insideThermometer, 2)) Serial.println("Unable to find address for Device 2");
// method 2: search()
// search() looks for the next device. Returns 1 if a new address has been
// returned. A zero might mean that the bus is shorted, there are no devices,
// or you have already retrieved all of them. It might be a good idea to
// check the CRC to make sure you didn't get garbage. The order is
// deterministic. You will always get the same devices in the same order
// Must be called before search()
//oneWire.reset_search();
// assigns the first address found to insideThermometer
//if (!oneWire.search(insideThermometer)) Serial.println("Unable to find address for insideThermometer");
// assigns the seconds address found to outsideThermometer
//if (!oneWire.search(outsideThermometer)) Serial.println("Unable to find address for outsideThermometer");
// show the addresses we found on the bus
Serial.print("Device 0 Address: ");
printAddress(insideThermometer);
Serial.println();
Serial.print("Device 1 Address: ");
printAddress(outsideThermometer);
Serial.println();
Serial.print("Device 2 Address: ");
Serial.println();
// set the resolution to 9 bit
sensors.setResolution(insideThermometer, TEMPERATURE_PRECISION);
sensors.setResolution(outsideThermometer, TEMPERATURE_PRECISION);
Serial.print("Device 0 Resolution: ");
Serial.print(sensors.getResolution(insideThermometer), DEC);
Serial.println();
Serial.print("Device 1 Resolution: ");
Serial.print(sensors.getResolution(outsideThermometer), DEC);
Serial.println();
Serial.print("Device 2 Resolution: ");
Serial.println();
// function to print a device address
void printAddress(DeviceAddress deviceAddress)
for (uint8_t i = 0; i < 8; i++)
// zero pad the address if necessary
if (deviceAddress[i] < 16) Serial.print("0");
Serial.print(deviceAddress[i], HEX);
// function to print the temperature for a device
void printTemperature(DeviceAddress deviceAddress)
float tempC = sensors.getTempC(deviceAddress);
Serial.print("Temp C: ");
Serial.print(tempC);
Serial.print(" Temp F: ");
Serial.print(DallasTemperature::toFahrenheit(tempC));
// function to print a device's resolution
void printResolution(DeviceAddress deviceAddress)
Serial.print("Resolution: ");
Serial.print(sensors.getResolution(deviceAddress));
Serial.println();
// main function to print information about a device
void printData(DeviceAddress deviceAddress)
Serial.print("Device Address: ");
printAddress(deviceAddress);
Serial.print(" ");
printTemperature(deviceAddress);
Serial.println();
void loop(void)
// call sensors.requestTemperatures() to issue a global temperature
// request to all devices on the bus
Serial.print("Requesting temperatures...");
sensors.requestTemperatures();
Serial.println("DONE");
// print the device information
printData(insideThermometer);
printData(outsideThermometer);
Reason: Added missing [/code] closing tag.
You only have two variables holding sensor ID numbers:
When you get the sensor addresses:
The third line replaces the address collected by the first.
You need different variables to hold the addresses of sensor 0 and sensor 2.
- runnu
So should i name sensor 2 an other number?
Sorry but I'm new to this programming.
It seems that it is finding the the 3 thermocouples, but not plotting the readings of the second thermocouple.
- Screen Shot 2015-03-08 at 22.39.17.png (71.02 KiB) Viewed 534 times
Yes. Try insideThermometer1, insideThermometer2, and outsideThermometer.runnu wrote:So should i name sensor 2 an other number?
- runnu
Hi i managed to get 3 readings but it seems that the 3 readings are of the same sensor the middle one (sensor 2) the one that it was not working. it seems that the programme also got 3 addresses and are the same.
In this programme i changes all the names of the thermocouples to : 1, 2 and 3 and changes all programme to inside thermometer , inside thermometer and out side thermometer.
Thanks for your help and sorry for the inconvenience
[printData(insideThermometer);
printData(outsideThermometer)]
the programme is as follows:
[code][#include <OneWire.h>
void setup(void)
Serial.begin(9600);
sensors.begin();
if (!sensors.getAddress(insideThermometer, 1)) Serial.println("Unable to find address for Device 1");
if (!sensors.getAddress(outsideThermometer, 3)) Serial.println("Unable to find address for Device 3");
Serial.println();
Serial.println();
Serial.print("Device 3 Address: ");
Serial.println();
Serial.println();
Serial.println();
Serial.print("Device 3 Resolution: ");
Serial.println();
Serial.println();
Serial.print(" ");
Serial.println();
void loop(void)
- 2.png (75.44 KiB) Viewed 500 times
Reason: Added missing closing [/code] tag
You don't seem to have the idea of using unique variable names.
How do you tell the difference between 'insideThermometer' and 'insideThermometer'?
- runnu
Yes I named them but still the third sense is not being identified
DeviceAddress insideThermometer1, insideThermometer2, outsideThermometer3;
void setup(void)
Serial.begin(9600);
sensors.begin();
if (!sensors.getAddress(insideThermometer1, 1)) Serial.println("Unable to find address for Device 1");
if (!sensors.getAddress(insideThermometer2, 2)) Serial.println("Unable to find address for Device 2");
if (!sensors.getAddress(outsideThermometer3, 3)) Serial.println("Unable to find address for Device 3");
printAddress(insideThermometer1);
Serial.println();
printAddress(insideThermometer2);
Serial.println();
printAddress(outsideThermometer3);
Serial.println();
sensors.setResolution(insideThermometer1, TEMPERATURE_PRECISION);
sensors.setResolution(insideThermometer2, TEMPERATURE_PRECISION);
sensors.setResolution(outsideThermometer3, TEMPERATURE_PRECISION);
Serial.print(sensors.getResolution(insideThermometer1), DEC);
Serial.println();
Serial.print(sensors.getResolution(insideThermometer2), DEC);
Serial.println();
Serial.print(sensors.getResolution(outsideThermometer3), DEC);
Serial.println();
Serial.println();
Serial.print(" ");
Serial.println();
void loop(void)
printData(insideThermometer1);
printData(insideThermometer2);
printData(outsideThermometer3);
- Franklin97355
Please go back and edit your message to add the closing [/code] tag at the end of your posted code.
- runnu
void setup(void)
Serial.begin(9600);
sensors.begin();
Serial.println();
Serial.println();
Serial.println();
Serial.println();
Serial.println();
Serial.println();
Serial.println();
Serial.print(" ");
Serial.println();
void loop(void)
The output posted above doesn't seem to be consistent with the most recent version of the code you've posted.
In this section:
the address numbers should be 0, 1, and 2. I'd expect the code to tell you it couldn't find an address for Device 3.
Try changing that section like this:
and post the output you get.
In this section:
if (!sensors.getAddress(insideThermometer1, 0)) Serial.println("Unable to find address for Device 1");
if (!sensors.getAddress(insideThermometer2, 1)) Serial.println("Unable to find address for Device 2");
if (!sensors.getAddress(outsideThermometer3, 2)) Serial.println("Unable to find address for Device 3");
- runnu
Hi, thanks a lot it seems that it has worked perfectly. this is the code for three k-Type thermocouples. The sensors are not plotted one after the other but one can easily identify the sensors readings.
void setup(void)
Serial.begin(9600);
sensors.begin();
Serial.println();
Serial.println();
Serial.println();
Serial.println();
Serial.println();
Serial.println();
Serial.println();
Serial.print(" ");
Serial.println();
void loop(void)
- 3.png (89.27 KiB) Viewed 422 times
Yeah, that shows different addresses for each of the three sensors.
Glad to see that it's working!
