I tried the example code for the mcp9808 and it works fine.
I would like to have two mcp9808.
My question is how do i properly syntax in code to address each mcp9808 and read the temperature from both?
**below is just an lcd example, i'm not asking about LCDs**
Just for an example when I use two LCDs with the backpack with I2C, I use the following:
LiquidCrystal lcd1(0);
LiquidCrystal lcd2(1);
then i can print to each lcd such as:
lcd1.print("some text");
lcd2.print("some other text");
mcp9808 I2C proper syntax addressing
- sxrg
Re: mcp9808 I2C proper syntax addressing
Let me add that I know that the default addressing is 0x18 and how to apply the addressing by connecting A0 and or A1 and A@ high with would change the addressing to 0x19 and so on.
- Franklin97355
This is the code for the begin function: so you would add an address to the begin call in your code.
boolean Adafruit_MCP9808::begin(uint8_t addr)
mcp2.begin(0x19);
- sxrg
Thanks for the reply.
Using the example code for the mcp9808 I added your code:
This seems to work, i can see the two different temperatures.
But i kept getting errors when I tried to add:
Where is this placed?
Adafruit_MCP9808 tempsensor = Adafruit_MCP9808();
Adafruit_MCP9808 mcp2 = Adafruit_MCP9808(); //your added code for the second mcp9808
tempsensor.begin();
mcp2.begin(0x19);
boolean Adafruit_MCP9808::begin(uint8_t add)
- Franklin97355
That is the prototype in the .h file. You don't add that it was just to show you where the address went.Where is this placed?
- sxrg
Sorry for my ignorance..lol
But, Thank you very much. I appreciate it.
