Binary sketch size: 11,774 bytes (of a 28,672 byte maximum)
processing.app.debug.RunnerException: Couldn’t find a Leonardo on the selected port. Check that you have the correct port selected. If it is correct, try pressing the board's reset button after initiating the upload.
at processing.app.debug.AvrdudeUploader.uploadViaBootloader(AvrdudeUploader.java:152)
at processing.app.debug.AvrdudeUploader.uploadUsingPreferences(AvrdudeUploader.java:67)
at processing.app.Sketch.upload(Sketch.java:1671)
at processing.app.Sketch.exportApplet(Sketch.java:1627)
at processing.app.Sketch.exportApplet(Sketch.java:1599)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2380)
at java.lang.Thread.run(Thread.java:619)
I discovered the port to be COM17. I changed the port under Tools. But the upload is taking forever,(over 30 minutes) without completing. I've stopped and tried again and again. on the third attempt, it returned an error that avr.a could not be rewritten. I am trying the 4th attempt now and I've attached the screenshots. What could be the issue? could it be windows 8?
Thanks. I've downloaded the new one. But upon istalling requisite libraries, i got an error about duplicate libraries.When i uninstalled them, i got an error about missing libraries.
Anyway, I tried uploading, but as soon as i clicked upload, the flora automatically disconnected. is this normal? I still got an error and an advice to click the reset button after clicking uplaod. NOw I dont even know if it finished uploading.
Here is the log and a screenshot.
Multiple libraries were found for "Adafruit_LSM303.h"
Used: C:\Users\Johnoamen\Downloads\adafruit-arduino-1.6.3-windows\arduino-1.6.3\libraries\Adafruit_LSM303
Not used: C:\Users\Johnoamen\Downloads\adafruit-arduino-1.6.3-windows\arduino-1.6.3\libraries\Adafruit_LSM303
Multiple libraries were found for "Adafruit_WS2801.h"
Used: C:\Users\Johnoamen\Downloads\adafruit-arduino-1.6.3-windows\arduino-1.6.3\libraries\Adafruit_WS2801
Not used: C:\Users\Johnoamen\Downloads\adafruit-arduino-1.6.3-windows\arduino-1.6.3\libraries\Adafruit_WS2801
Sketch uses 11,368 bytes (39%) of program storage space. Maximum is 28,672 bytes.
Global variables use 562 bytes of dynamic memory.
Go into the Preferences menu and select verbose on upload. Then quit and restart the IDE. That will give you an idea of what's going on with the upload.
Forcing reset using 1200bps open/close on port COM17
PORTS {COM3, COM17, } / {COM3, COM17, } => {}
PORTS {COM3, COM17, } / {COM3, } => {}
PORTS {COM3, } / {COM3, } => {}
processing.app.debug.RunnerException: Couldn't find a Board on the selected port. Check that you have the correct port selected. If it is correct, try pressing the board's reset button after initiating the upload.
at cc.arduino.packages.uploaders.SerialUploader.waitForUploadPort(SerialUploader.java:234)
at cc.arduino.packages.uploaders.SerialUploader.uploadUsingPreferences(SerialUploader.java:130)
at processing.app.debug.Compiler.upload(Compiler.java:165)
at processing.app.Sketch.upload(Sketch.java:1260)
at processing.app.Sketch.exportApplet(Sketch.java:1202)
at processing.app.Sketch.exportApplet(Sketch.java:1174)
at processing.app.Editor$DefaultExportHandler.run(Editor.java:2471)
at java.lang.Thread.run(Thread.java:745)
enabled in File > Preferences.
Hello everyone. I got my adafruit flora replacement and uploaded the sketch. Then I soldered all the components, but there seems not to be any power flowing into the system from the battery section. I just got a multimeter, and I want to test the individual components separately before putting them together. How can I test the flora part without the wireless components?
